Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Laser 73 Heat exchanger loose part
Hey Guys,
On my Laser 73, when I took the heat exchanger off, I discovered that there is a loose piece of metal inside the lower chamber. It is just sliding around. I'm guessing it is some sort of baffle to direct the air flow into the upper chamber, before being routed down through those 14 tubes, and out through the blower motor.
Any thoughts would be appreciated.
Thank you,
Mike U.
  • g_m_urban1 Mar 09, 2009
    Thanks Tom, I'll look into that. Definitely will keep/rebuild this heater.
    But you know, the color of the Stainless Steel on the heat exchanger does not look bad, and there is no warping. You definitely think it's a goner? How is that baffle situated int the exchanger?
    Best
    Mike U.
  • g_m_urban1 Mar 10, 2009
    Thanks Tom. Just wanted to be sure. I will definitely completely rebuild this heater. I've gotten some 13 years out of it, so if I could get another 5 or 10 years from her, I would be thrilled.
    It is hands-down a great heater, and I would not hesitate to buy another.
    Again, thank you for you expertise.
    Best regards,
    Mike U.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
GM,
As I mentioned in the last post, you are in need of a big overhaul. The heat exchanger baffle that has become detached is a sign of a heater that has been running very hot. When you get down into the burner you may find a warped bottom. If so, you are looking at a new burner, and heat exchanger. The burner ring and several gaskets will also need replacing. All the above will run around $600+. Despite the high cost of parts you are better off rebuilding than buying new by $1000 or so. When you look at it in the long run you are spending $60 or so a year for the 10 years you have owned the unit. Not bad, I'd say.
good luck,
Tom Hawkins
hawkins111@gci.net
Posted on Mar 09, 2009
  • Thomas Hawkins Mar 10, 2009
    Mike,
    Trust me, it's a goner. The baffle is welded before exchanger is put together. The heat from the burner hits the baffle first. That is one of the hottest parts of the heater. Your burner mat has been gone for some time and the ring has warped. This and the chance the pot is warped causes a hot flame that leaps high in the chamber. It hit the baffle in the exchanger and you're done.
    Tom Hawkins
Have a Pentair Minimax Plus 400 heater leaking water. How do you get the top and flue collector (gas is turned off at source) off so you can see if the heat exchangers are leaking, or is there another way...
There are multiple screws around the perimeter, remove them then lift of the top. Then there is multiple pieces of sheet metal that also needs removal. Then the baffles sit right on top of the heat exchanger which will easily be removed once the sheet metal is removed. then inspect the exchanger.
Good luck
May 22, 2014 | Pentair Pool & Spa
Burns orange?
Could be orange for a few reasons could just be burning some dust or something in the air. if it keeps staying orange i would say that it has a cracked heat exchanger and the fan is disrupting the flame.
Dec 28, 2013 | Rinnai Toyostove Direct Vent Heater:...
MY LASER 73 IS DISPLAYING ee 8 i BELIEVE THIS TO BE A BLOWER PROBLEM WHERE MAY I FIND A TECHNICIAN TO FIX THIS PROBLEME
Yes it is a motor issue. They frequently quit turning after sitting a while. Remove the heat exchanger and vacuum out the exhaust side of the blower motor. Use a dental pic if you have one and gently clean the impeller fins. Vacuum it again, then lightly spray impeller with water, and vacuum often. When impeller is clean, reassemble and your stove will start. ( This is assuming you were able to turn the impeller when you cleaned it) Thanks and good luck
Aug 21, 2012 | Rinnai Toyostove Direct Vent Heater:...
My heater rattles I took off the inlets and saw a piece of loose metal between the inlet and outlet
Thank you for posting your question here on Fixya.com.
That is the diverter plate and it should be welded into the header. It helps direct some of the water flowing thru into the heat exchanger to heat the water. If the weld fails the diverter can interfere with that flow and cause overheating or poor flow thru the heater which in turn can lead to the problems you describe.
Remove the inlet side hose once you have blocked the flow of water from the pool and you should see the diverter in the inlet. If you can move it then it is broken and needs to be fixed back in place or the whole heat exchanger needs to be replaced.
If you can weld then tack in back in place. If not a local rediator repair shop MIGHT be able to fix it or else you need to replace the whole heat exchanger assembly.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Sep 06, 2011 | Hayward 100kbtu Pool Or Spa Propane Gas...
Toyo laser 73 error code EE8. What does that mean?
All error codes are explained on the lower left side of the heater. The EE8 message is for the combustion blower motor. If your stove has been unused for the summer you may get away with just spinning the blower wheel by hand to free it up. If this does not work you are in for a new motor or assembly. Either way you need to clean the blower and heat exchanger.
Tom
Aug 23, 2010 | Rinnai Toyostove Direct Vent Heater:...
Can i use parts from toyostove laser 56 on laser 72
can u use 72 heat exchanger on the 73???
May 12, 2010 | Heating & Cooling
Low heat output. Older Laser 72. Does something
It's likely that the burner mat has came loose or it has a lot of carbon buildup in the burner. Look at the flame when the heater is on. It should be mostly blue with slight yellow tips. You might need to clean the fuel nozzle also. You can remove the fuel pipe where it connects to the burner and use a piece of wire or an allen wrench that will fit in the nozzle that goes into the burner to remove any carbon that may have built up. You can also clean the burner but don't destroy the mat in the bottom. You can find the owner's manual at toyostove.com and it will give you some more things to clean.
Apr 17, 2010 | Rinnai Toyostove Direct Vent Heater:...
Does not extinguish
If your fuel was yellow it was #2 home heating oil. Toyotomi Laser heater run well on #1. Since yours in giving you a EE10 message you are going to have to open the burner and clean it, the blower and the heat exchanger. The air holes are blocked on the burner and it takes too long to burn the fuel up, EE10.
This is a dirty job but not that difficult. Try toyotomiusa.com/ and use their dealer locator. You should find a dealer in South Dakota that will be able to get you some gaskets you might need.
Good luck,
Tom Hawkins
hawkins111@gci.net
Jan 27, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyostove laser 73error codes
EE 6 can be some kind of obstruction in the fuel line causing the fuel to not reach the heater. It could be the high limit switch being activated. For that they say clean the fan, and fan cover. Your tank could be too high. The fuel sump valve could be malfunctioning. I think you would need to replace the pump for that. (It probably is not that as your heater does run for a while.) Finally it could be a flame sensor malfunction. Did you notice if there is a lot of carbon built up in your heat pot? It could be building up on the flame rod, causing the heater to not be able to sense a flame. Is your burner ring (the metal thing that sets inside the heat pot) warped? This will cause your heater to go out from time to time as the fame burns erratic and too hot, building up more carbon. Replacing that burner ring if it is warped could solve all your problems. You might wantt o replace the burner mat while you are at it.
Dec 31, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyostove L-73
I have used #2 in the summer. I have been told the difference between 1 and 2 is 1 has an additive so it won't free. I would use oil meant to be used as heating oil because it should be lower in sulfer.
Nov 18, 2008 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
139 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
