Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Vertical lines on a panasonic PT-53WX53G Chassis AP825
I was trying to help a friend fix his TV. The picture was distorted so I took a shot at changing the STK chips since that fixed the problem with my set earlier back. It was a successful repair however a new problem has come into play. The TV works great for and hour or two, after that, the screen goes to all bluish green lines going vertically about every 1/4 inch or so covering the whole screen (the lines are from the blue and green guns). It has done it with red also but only once. It over powers any feed (DVD, Cable, ect.) and makes it look almost like a negative. It also does it on all the inputs regardless weather there is anything hooked up or not. The weird thing is, the menu works fine (it displays over the problem). It almost looks like a stray signal coming from somewhere. Once this happens, it will only return back to normal once the set has been off for several hours. I tried wiggling and moving the board around suspecting a loose connection but it didn't change. I am guessing a heat related problem but I don't know where to start looking. I tried blowing air over certain areas with no effect. I have pictures of this problem if needed. Just leave me an address I can send them too. Any help with this matter would be greatly appreciated, Thanks
  • 1 more comment
  • Joe1974 Mar 11, 2009
    Which one is the A board? Is it one of the boards that clip into the
    main boards? I have several pics of the set. Let me know if you need
    any. Thanks, Joe
  • Joe1974 Mar 12, 2009
    Ok thanks, what does this board do anyway and where is the best place to get a replacement if needed?
  • Joe1974 Mar 16, 2009
    OK found the problem on the Panasonic, there was PTV fluid in/on the board. (long story) Cleaned the board, set is ok now. I have a new one for ya. I picked up a Sony KP57HW40 a while back, went through the turns one color and shuts off ****. I have a new but related problem. I posted it under Sony so here is the link, could you take a look at it?
    http://www.fixya.com/support/t1804972-so...
    Thanks
  • Panasonic Master
  • 8,617 Answers
I have seen that symptom caused by bad caps on the A board look at the tops of the capacitors for any sign of swelling or puffiness on the tops.
Posted on Mar 10, 2009
  • Sonny Berry
    Sonny Berry Mar 11, 2009
    The A board is the large green board on the left side when looking in the rear of the set
Black screen
how many times does the red light flash?
Techman
May 16, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic CinemaVision PT-47WX53G : half the screen is distorted
did you try to try to adjust the vertical and the horizontal of your tv?
Oct 05, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt-53wx53g vertical output ic
IC451 (Vertical Output) LA78045 part number is C1AA00000521
Available in Part Store.
Above info are taken from related service manual and an image of s.manual is given below...
Jun 19, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53wx53G 53' projection tv problem
was your tv hit hard,a non magnetically shielded speaker set on top or under it?
Nov 09, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Ghosting in Red, Green and blue
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 24, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic HDTV sound prblem
replies the audio IC then check the capacitor. also the mylar capacitor
Aug 26, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Picture shows only about a 2-3" blue,green,or red vertical line down the middle
If your seeing vertical line across the screen you need to check the components in the vertical stage as well as the vertical IC could be bad, or the yoke could open.
Also check if any voltage reaching the vertical stage.
Good luck.
Was this help full.
Oct 31, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Vertical lines and big red spot on Panasonic PT-56LCX66
Return it my friend, it sounds like a problem on the display panel driver board, and boy is that expensive to replace! Good Luck
Jul 30, 2007 | Panasonic PT-56LCX66 56" HDTV
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
245 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
