Question about Insignia I-LC23Q1 23 in. HD-Ready LCD Television
Audio fades then stops after a few minutes of power
New tv worked fine for about 6 months, then began experiencing audio problems. First some crackling, then (after power on a longer time), complete audio shut down. Initially troubleshooted by turning off tv for a short period of time, then turning it back on. But problem became more and more frequent to the point of not having audio at all.
I had this problem on a sharp flatscreen lcd. the audio output i.c. was a surface mount chip-had to change complete signal board assembly,
Posted on May 02, 2009
Hitachi 51F710E has no sound
The audio portion of the main board is failing. You can get a replacement here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 07, 2017 | Hitachi 51F710 Rear Projection Television
Marantx SR4600 Receiver
Some indication of power supply issue. if it is 6 months old. It should be still under warranty. Should it not?
Sep 07, 2007 | Marantz SR4600
My vizio 42" all of a sudden lost sound on the
I can see good video, but I hear no audio with my XWH200 adapters?
Published 11/21/2011 06:46 AM
Updated 11/21/2011 02:26 PM
While most HDMI sources work with good audio and video, we have a compatibility issue with audio from a few specific products (eg, DirecTV HD DVR satellite set-top box, DISH Networks satellite set-top-box, and TiVo Premiere XL cable set-top-box). If you are experiencing problems with no audio or muted audio with one of your HDMI sources, then please try changing the audio settings on your problematic HDMI source to PCM or LPCM. Then turn off the TV, remote power from the WirelessHD adapters, and power off the HDMI source. Now power everything back on. If you are still experiencing no audio then please write down the model number of your HDMI source with no audio and contact VIZIO customer support.
Oct 27, 2010 | Vizio VW42LF 42 in. LCD HDTV
Sanyo DP32649 works fine for a few minute, then sound goes off. turning the TV off for a moment & then back on restores the sound. But sometimes this will happen ever few minutes for the length of the...
I have the exact same problem. It's a volume control issue. For me, when I turn my TV on and have it on low volume, it works fine (but sounds somewhat distorted). But once I turn the volume up to normal levels, the speakers crackle and then go out. I opened my tv and checked my speakers, and they were perfectly fine; not blown or anything. As well, the audio processor and circuitry didn't appear burned at all.
This used happened every few months for 30min or and hour at a time. Then, about 2 months ago, it happened again, and ever since then it still hasn't worked properly. The only way I got around this was by buying a cheap 2.1 speaker system, and connecting it to the audio output on the TV. Or you could buy a speaker bar or home theater system. I believe this issue has to do with problems with the circuitry in the audio amplifier, and there's not much you can do except add external speakers, or contact Sanyo if you still have an active warranty.
Depending on where you bought your TV (such as from walmart), its possible that the LCD panel was produced by Sanyo, but the electronics were done in China. Walmart does this with nearly every TV they sell.
Jan 30, 2010 | Sanyo DP32649 31.5 in. TV
No audio after a few miutes
I changed the input from DV/DVD to VCR/TV and it worked for a six hour recording. Hope this helps.
Jun 08, 2009 | A D S DVD Xpress DX2
DVD video stops; audio continues
This definitely sounds like a circuit board-level issue. Have you tried moving to a different input set (i.e. if you're now on the TV inputs, try the DVD or AUX inputs for both video and sound)? Just to rule out the obvious, have you made sure that it's the receiver and not the DVD player? I know that you said you powered down the receiver, but if you had turned it off by pulling the plug on the surge suppressor and your DVD player is in the same suppressor, you might want to make sure it's the receiver and not the DVD player.
If you're sure that it's the receiver, then you might want to look into taking it to a Pioneer service center to have it repaired. If it's not worth the cost to you, it might be time to be looking into a new receiver.
Dec 10, 2007 | Pioneer VSX-D914 Receiver
SONY KP-57HW40
you are experiencing one or more of three things
1.the crt itself is damaged
2. the vertical ic on blue crt board is bad
3. the focus block is bad
if you hire a sony authorized technician they should be well aware of this problem.
Oct 22, 2007 | Sony KP-57HW40 57" Rear Projection...
JVC KD-LH300
dirty,clean the optical pick-up?
Apr 30, 2007 | JVC Sirius KD-LH300 CD Player
Picture faded to black, came back, faded again and had stayed black.
It seems your set has a loose conection in the high voltage circuits,in fact by now it should have many loose conections in different areas like the power supply and the horizontal deflection circuits,if you are familiar with tv service you can use the information as the first step to take,some of the loose conections are hard to see even for the trained technician but the one giving you this problem should not be hard to see,if you are not too familiar with tv service be safe and call for assistance from a servicer a least for an estimate.
Oct 11, 2006 | Mitsubishi CS-40507 40" TV
Insignia I-LC23Q1 23 in. HD-Ready LCD Television Logo
138 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
