Question about Frigidaire GLER642A Electric Dryer
My frigidaire dryer won't tumble
I have a 1 peice frigidaire washer/dryer combo and having problems with the dryer turning. I can see the heater coil getting red behind the drum and feel the warmth. Can you suggest anything to correct this? Hoe difficult is it to open up the machine and get to the belt?
Any help would be greatly appriciated!
Thank you in advance!
Brad Murray
  • 163 Answers
This belt you may want someone with experience.it does sound like your belt is bad but their is alot to go thru to put new belt on and if you never put one on before then it will be well worth spending a little.
Posted on Mar 09, 2009
How do you get the water to drain in the Malber WD100 washer/dryer combo?
Hi. I''m assuming you are referring to a WD1000.
To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
Sep 21, 2014 | Malber WD1000 Front Load Washer/Dryer
Why would a frigidaire flse60rgs1 combo dryer runs but not heat and washer not start?
check out house breaker and could be heating element problem or thermostat issues ,not enough info for more respond .
May 18, 2014 | Washing Machines
Can an frigidaire X091307954 dryer be stacked on a Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer?
this is possible, youll need a kit that sets on top of the washer,check back where you bought the washer and dryer, they make a washer and dryer combo thats one peice, they are smaller however
Jul 13, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
My frigidaire washer dryer combo does not agitate but when i turn on the dryer the washer turns on too. what can i do?
You have a problem with the lid lock assembly and it will need to be replaced. Here is the part to order. I also have the service manual if you should need it.
Nov 23, 2012 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire combo washer/dryer screws inside come off
The drum shaft came loose from drum. You can YouTube it for procedure of disassembly of dryer. Remount shaft, if screws are bad may need new shaft with screws, make sure it is tight to drum. While you have it apart you can clean out lint.
Sep 27, 2017 | Frigidaire GLER331A Electric Dryer
Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Dec 23, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire GLER642A Electric Dryer Logo
159 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
