Sony Vaio Laptop Model PCG-384L - Won't turn on.
Battery stopped working several weeks ago, would only work when plugged in. Then just stopped working.  Not receiving any power.
  • 3 more comments
  • ljacobsmcdon Mar 10, 2009
    Will a battery do the trick.  It's not receiving any power at all when plugged in to the power cable.  Hate to spend money on a battery only to find out it still won't work.
  • ljacobsmcdon Mar 11, 2009
    Took it to Best Buy last night, they thought it was the same thing you mentioned.  I left it there so they could back up my files (very expensive). Told me they could send it out for $80 for estimate, but in the end wouldn't be worth fixing.
    I'll take your advise and bring it to a "small private local one".
    Thank you for your help.
  • ljacobsmcdon Mar 12, 2009
    it was $159 to back up files. The $80 was for just an estimate. My daughter needed files right away.  Teenagers, everything is now!
    Will know better in the future. Thanks.
  • ljacobsmcdon Mar 14, 2009
    yes, I'm afraid I did.  But I'd love to find out how. Thanks
  • ljacobsmcdon Mar 15, 2009
    will this usb converter adapter actually power the computer.
    Master:
  • 404 Answers
It means time to buy a new battery..it happens
Posted on Mar 09, 2009
  • 3 more comments
  • lotfi bouakaz
    lotfi bouakaz Mar 10, 2009
    I def think its the power pin "dc socket" its the most common issue
    to find out realy you need another battery "charged" but why dont you take it to a repair shop "small private local one" they diagnose it and
    tell you what is wrong. because this is a hardware issue and its not like you can fix it withour opening the laptop apart.
    go there, tell them you think its the DC socket, also have them test
    your charger "using a volt meter" when they know you know these
    things they wont rip you off or anything
  • lotfi bouakaz
    lotfi bouakaz Mar 11, 2009
    dont ask for file backup simply remove the hard drive because the problem you have has nothing to do with data, $80 is worth it man. but remove the hard drive so the data stays with you when its fixed simply put back the hard drive and use it directly
    here in uk we fix them for £90 which is $190
  • lotfi bouakaz
    lotfi bouakaz Mar 13, 2009
    dont tell me you paid the $160 for backup because you couldve done it yourself for $10 and I could've showed you how
    did you or not???
  • lotfi bouakaz
    lotfi bouakaz Mar 14, 2009
    ah noway! $190 damn you must be a rich guy then. anyway
    you need this as easy as chips to use.
    http://www.amazon.com/Sabrent-USB-DSC5-3...
    $20 it costs, you could have saved $170, and with that $170 could've bought so many things or could've ran your care for 1 month.
  • lotfi bouakaz
    lotfi bouakaz Mar 16, 2009
    no just to get your data backup, it makes your hard drive like a usb pen drive or like a cd or like a floppy disk
Cooling fan stopped working
any 18-20 volt laptop charger should work only need correct power plug and that can be easily changed if necessary with soldering iron and volt meter. using old charger plug as replacement. volt meter is used to check out correct polarity of plug before and after you re solder plug on.generally outside is -ve and center is +ve ,alternatively go to ebay or google and type in Sony Vaio PCG 7Q1M charger,or type in part number ,or try 18-20v laptop charger, that is what I do when I need a replacement charger,cost around $10 delivered usually.
Jan 04, 2014 | Sony Vaio PCG 7Q1M Laptop Universal AC...
I hadn't charged my Sony Vaio model PCG-61611L for a couple days. Then when I finally plugged it in to charge, it won't turn on. I even left it plugged in for a few days and still nothing. It has...
Try A Hard Reset
Remove the battery and charger/ac adapter/power cord from your Sony Vaio laptop, press and hold the power button for 20 seconds to discharge any residual current inside the laptop.
This clears your RAM and is like a hardware reset.
Replace the battery and charger/ac adapter/power cord
and turn your laptop on.
If that does't work try removing ram and reinstall. Sometime this works with these laptops.
Sep 11, 2017 | Sony VAIO VGN-AW330J/H Notebook
HAVE TRIED CHANGE THE CMOS BATTEWHAT CAN I DO NXTRY TO REMOVE BIOS PASSWORD BUT IT COUDNT WORK,?
Sony Vaio PCG and some Vaio VGN Series use the last 7 digits of the laptop serial number to calculate the bios master password. The serial number for a Sony Vaio is often located on the bottom of the laptop on a white sticker. The serial number may also be found by removing the battery and checking in the battery compartment. The link to unlockbiosrecovery.com below works on the following models:
PCG-C, PCG-F, PCG-GR, PCG-GRS, PCG-GRT, PCG-GRV, PCG-GRX, PCG-GRZ, PCG-N, PCG-NV205, PCG-QR, PCG-R, PCG-SR, PCG-SRX, PCG-TR, PCG-V, PCG-VX, PCG-X, PCG-Z, VGN-B, VGN-FS, VGN-S, VGN-T, VGN-TX1, VGN-X
I use http://www.unlockbiosrecovery.com/Unlock_Sony_Bios.php
For $20 they use the last 7 digits of the laptop serial number to calculate the bios master password and then email it to you in an hour. They guarantee it to work and you can call them if you have a question.
Sep 10, 2011 | Sony VAIO VGN-FS640W Notebook
Can you tell me where the cmos battery is located on my sony vaio laptop model PCG-384L; VGN-FZ140E
If it is not where you can see a slot on the side or back, I would bet it's under the keyboard. The Sony support page may have the answer.
http://esupport.sony.com/US/perl/index.pl
Jul 24, 2011 | Sony VAIO® VGN-CR190E/W PC Notebook
I have a Sony Vaio laptop, model PCG-384L. It will not power up. My wife indicated that she push some button that lock the power. Can seem to find the button that controls or locks the power button. ...
Typically that flashing light means low battery. Which makes sense, as you probably have an issue with the AC Adapter that you plug into the computer to charge it, or the DC Jack that this adapter plugs into on the laptop. Either of these things will cause your computer to not charge the battery, and if there isn't enough power it won't turn on.
Aug 10, 2010 | Sony VAIO Notebook
The led with the symbol A in a lock blicks and
I GOT SONY VAIO PCG-384L LAPTOP AND IT KEEP ON CRASHING,
I CANT FIGURE OUR WHAT IS THE PROBLEM?
Feb 12, 2010 | Dell Latitude D600 Notebook
Cmos battery
open the case at back of your notebook you will see the motherboard, look for the battery just a size of a coin, thats the cmos battery and replace it with a new one.
Nov 08, 2009 | Sony VAIO PCG-K23 Notebook
Webcam software for sony vaio laptop ,inbuilt webcam software of the sony vaio laptop VGN Fj 68 GP /w not working I cannot use my webcam because I don´t find an icon to click on. I think I must activate...
Check out the manual on your computer regarding the webcam controls
Sometimes the webcam start procedure can be found under the keyboard heading
Start > Computer >> Local disk (C) >> Documentation >> EN(glish)
Try the Sony Support website for drivers
http://www.kb.sony.com/selfservice/microsites/searchEntry.do?locale=LA_eng_US&usemicrosite=true&region=UMRE_UNITEDSTATES_2_5&sonyregion=US&searchString=webcam%20drivers&product=&sonytemplate=&sonymodel=
May 31, 2009 | Sony VAIO VGN-FJ180P Notebook
Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Dec 20, 2007 | Sony VAIO PCG-K25 Notebook
Computers & Internet Logo
3,790 people viewed this question
David Payne
David Payne
