Question about Linksys BEFW11S4 Wireless-B Broadband Router (12503024)
HP laptop not recognizing Linksys Wireless B Security Key..
I have a Linksys BEFW11S4 Wireless-B router (I know, I know, it's old) that's been working fine for years but when I try to connect my new HP Laptop (Model: dv4-1225dx) running Vista I can only connect to the internet if I disable security. (Note: I have another HP laptop running Vista which has been connected to the same WEP enabled router for the last 2 years....no problem). So, with WEP security enabled (the only type that it offers), it prompts me for my Security Key which I enter but it keeps saying that it's invalid and that I must enter a Security Key that is 5 or 13 characters long...mine is 8 characters long. Do I really need to create a new Security Key in order for this to work or is there something else going on here? I'm certain the Security Key I'm using is correct, verified it by going to my router's set-up page. Any ideas?
  • VinPro Mar 09, 2009
    Unfortunately, my old Linksys Wireless-B router only offers WEP. Although WEP is an option on my new HP laptop running Vista, there does indeed seem to be some compatibility problem in that it won't accept my Security Key. Somehow though, I didn't have this problem with my 2 year old HP laptop running Vista.
    Anyway, as I stated above I did find a temporary work-around, albeit one that many would consider risky, i.e., disabling WEP security. The long term solution, obviously, is to upgrade to a G router....thanks again for trying.
  • 135 Answers
The WEP encryption is consist of 10 characters for 64 bit hex, 128 bit hex is 24 characters and WPA is 8 to 63 characters. So it seems that you have a vista computer? The compatible encryption for vista is WPA, sometime using WEP it is not working properly. So I might advise you to access the configuration of your router (192.168.1.1) and change the wireless settings of your router to WPA-Personal.
Posted on Mar 09, 2009
  • Michael Badajos
    Michael Badajos Mar 10, 2009
    Oh I see, yah that's right I though that was a new computer. thanks for voting.
How do i get a security code so others cant use my internert
type 192.168.1.1 into your browser and hit enter. This will take you to your router page.
If you have never been to this page before this is a list of defualt passwords to enter your page.
Linksys BEFW11S4, WRT54G: admin
Linksys EtherFast Cable/DSL Ethernet routers: Administrator
Linksys Comcast routers: comcast
All other Linksys routers: [none]
Default passwords: Linksys BEFW11S4: [none]
Linksys Comcast routers: 1234
All other Linksys routers: admin
From here you can set your own wireless security mode and generate a passphrase or key to lock out intruders.
Hope this helps...Good luck
If I have helped you resolve your problem, please
consider giving me a good rating and a quick
thanks or good job.It will help me as well Thank
you.
Oct 23, 2010 | Linksys Wireless-G WRT54G Router
How do i make a password on my wifi conection..my router is linksys BEFW11S4 v.2
First, your router is old, go pickup a new one that supports the G standard, don't worry it will fall back to B standard or better yet get an N standard router. To setup wireless security directly connect a pc via cat5 data cable to one of the switch ports on the router (not the wan) and login to the web innerface, click the wireless tab, now look for the security or encrypted options. Most routers support WPA-2 encryption where you enter a phrase of 2 or 3 words if your router only supports web encryption go buy a new router. Save it, then go to your pc, disconnect, remove the wifi ssid from your managed wireless list refresh and search for the ssid of your wireless signal (name), now connect and the router should challenge you for your WPA pass phrase you setup in the router. Now your wifi ssid is secure and all connections will require the passphrase.
Aug 28, 2010 | Linksys BEFW11S4 802.11b Wireless...
I have a new laptop and am unable to access wireless with the linksys router ( it worked on my old pc, before it died) The infor on my router reads: linksys wrt100 range plus wireless router
Check if the wireless security is ON. If yes, then you will need to know the wireless network key.
To check the settings on the router on a connected computer, use a web browser and in the address bar type: 192.168.1.1.
By default leave the username blank, then the password is admin.
Go to Wireless, take note of the SSID.
Then go to Wireless security, copy the pre-shared key/ wireless network key.
On your new laptop, view the available networks, you should see your SSID. It will prompt you to enter the network key, just type the wireless network key.
I hope this helps!
Mar 23, 2010 | Linksys WRT160N Wireless Router
I have a new hp lap top with windows 7 it is recognizing my linksys router but saying no internet connection available, i have two other laptops that have no problem connecting
You have befw11s4 router, which is very old router.
May be you will need to upgrade the firmware of the router.
change the channel to 6.
check the wireless security settings.
Make sure that the wireless MAC filter is disabled.
For this you will need to access the router set up page.
make sure that the computer is connected to the router with the cable when you open the router set up.
Click here for mode info about routers and wireless network
Jan 08, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
Linksys BEFW11s4 Wireless Router Security Issues
Try changing the router's channel (play around with 1, 6 and 11) and see if it works.
Jun 28, 2009 | Linksys BEFW11S4 802.11b Wireless...
My password is "wrong' whenever I try to connect on my laptop
That's firmware problem on your router. Try to download the latest firmware for you router from www.linksys.com/download then load the latest firmware. After successfully updated the firmware, you need to hard reset the router by pressing the reset button for 20 seconds then unplug the power for 10 seconds and plug it back in. You will need to reconfigure the wireless settings.
Apr 15, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Wireless connection
RESET YOUR ROUTER TO FACTORY. START WITH BASIC CONNECTION ON BOTH UNITS THEN GET MORE ELABORATE WITH SECURITY.
Mar 08, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Linksys BEFW11S4-RM 4 port wireless router
This is an old router. Look at the power light. You must have a STEADY power light. RESET the BEFW11s4 by pushing the reset button for 30seconds. Unplug the power of the BEFW11s4 for 30 seconds. Connect pc to port 2 or 3. pc should get an ip of 192.168.1.x. If you are getting this ip that means that the pc is already detecting the router.
Good Day
Mar 06, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys Wireless-B Router, Model BEFW11S4
It's really easy to find your wep key if you can log into the router page.  Usually the router is defaulted to 192.168.0.1 or 192.168.1.1
You put that number after the http:// in a web browser and it should ask you for a username and password.  Either enter the username and password you set it up for, or if you didn't set one it's probably admin admin.  Now there should be a page with a bunch of settings.  Near the top click on the tab that say wireless, and under that tab there should be something called security.  The WEP key you have set up should be in here.  The WEP key is not the passcode, just wanted to point that out.  It's most likely under something by the name of key 1 or something to that affect.  That should take care of your WEP key problem.  I would personally recommend upgrading to a wireless G router if the other devices on your network can use G.  Wireless G is much faster and also allows the use of wireless B devices on it.  Hope I helped.  If you need more help just ask, I might be able to get some screenshots up or direct you to a manual.
Oct 17, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
198 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
