Question about Watches
I ordered Armitron watch #45/6917 BLK from Amazon, and no user manual came with it. I want to have the watch chime every hour, the main reason I bought this watch.
  • 2,334 Answers
Follow this link and find instructions for your watch:
http://www.armitron.com/watch_instructions.asp
Do not forget to rate, please.
Posted on Mar 09, 2009
How to set the hourly chime on the Armitron 165 45/7042?
The manual for the 45/7042 is elusive. Like the Unicorn and Bigfoot, people can tell you what it looks like, but they have never seen it. To turn on/off the hourly chime, press and hold the top left button (you should see the alarm). While holding down the top left button, pressing the bottom left button should turn the hourly chime on/off. This appears to be indicated by the days of the week turning on/off.
Apr 12, 2016 | Armitron Watches
I cannot set the time on a wr165
here's a simple instructions of setting your watch
Watch setup instructions
for the Armitron Instalite All-Sport :
Mode B / \ C Date
Light A \ / D Alarm
_____________________________________
Set time time / date
Press and hold B (Mode) untill alarm hours flash
Press D (Alarm) to advance these
Press B (Mode) again, seconds will flash,
press D (Alarm) to advance these
Press C (Date), minutes flash, press D to advance these
Press C again, hours flash, press D to advance these
Press C again, month flashes, press D to advance these
Press C again, Date flashes, press D to advance these
Press C again, Date flashes, press D to advance...... [suggestion from Chikita]]
Activating/Deactivating Hourly Chime
1. From "Normal Time Mode", press and hold "D" (Alarm) and
at the same time press "C" (Date) once. Hourly chime symbol,
( a house shape) appears in "chime" windows to indicate
the hourly chime will beep every hour.
Activatin/Deactivating Alarm
2. With "D" (Alarm) still pressed, press "C" (Date) again. Alarm symbol
( a clock shape with waves above it) appears in the
upper right to indicate the 24 hour alarm is now activated.
[I assume this "toggles" between off and on states,
so performing it again should turn off the alarm]
i hope this will help you.
Jul 22, 2011 | Armitron All Sport Digital watch
How to set the alarm
These are the instructions posted on the Armitron website. I hope they help.
1. From Time Telling Mode, press 'B' twice to enter the
Alarm Mode.
2. Press 'A'. Alarm Hours flash. Press 'C' to advance the
Alarm Hour.
3. Press 'B'. Alarm Minutes flash. Press 'C' to advance the
Alarm Minute.
4. Press 'B'. Alarm Time Zone flashes. Press 'C' to select
either Time Zone 1 or Time Zone 2.
NOTE: The Alarm is available in one Time Zone only.
5. Press 'A' to end set sequence.
6. Press 'B' to return to Time Telling Mode.
ACTIVATING THE ALARM AND HOURLY CHIME
1. While in Alarm Mode, press 'C' to activate the Alarm.
The Alarm symbol appears to indicate the Alarm will
sound at the preset Alarm Time for 20 seconds or until
'A', 'B' or 'C' is pressed.
2. Press 'C' again to activate the Hourly Chime.
"CHIME" appears to indicate the Hourly Chime will sound
every hour on the hour.
3. Press 'C' again to deactivate the Alarm.
4. Press 'C' again to deactivate the Hourly Chime.
5. Press 'B' to return to Time Telling Mode.
Apr 12, 2011 | Armitron Digital Sport #40/8095SIL Watch
How do I turn off the alarm on my Armitron watch?
I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
Nik.
http://home.earthlink.net/~eldonenew/armitron.htm
or
http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
Other People Are Reading
Setting Date, Time and Alarm
  • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
  • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
  • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Jul 20, 2010 | Armitron Round Digital Sport 408089 Watch
Setting Armitron Watch model WR330
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ARMITRON watch manuals. Rate me, please.
Mar 14, 2010 | Watches
How to change time
You can get a set of instructions from the Amitron web site (www.armitron.com/watch_instructions.asp).
You will see a list of watch diagrams, choose the one that looks like yours and download the PDF.
Jan 31, 2010 | Armitron Instalite Calendar Date/Day with...
Armitron Pro Sport Watch Hourly Chime
Based on insructions for another watch, I just figured this one out. The steps would be:
Get in Alarm mode (press mode button)
Then you can cycle through the following by pressing the ST/STP button
1. Alarm on
2. Chiime on
3. Alarm and Chime on
4. Alarm and Chime off
You can see this with a magnifying glass and watch the center and right hand circular icons at the top of the display.get highlighted.
Dec 26, 2008 | JCPenney Armitron Sport Link Bracelet...
Ladies Armitron 45/6967
Armitron alarm/chrono
1.To set the time hold the mode button until the alarm flashes, then hit it one more time and the time will flash to be changed. Once the alram or time is flashing use the ST/STP button to navigate between hour, minute, month, day and day of the week, the ADJ button changes the numbers.
2.While holding down the ADJ button use the ST/STP button to turn off the hourly CHIME and the ALARM chime.
Hope this helps!! K~~
Sep 27, 2008 | JCPenney Armitron Sport Link Bracelet...
Watches Logo
445 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
