Question about Fisher and Paykel 24 in. DS-603 Built-in Dishwasher
Beeping fault code Fisher and Paykel DS603
Yesterday the DS603 starting beeping and wouldn't stop. The fault code was on rinse.....We unplugged the machine and then tried it again, same thing. We then left it unplugged overnight. This morning I tried it again and it went through the wash cycle just fine...ran for well over 45 minutes then started beeping again, it appeared to be in the dry cycle as the dishes were almost completely dry. I tried it again, same thing ran for about 40 minutes and then started beeping again. Now it's unplugged again and would love to know how to stop the beeping. any help would be appreciated. Thank you
  • 144 Answers
Stop the unit and check to see if it's heating when it's beeping at you. eg is it warm water inside at the time? if not you may have a faulty element.
Posted on Mar 24, 2009
2 Suggested Answers
  • 784 Answers
SOURCE: Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
Posted on Sep 09, 2009
My Fisher Paykel washing machine won't spin it's goes to rinse then stops. The wash light and the last rinse light comes on also spin light comes on and it's beeping
Ian,
Which wash light? There are a total of 8 lights in the sequence on the panel. From left to right, can you give me the numbers of the lights that are on. I have a Fisher Paykel fault code manual, so I can look it up if you give me the lights that are lit and also give me the model of your machine, some of the codes are different for different models.
Aug 13, 2015 | Fisher Washing Machines
After starting briefly, why did it suddenly stop?
I know it is an old post but this will help the fault code lights 1 and 7
130. (10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
The Motor Control Module has found an error in the pattern received
from the Rotor Position Sensor. Likely causes of this fault are a bad
connection on the harness between the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Watch this video if you are good with fixing things
Fisher and Paykel 130 10000010 Error Code Fix
Jun 06, 2015 | Fisher and Paykel Washing Machines
The top dishwasher of my Fisher&paykel Paykel DDd603 &DS603 model ontinuallly beeps. I tried unplugging the power for several hours and it still beeps. Any recommendations ??
Assuming the bottom dishdrawer is working ok, it is likely the controller on the top drawer is either faulty or sensing some incorrect signal. If pressing any of the panel buttons makes no difference, then most likely the controller is faulty.
By the way I am unclear why you mention two models in your problem description. DD603 is a double drawer dishwasher and DS603 is a single drawer unit.
Apr 10, 2013 | Fisher and Paykel Dishwashers
Fisher & Paykel Ecosmart will Wash but not Rinse/Spin
You have too many clothes in the washer. Take some out and try again
Sep 09, 2009 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel 24 in. DS-603 Built-in Dishwasher Logo
1,482 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
