Question about Ingersoll Rand DD2T2 T Win Stack Single Stage Compressor
Ingersoll rand compressor oil leak (Model DD2T2, 4.5 Gal.)
Oil leak is directly below the oil fill port. Where is the drain plug. Could it be leaking? (Model DD2T2, 4.5 Gal.dual tank)
The brass fitting that goes into my DD2T2 seems to have a hole in it and it looks impossible to remove without ruining a major gasket due to the close tolerance in replacing the fitting. Am I missing something?
Posted on Sep 15, 2009
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
I did not drain the tank on my 80 gal comp now trying to drain I only get a trickle out of the drain line. Help
Take drain plug completely out of bottom of the tank and remove the outlet plug on the side of tank. pour 1 gallon of clean water into tank and stir up sediment. . Replace the side plug and start compressor , keep this up until drain water runs clear not orange. Then re install everything and check tank pressure and for leaks.
Apr 15, 2013 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
I have an old type 30 model ingersoll rand air compressor. It has not run for years, we just wired it up and ran it for about 5 minutes. After that, I thought I better check the oil level... There does...
Alot of the older units did not have a sight glass. They had a dip stick on the fill plug. Over the years they broke off or the oil fill plug was replaced with a newer type that does not have the dip stick. To answer your question dip stick or not I always fill with oil to the bottom of the threads on the fill plug. You should remove the plug and check the oil level before each use on and older unit like this until you have a good handle on how much oil it uses. you may also be able to remove a plug usually on the front of the case lower left side and install a sight glass or low oil level switch. Have a good day!!
Nov 12, 2011 | Ingersoll Rand - Rand Type - 30...
Yeah if no visible leaks your compressor rings are worn an will need to be rebuilt. Check around for rebuild kit and maint cost. May be just as cheak to buy another one, you can get deals on ebay and craig's list. Good luck..Google the model# you may find parts..
May 14, 2011 | Ingersoll Rand UP6-30-125 120 Gallon...
Where can I get an oil fill drain plug for ingersoll rand compressor 2340L5-V?
There are alot of resources to obtain this. I would search the net or you can contact ingersoll. the 800 # on the unit would be a good place to start.
Jan 29, 2011 | Ingersoll Rand - Rand Type - 30...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
I have a ingersoll rand air compressor rand 4000 60 gl vertical 230v model #ra5e6va serial #dc90177-0025 i am wanting to know what cylinder head torqe is for the compressor.the head gasket leaks oil and...
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Oct 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
The oil fill plug broke on my Ingersoll Rand R 242-5n
Remove it and try a NAPA auto parts store. If they can't help I'd try Graingers.
Aug 30, 2009 | Ingersoll Rand Compressors 5-HP,...
What is the amt of oil ingersoll-rand 242-5n air compressor need
I don't have the manual for your compressor, but if you drain the oil and then measure the volume of the drained oil, it should be about the same.
If you are wondering about the quantity of oil to purchase, 2 quarts should be more than enough.
Apr 08, 2009 | Ingersoll Rand Compressors 5-HP,...
Ingersoll Rand DD2T2 T Win Stack Single Stage Compressor Logo
500 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
