Question about Microsoft Windows 98 for PC
I have win98se O.S. When I try to open Windows Media Player I get 'application error has occured' It appears some registry files are erased. How do I get these files as I do not have backup CD?
You can try uninstalling and then reinstalling Windows Media Player from Control Panel/Add Remove Programs.
Posted on Mar 11, 2009
Hp pavilion a1102n winxp home. Blue screen after win splash logo, flashes too fast to read. 2x256mb. Dial up modem. Tried: removing modem, removing front usb FireWire media card slots. Removing one or...
Dear,
I saw your video and check the blue screen error. It comes for a friction of second and disappears but i kept my media player in slow motion mode and checked it. This error belongs to a missing registry file.
PERFORM THIS PROCEDURE for recovery.
A Stop 0xc0000218 error message means that a necessary registry hive file could not be loaded. This error message can occur if the file is corrupt or missing. To resolve this issue, you can reinstall the operating system and restore the registry files from a backup. The registry files may have been corrupted because of hard disk corruption or some other hardware problem.
This error message can also occur if the driver has corrupted the registry data while loading into memory, or the memory where the registry is loading has a parity error. In the latter case, turn off the external cache and check the memory chips.
To resolve this issue, follow these steps:
  1. Start your computer by running the Recovery Console, run the chkdsk /p command on the drive, and then restart your computer. Test to determine whether the issue is resolved. If the issue is resolved, do not complete the remaining steps. If the issue is not resolved, go to step 2.
  2. When Windows loads, press SPACE BAR when the "Load Last Known Good" message appears.
  3. Complete a parallel installation, and restore the registry files from a tape backup. To do so:
    • Reinstall Windows in a separate folder.
    • Restore the damaged registry hive from backup. This procedure is specific to the backup application that you used to make a backup. Consult the documentation of your backup application or consult the vendor if you need assistance. Typically, this procedure requires you to restore a system state backup to an alternate location, and then copy the appropriate registry files to the %SYSTEMROOT%\System32\config folder of the damaged operating system.
    • If you do not have a tape backup, include the backup of network servers and production workstations.
    NOTE: If Windows is stored on a FAT partition, you can restore the files by using another computer and by copying the registry hive files to the %SYSTEMROOT%\System32\Config subfolder.
best of luck!
Mar 07, 2012 | HP Computers & Internet
Tip
How To Get Help Soving Problems With Windows 7 Easily
There's One Cool Feature in Windows 7 that's not available in it's predecessors, which is called "Problem Steps Recorder".
This "Hidden" tool, can help you record the steps you took in which leads to the problem occurring.
To access the Problem Steps Recorder in Windows 7, you should follow the steps below:
1. Click on your Start Menu Button in the Lower Left Hand Corner,
2. Next in the "Run" Box, type in "psr" (Without the Quotes), to which you should see something like in the below image
3. Next, Double Click on the found file "psr" and you should see the following program appear on your desktop:
4. To Start Recreating What You Did When Your Problem Occurred, First, Click On The "Record" Button.
5. Now, Just Navigate To The File/Folder or Application To Which You Are Experiencing Problems With. (This Can Be Accomplished The Same Way in Which You Normally Open/Access Files/Folders & Applications).
6. Once You Have Got To The File/Folder or Application That Was Giving You An Error Message When Opening The File/Folder or Application & The Error Message Can Be Seen On Your Desktop, Then You Can Press "Stop" On The "psr" Application.
7. You Shall Then Be Prompted To Create A Name For Your "psr" Report, Which You Should Name Accordingly To The Problem You Have Recorded. IE: If You Were Having A Problem With Windows Media Player, Then Name The File "Windows Media Player Error Message Report". This File Will Then Be Saved in ZIP Format in a Location That You Chose To Save It. (Probably Best To Create A Folder On Your Desktop Called "Problem Steps Recorder Reports) or (PSR Reports).
8. Now, When The ZIP File is Extracted, It Will Contain A Single HTML Page Containing The Steps You Took (With Colour Pictures That Can Be Clicked On To View The Full Size Image). This Can Then Be Emailed or Recorded To A USB Flash Drive or Floppy Disk, & Examined By Someone With Experience Of Troubleshooting Windows Software / Hardware Errors Easily.
9. An Extra Tip So That You Don't Have To Keep Searching For The "psr" File Would Be To Right Click On The "psr" File After Running A Search For it As Described in "Step 2" & Then Clicking On The "Pin To Taskbar " or "Pin To Start Menu" Options, So That The "psr" Tool Will Always Located on Your Windows Taskbar, and/or in Your Windows Start Menu.
on Jul 15, 2010 | Computers & Internet
Error code 0x00000002
STOP 0x2 DEVICE_QUEUE_NOT_BUSY error code has a value that is 0x00000002. This is a fatal error typically known as STOP message or Blue Screen of Death (BSOD).
This error generally occurs in Windows XP but may also occur in latest version of Windows such as Windows Vista or windows 7. The computer may stop responding without warning. Moreover, your computer may give error messages like STOP 0x00000002 error or related errors and if blue screen appeared then you may have to restart the system in the mean time of your work due to which unsaved work will be lost.
Cause of Error:
  • You may be using corrupted profile in your system which raised this problem
  • The device driver of your system is not updated
  • Malfunction of hardware usually is the cause of error such as STOP 0x2 DEVICE_QUEUE_NOT_BUSY or similar error
  • Registry database of your system may have corrupted or modified erroneously by invalid application
  • You have installed new hardware unsystematic or installed unknown application
  • Spyware has infected the PC
  • Antivirus software is not working
  • The operating system or application might have run out of usable memory.
This is one of the serious problem in computer if it is not resolved instantly then it might create some more unexpected error. STOP 0x00000002 error and its related error will disturb you all the time and you may have to bear loss of data. When blue screen of death appear on your monitor screen then you need to restart directly whether you have saved your work or not. Therefore, you are suggested to fix STOP 0x00000002 error as earliest possible.
How to Fix:
To fix STOP 0x00000002 error you need to follow the following methods.
  • If this error occurs in your pc then you will have to restart the PC and then press F8 key before appearing Windows. You will see a black screen with white text giving many options. Select the option "Last Known Good Configuration" and press Enter. If you have configured the computer improperly then it may fix the error.
  • If you have installed any hardware in your system then the chances is more that the device driver is not updated and thus errors of type STOP are given at the time of operation. You must download latest drivers.
  • If your system does not become stable then you need to try scanning of registry with this tool. Since, registry keeps all configurations of your system if it gets impaired then you must download registry repairing softwareand repair it .
Mostly, spyware has been the reason of various errors in computer system. Spyware damages files in the computer system and if once damaged then it is no longer used and it also corrupt registry database. The file which is infected by virus may be a program file, system file etc. If STOP 0x00000002 error occur in spite of antivirus then download anti spyware to scan your computer.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 28, 2011 | Microsoft Computers & Internet
Youtube video not play
This is the mismatch of video format,
you can download a video converter, this kind software
can convert all kinds of video files to which you want.
as to youtube video files,you can download a
aneesoft youtube video converter.
Jul 20, 2010 | YouTube Videos
New computer dell inspiron 570 running windows 7-connected for 3 days. came back to use it this afternoon and the media player has lost it's sound and you can hardly hear the PC -the system tells me =media...
Microsoft Windows Media Player is a free media player software that comes with the personal computer version of Windows operating systems. The software supports basic file formats such as WMV, WMA, AVI, MP3, and ASF. The player included in Windows XP gives you the power to create your own CDs, search and organize digital media on your PC, and copy files to portable devices such as CDs and pen drives.
Fix Windows Media Player Problems
Corrupted and missing DLLs files, incorrect registry entries, and outdated files are some of the causes of Windows Media Player errors. Covered here are a few steps that you can take to fix common problems.
C00D11CD: Unknown Error
C00D11CD errors occur when an operating system component or some other program encounters an error and does not communicate it to Windows Media Player. Due to its generic nature and multiple reasons for occurrence, there is no specific solution to this problem.
If you encounter the error when trying to play an AVI or MPEG 2 file, then most likely, you do not have the correct codec version installed on your system. To fix a Windows Media Player problem related to codec, search for the required codec on the Internet, download it, and update it on your system to play the required file.
Windows Media Player uses Digital Rights Management (DRM) to authorize copying files to a CD or to download them from an online music store. If you do not have DRM authority to copy a particular song, you will not be able to play it and the error will pop up.
Windows Media Player uses the wmadmoe.dll file to encode files. If something goes wrong with this file, you may get the c00d11cd error when you try to copy songs from a CD to your hard disk. To fix a Windows Media Player problem in this situation, you must register the DLL file by running the command ‘regsvr32 wmadmoe.dll’.
80040155: Interface Not Registered
If this error occurs when you try to burn songs into a CD, then the most probable cause is that the required player files are no longer registered on your system. To fix this error, try to reinstall your Windows Media Player or download and install a newer version of the player, if available on the internet.
800C2EE2: Action timed out
This error occurs when your Windows Media Player is unable to connect to a server due to problem in the network, and therefore cannot play protected audio/video files that you download from an online music store. Incorrect Internet Explorer security settings might be the cause of this problem. To fix this, open Internet Explorer and select Tools-Internet Options-LAN Settings. Next, clear the Automatically detect settings check box.
C00D0FAA: Cannot rip the files
The error usually occurs when you try to rip CDs to MP3 format. Existence of entries from an earlier player version in the registry might be the reason behind this problem. One way to fix this problem is by adjusting the audio quality. However, if you want to maintain the audio quality, then to fix this Windows Media Player problem, open the Registry Editor by running the Regedit command and navigate to the subkey given below.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MediaPlayer\Sett ings\MP3Encoding
Here, open ‘LowrateSample’ and delete the value displayed in the Value Data box. Select OK and exit Registry Editor.
Many times errors also occur when there are corrupt files on the system or there are invalid DLL entries and other related incorrect entries in the system registry. For this, you must try to download reliable registry cleaner software from the Internet and scan your registry for invalid entries. Using registry cleaner software, you can easily and efficiently fix Windows registry problems, and make your PC free from irritating errors.
Errors can occur in Windows Media Player due to outdated files, missing or corrupt DLL files and incorrect registry entries. Most of the time, you can fix Windows Media Player problems by updating missing files or by upgrading the player to a later version. Additionally, to prevent registry-related problems, you can use a registry cleaner software to regularly scan the registry and eliminate invalid DLL entries and corrupt values from it.
Mar 06, 2010 | Computers & Internet
I cant open windows media player a message pop up
you need to reinstall windows media player using the windows disc... also, you can try to use the windows repair feature.. just boot with your windows CD and pick repair my copy of windows..
Jul 09, 2009 | MSI MS-6340 Motherboard
JNC SSF-F310PNK Mp3
The song format is most likely wrong:
read my "Tips and Tricks" on Song formats for Mp3 players: too long to repost here
Song Formats for Mp3 Players Explained
By Tha Mp3 Doctor
I have seen quite a few threads around Fixya in which the stated problem is that the Mp3 or Digital Audio Player will not load the songs; will appear to load the songs but will not actually play them in the Mp3 player once disconnected from computer; will skip the songs on the player, or show only “0:00” for file length; songs “disappear” all of a sudden (although this particular problem can be caused for many reasons not covered in this article); your store-bought/burned/ripped CD’s will not load into your Mp3 player; or get the error message “File Format Not Supported.” All of these problems occur because the user is trying to download a song format that the player does not recognize. Every music file is in a certain format. The most common music file formats are Mp3, WMA, AAC, WAV, RA, etc. Each Mp3 player only recognizes a certain number of these formats. Every Mp3 Player is different. You will have to check your Mp3 player’s product specifications (specs) or user’s manual to find out which formats your particular Mp3 player recognizes. When you try to download or sync the wrong file format, you will get one of the errors that I mentioned above.
Or, it could be a "formatting" issue:
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jun 10, 2008 | JNC Computers SSF-310 MP3 Player
A problem occured using m y mp3 player
Deleting files through Format:
1. Formatting the player erases all files in the player, and oftentimes this is the best option to ensure that all files are removed and any corruption eliminated. Also, it is best to format the player when in MSC mode.
2. When the appears as a drive letter (under MSC mode), right-click on that drive letter and select "Format". On the "Format" pop-up window, click "Start" to begin the format process.
3. Follow the on-screen prompts and safely remove the player from your PC when the "Format Complete" display appears.
4. Unplug the player from the PC and when the player is powered up, the message "No Files" should appear on the player's LCD screen
5. Switch the mode back to "MTP", or continue to use "MSC". Note: It is best to use "MTP" when you are transferring subscription music to the player
***Or you can use windows media player to format your player....
Open up your windows media player and click on the sync tab..assuming that you have windows media player 11...right click on the device and hit format..if you have windows media player there should be a little pen or pencil on the right side..just click on it and hit format..
I hope this helps. :)
Please rate accordingly...
Jan 26, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
SHIFT3 INNOVAGE MP3 PLAYER
-Tha Mp3 Doctor
Jan 07, 2008 | iLO (2 GB) MP3 Player
Microsoft Windows 98 for PC Logo
85 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
