Question about LG Microwave Ovens
Where do I get a plate for LG Intelowave MG6045N microwave in Bethlehem/Reitz (FS)
How to change fuse for lg lrm1250W
Hello
Get beneath the LG microwave, and grasp it on the bottom at either end. Lift the microwave up slightly, and pull it out from the wall to remove it from the mounting plate.
Turn the microwave onto its face on a soft rug or blanket. Remove the screws from the back panel of the microwave, and slide the panel upward to take it off the unit.
Look for the three fuses in the LG microwave -- one at the lower-right corner, one in the upper-right corner and one in the top center. Check each of the fuses to see if any of them look dark in color; this indicates a burned-out fuse.
Remove the burned-out fuse by gripping it firmly and pulling it away from the wall of the microwave. Once the fuse is removed, press the new fuse into the same position in the microwave until it clicks into place.
Slide the back panel onto the microwave, and replace the screws. Lift the microwave into the space beneath the cabinet from which it was removed, holding it slightly higher than the mounting plate, and lower the microwave until it catches on the mounting plate.
Oct 05, 2011 | LG LRM1250 Microwave Oven
My microwave turntable has stopped turning. Has this been an issue with other LG microwaves? My microwave is just over a year old. Please advise. Thank you. Nancy Pappas
It is only an issue with all manufacturers when the plate is turned when checking the food as it will strip the plastic teeth is the tiny gear box.
The motors are fairly inexpensive to replace.
Feb 24, 2011 | LG Microwave Ovens
A lot of buttons on the touch control panel dont work. How do I open the front plate?
The front touch plate is a thin membrane which sticks on to the front panel of the microwave. You can not get into it. It has to be replaced as a unit.
Oct 16, 2010 | LG LMVM1935 Convection/Microwave Oven
I need a plate for my lg intellowave microwave oven where can i purchase this and how much
possibly ebay. But you need to know what size the plate is. I'm trying to figure that out myself - I can't find a model number only "intellowave" and one touch control
Aug 30, 2009 | LG Microwave Ovens
LG microwave LMA1560SB will turn without the glass plate, but not with weight on the plate.
The motor that spins the plate is weakening and will eventually have to be replaced. You can get one fro repairclinic.com or other sites fairly cheap.
Jun 22, 2009 | LG 1.5 Cu. Ft. Full-Size Microwave - Black
Microwave doesn't work
There is a reset somewhere around the top or close to heating element
Mar 12, 2009 | LG Over-the-Range Microwave
Start buttom doesn't work
Okay, it does sound like your membrane keypad is worn out at the Start pad.
It may be available separately as a key sheet or already attached to a new plastic frame.
In case it comes as a key sheet and if you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
LG's Latin American Wen sites are here.
Dec 16, 2008 | LG LRM1250 Microwave Oven
Microwave Ovens Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
