I hooked up a new hard drive to my old monitor and I can't hear the sound - just slightly. The vol is up to 100% on my keyboard and screen. Where would I find settings to correct this? I am not sure where to look.
Thanks!
Sorry - new at this. My computer is a HP a6750y PC and the monitor is my old one. The speakers have a line to the "out" plug in on the pc - no wall plug or usb cord. I have reinstalled the driver with no success.
ThanksSorry - new at this. My computer is a HP a6750y PC and the monitor is my old one. The speakers have a line to the "out" plug in on the pc - no wall plug or usb cord. I have reinstalled the driver with no success.
Thanks
Thanks - I thought it might be that too. Same with my printer - I can no longer fax from it due to no telephone jack in the PC.
Thanks again!Thanks - I thought it might be that too. Same with my printer - I can no longer fax from it due to no telephone jack in the PC.
Thanks again!
If you had a new hard driver installed into you computer you may have to reinstall the sound and driver software in the computer. You didn't state what Compaq or HP computer you are using? Did the monitor come with this computer ?If you had a new hard driver installed into you computer you may have to reinstall the sound and driver software in the computer. You didn't state what Compaq or HP computer you are using? Did the monitor come with this computer ?
You can't post conmments that contain an email address.
I was afraid of that. The speaker system is only half in the monitor the other part(Amplifier section) was in your old computer. Here is a possible solution. Buy an external sound /speaker system. The amplifier comes with it and many can be had at a reasonable cost at **** places as Walmart , target ,etc. Sorry. but the speakers on
your monitor, I believe , will not work with you new computer. Sorry.
Check the settings of the monitor for audio volume. Also check the individual volume control setting for the applications and system sounds. Or call ViewSonic technical support for assistance.
If the product is under 12 months old please return to your retailer with proof of purchase for them to assist under the terms and conditions of the warranty. Without being able to inspect the product it is impossible to diagnose the problem.
Did you look at the PC CONTROL PANEL/SOUNDS and AUDIO DEVICES PROPERTIES/VOLUME/ADVANCE? Look at each controls: Master Volume and the Wave setting to see if it is set to very low positions.
Monitor volume is affected by TWO volume controls (or even three...) 1: Volume on the monitor can be set to 80% 2: Main Volume on the COMPUTER can be set to your liking. 3: Wave volume on the computer mixer settings should be set for 80% (See Sound on your control panel or right click your volume control near the clock)
If all these are right and the volume is still low, check that the audio is not set for surround 5 or 7 channel and the monitor audio connector is plugged into the REAR green connection on the computer.
Still problems, the audio driver in the monitor is shot.
if you can hear the one beep sound when booting that means your laptop's system is in good condition. try putting it in the external monitor if still you cant see anything both in external and the LCD just install the old keyboard and press the Fn then external monitor... hope this helps...
Thanks
Thanks again!
