Question about HP Photosmart M537 Digital Camera
On my HP 537 camara my daughter dropped it now the switch that makes the camara go to view pictures or take movies will not work, it just slides back and forth? Is there a way I can open it and fix the switch?
  • pastormatt Mar 26, 2009
    I have an M537 with a mode switch that justs slides too. Can it be fixed?
If you can take things apart without damaging things...then it may be possible to fix. I have had mine apart several times, and the slider on the outside, switches a mini micro slider inside. It has to be lined up with the tabs...dropping it may have caused it to jump the slots.
Posted on Apr 29, 2009
My camara casio digital exilim ex-s8 the card is locked...how do i doing unlock? thanks
Take a look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Dec 23, 2010 | HP Cameras
Why my camara reads card protected.,,,i pearches a memory card and the camara doent work
Nov 26, 2010 | Polaroid a550 Digital Camera
Will not recognise sd card
Is the SD slide protection switch unlocked? You will also need to format the memory card before it will work in your digital camara. Make sure the memory is compatible with your camara (too much memory and it won't work)
Nov 09, 2009 | HP PhotoSmart M627 Digital Camera
My Nikon oolpix 5600 will not allow me to format my cards or take pictures. It displays "memory card is write protected". I know my daughter dropped it but everything else is working properly.
Oct 31, 2009 | Nikon Coolpix 5600 Digital Camera
Cannot see what im shooting and on lcd screen,no picture jus black. It shows numbers timer everything else except picture. In play mode everything works fine.
I have 2 xelim camaras. One of which has a piece of some type of cover partially obstructing the view. This camara still displays the time and menus and older pictures. If I take pix now the picture is obscured. The other camara has no picture on the display but when I take a picture it turns out just fine. That camara will need disassembled and a connector hooked back up
Most screens on digital camaras are for aiming the camara and output (displaying the picture) therefore any problems with the screen do not translate to a picture.
Oct 23, 2009 | Canon ZR85 Mini DV Digital Camcorder
Digital camara and memory card
Basically picture files in memory card have corrupt data that's why computer doesn't recognize it.
HP recommends following action...
Close the HP Image Zone or HP Photosmart Software, disconnect the camera from the computer, and reset the camera. (can see this at HP Support)
2nd option is to find some memory card data recovery software on internet and use it to correct data files in memory card.
Thank you.
Oct 03, 2008 | HP Cameras
I have a technika View box sp-108 which alows you to view your ipod videos etc on the 7" screen. it also doubles up as digital picture frame allowing you to load mp3 video and jpeg photos from flash...
Make sure you don't have to many folders or sub folders, best to keep it simple.
Wipe the card and format it as "FAT" not "FAT32" just right click your usb or SD card in vista or XP and select format.
Drop your MP3 album onto the card, If you use your USB Stick and SD card at the same time then it will default to SD and not play from both.
I found it would not read from one card unless I had a playlist, so I used a free program called Playlist creator 3 - get it here (only relates to MP3's)
http://www.soft32.com/download_66536.html
I dropped and xvid movie onto the SD card and it played fine, just make sure you are in the correct menu 1st! and the movie isn't in some very old format as it may not play all codecs (encoding used to make movie)
Hope this helps
Sep 22, 2008 | Audio Players & Recorders
Button
perhaps it is in movie mode ? switch the camera to "auto" and take a picture with the same button used to start video recording
May 12, 2008 | Canon PowerShot A520 Digital Camera
A345 stuck in movie mode
you need to open the camera caseing a small amount. As you put the case back make sure the switch is in the movie position so it will engage the switch inside on the circuit board. Looks like the switch has been knocked off the control inside.If you have been moveing the switch back and forward you may have broken it.
Dec 27, 2006 | Fuji FinePix A345 Digital Camera
Black screen when camara is in photo mode
anyone else had this? or know what to do. whatever best you can do is to take the camera to a good repairer as you can't fix the problem by yourself. there may be two possible reasons for the problem. 1) bad image sensor i.e. damaged CCD or 2)shutter blade are not working. the shutter blades may be jammed due to friction are no signal.
Jun 24, 2006 | Fuji FinePix S304 Digital Camera
HP Photosmart M537 Digital Camera Logo
156 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
