Question about Hotpoint 24 in. HDA900X Built-in Dishwasher
Motor will not start
Hotpoint HDA 900x....Water starts process, but motor will not start. Had this problem before, repair tech stated if dishwasher not used often a reset switch had to be reset? Where is this swith located?
  • antonedfd Mar 09, 2009
    Ok, I've located the motor. Unable to find reset button....in front/back/under/top?
  • 6,784 Answers
Hi, the reset switch is located on the inside of the dishwasher. its on the actual motor. here's a tip to keep the motor operational during low usage cycles.
If you do not use your dishwasher often, set it to fill and pump out once every week.
This will help keep the seal moist, and the garbage disposer clear. it will also keep the motor form deactivating itself.
Posted on Mar 09, 2009
  • Michael Masters
    Michael Masters Mar 09, 2009
    Heres a quick way to reset the control panel. this may power up the motor without disassembling. press and hold the on/off button for 2 mins.
  • Michael Masters
    if that panel reset didn't work, you will have to manually reset by disassembling and pressing the on board button on the motor.
I have a Hotpoint BF71 dishwasher. I put it on but it hasn't worked, it filled with water which won't drain not will it even start now. I took out the filter but I couldn't find any blockages Help!
Reset the power at the breaker, but you may need a new pump and motor assembly. The same pump washes and drains on most Hotpoint models- a solenoid is used to open a drain flap and let the water out, but a bad pump will equal no wash or drain... Hotpoint Dishwasher Pump and Motor Assembly WD26X10013 Hotpoint Dishwasher Drain Solenoid Kit WD21X10268
Jul 11, 2016 | Hotpoint Dishwashers
Hotpoint LFT 228 A dishwasher not making any sound
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Mar 11, 2012 | Hotpoint-Ariston LFT 228A 23 in Builtin...
. The dishwasher fills with water but will not
Same problem here. It's been a while since we used it. HDA 3440GO2SA. I think I've narrowed it down to the motor seizing. I get 12.2 ohms on the windings and a local tech says the windings are good then. Some decent troubleshooting videos here http://www.appliancehelponline.com/dishwashernotrunning.html. Turn the breaker off for the unit (so you have no power), remove the bottom panel and kick plate. take a screw driver and try to turn the motor fan blades. If it turns really hard keep turning it until it loosens up. If it turns freely, pull the plug, test the power coming in with your multimeter (requires turning breaker back on, of course, but after the leads are inserted in the plug). You should have around 120 volts with the door switch activated and wash cycle on. Anyhooo...I plan on trying to pull the hub and clean it up, put some di-electric grease on it and re-assemble. If that doesn't work then I'll debate whether to spend 150+ on a new motor or just get a new dishwasher...lol.
Jul 31, 2011 | Hotpoint 24 in. HDA3400G Built-in...
I'm trying to find out info on Hotpoint dishwasher catalog # 40mc20
That number is not a factory Hotpoint model number, you need to get the Hotpoint model number, which starts with #HDA*******(example#HDA1100NWH) then go to www.hotpoint.com and you will find info on the dishwashers.
GOOD LUCK !
Aug 09, 2010 | Hotpoint Dishwashers
My dishwasher starts fills water and never starts wash cycle?
If you hear a hum when it should be washing, the motor has seized. Replace motor. If it fills with water and stops quite, run it through a test using the tech sheet under the bottom panel to access. These dishwasher have had issues with the motor.
Oct 09, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
Premature drain on Hotpoint HDA 3400 dishwasher
hello my name is gilles the problem you have their is something stuck in your drain valve causing the valve to stay open remove the valve clean out reintall every thing should be fine thanks
Mar 15, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Hotpoint dishwasher full of water after cycle complete
If the motor is running, the diverter solenoid valve is probably not functioning. It is attached to the pump. With the power off, take the solenoid apart and remove whatever is jamming it. Toothpicks are a favorite as are any large food particle. It may also be bad. Not the problem...you may have a defective timer or your outlet hose is clogged or kinked.
Feb 10, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
FDW60 dishwasher
I've just (as of 10 minutes ago) had the same problem. I followed the advice given elsewhere in this forum and removed the bottom cover - water running out so needed a big towel to mop it up. I stood the machine upright and restarted it - no problem! it started straight away.
The question now is where is the water coming from? It seems there is obviously a leak somewhere and water is gathering in the undertray setting off the microswitch.
Oct 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher repair
remove your filter and you will find something wedged in the motor housing make sure you unplug before you start work if not check the capacitor mounted on the motor good luck
Jul 21, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishwashers Logo
254 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
