Question about Faria Chesapeake Series Tachometer
Tachometer needle does not move after the engine is running
115 Yamaha 4 stoke engine, Faria tachometer/guage style
The tachometer needle does not move when the engine rpms increase.
    Genius:
  • 1,066 Answers
Sounds like a bad connection on the outboard or the gauge
Posted on Mar 09, 2009
100 hp 4 stoke yamaha
What would you like to know? You have to give a little more info on your issues you are having with it, so we can help you out.
May 13, 2017 | Clymer Marine Maintenance and Repair...
Faria tachometer stuck and no longer operates
Common problem, probably moisture intrusion. Will most likely have to replace it.
Sep 15, 2014 | Faria Chesapeake Series Tachometer
Faria tach connected to alternator, irregular readings, needle bounces or does not leave zero, same readings on upper and lower tachs, Ford Leman engine, wiring connections are tight
Have you Alt tested for a bad diode. They still put out, but have an irregular pattern and lower voltages. That would bounce your tack all over the place.
Nov 13, 2012 | Faria Chesapeake Ss Marine Instruments...
Timing mark diagram for a yamaha f115txra
Hi Clifford_sut, I am sorry you can't find the first and best tool you ever bought for your Harley but despair not for a mere $15.00 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
Yamaha Motorcycle Service Repair Workshop Manuals
Aug 15, 2012 | Motorcycles
2004 yamaha 115 4 stroke, Loosing rpms and alarm sounding
maybe try replacing the fuel filter. it is possible that it has sediment in it and needs to either be cleaned or replaced (depending on the way it works)
these marine engines are difficult to work on, you may consider taking it to an actual shop to get it fixed
Jul 08, 2011 | Yamaha Boating
Starboard needle keeps erratic behavior, engine does not lose rpm nothing seems abnormal, usual see this when gas has water but port engine runs fine from same tank and needle steady
My thought is this may be electrical in nature. I would test with an external guage. If your engines have points, make certain they are in good condition. I suggest considering upgrading ignition to electronic, but that has nothing to do with this event, necessarily. Points are just always out, slightly.
Another test, before anything, may be to reverse the inputs on the Floscan and see if the problem moves or stays. If the problem moves, the starboard ignition is suspect. If the problem does not move, the Floscan may need repair. Make sure that you have tight and clean connections and good grounds.
Dec 13, 2010 | Floscan Twinscan 0 8000 Tachometer
Faria Chesapeake Series Tachometer Logo
1,121 people viewed this question
Top Faria Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Faria Boating Expert? Answer questions, earn points and help others
