I HAVE A WHIRPOOL WASHER WITH the ser # LSB6200KQ1 NOT WORKING. THW WATER FLOWS INTO THE WASHWER BUT CANNOT DRAIN OR SPIN. PLS ASSIST ME
  • 163 Answers
Most likely lid switch is bad or drive coupler.push the lid switch down and see if it clicks.if no click then its bad.drive coupler is located between motor and trans.
Posted on Mar 09, 2009
Whirlpool cabrio washwer wtw5600xw0 washes fine but when it's time to drain ,it drain's some of the water and it stops i had the pump checked and thought it was bad but it was not , i had a local repair...
So when you say it's not pumping all water out, is there still water standing in tub or no water standing and clothes are just sopping wet? Is machine spinning? If not spinning, could be actuator that shifts transmission from agitate to spin.
Aug 24, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
WHIRPOOL washer model LSR8010PQ0, WHEN LOADED WIT...
If large items in the machine create an imbalanced load the machine is designed to switch off...Towels are notorious for doing this because they hold so much water. Jeans don't soak up much water. Wash towels with towels alone and the problem should be reduced....Good luck....Nomess
May 16, 2010 | Washing Machines
My whirpool front loader say f02
If I am not mistaken f02 code means that long drain. put into spin and see if the pump turns on if it does check if water is coming out... if not need to check if there is something stuck in the pump blocking the flow for the water
Nov 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Will not drain or go into spin cycle
Definetly the lid switch has been knocked out of place or has gone bad.
Aug 26, 2009 | Whirlpool Washing Machines
Whirpool Washer LSQ9500LQ0 Won't Spin or Drain
Your belt assessment sounds correct on the dryer problem.
If you can, restore the lid switch connections, and operate the switch during what should be spin. You should be able to hear a relay or solenoid clicking off and on with the switch.
Aug 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirpool washer wont work
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Jul 26, 2009 | Whirlpool CAM2752KQ Top Load Washer
Water Won't Drain from Washing Machine
Hello phylislw61,
If you had an incident where a pillow broke and feathers where dispersed throughout the washer..then there is a good chance that teh drain fiilter screen, pump or hose feeding the pump is clogged. I would verify that the filter is free from anything that would limit water flow from getting to the pump.. then if the problem is still there.. examine the pump itself to make sure it isn't clogged...
If you or someone in your family is reasonably handy, here is a link to your washing machines exploded view and parts and this should provide sufficient information for how to access the pump and associated hoses etc that feed into and out of it for cleaning..
If you are having problems after you verify the lines are free of restriction, feel free to contact me and I will try to assist you in solving your problem.. Here is the link..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Dec 06, 2008 | Roper RAS8445KQ Top Load Washer
Whirpool top load washer
things to check, to narrow it down:
  • is the timer stopping prematurely? (timer problem)
  • is the machine draining the water as fast as usual? (water pump problem or something blocking water flow)
  • is it spinning as fast as usual? (clutch problem)
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 11, 2008 | Washing Machines
Washing Machines Logo
147 people viewed this question
Top Washing Machines Experts
