SOURCE: New Fan for buffalo terastation ts-1.0tgl/r5
just the fan, with 3 wires, as long as it has the 3 wires then you can adjust the speed... most fans do come with this 3 wires setup now adays
SOURCE: buffalo drivestation 500 gb wont start
Certainly we can help,
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
SOURCE: Unfortunately I formated my BUFFALO
Dear Shaji, I think u used File recover software for recovering the file. Same thing happened to me also. My brother got one HDD from his friend. I will explain u, how to recover or to detect HDD. I have a suggestion. I think u r believing in god. So first pray and put the HDD in USB port. After that also, if u are getting same issue means, you can give this HDD to some other great intelligent beautiful people... Like your MACHU (cousin)
Pitt_Fan, wondering if you found the answer to your problem. I too am looking at replacing our NAS drives (3 of) with one big 4 bay RAID capable system from Buffalo - so am wondering what you think of it, and it's service support?
thanks.
