Question about Motorola Mobility TracFone w175 PayAsYouGo Cell Phone
Unable to change the time.
I am unable to change the time. Apparently, Tracfone does not come with automatic DST. Selecting ''Settings,'' ''Initial Setup'' also proves futile, because there is no Time/Date menu on the W175G model. Thanks.
  • lizhend Mar 10, 2009
    I have the same problem. Please somebody help. Tracfone acted like I was kidding them.
  • Darrin Apr 13, 2009
    Update: a week after my initial post, it automatically changed to DST.
MY W175 Automatically changed to dst. Had to turn it off and I dont remember if had to take the battery out or not, but when it finally picked up service the time was daylight savings time.
Posted on Mar 26, 2009
How can I set the time zone?
The DST is only based on GMT.
When daylight saving time (summer time) begins
The following models employ the Automatic Daylight Saving Time/Summer Time adjustment. The DST indicator in the display appears in the display at the beginning of the daylight saving time (summer time), and disappears at the end of it. Automatic DST/Summer Time adjustment is based on GMT (Greenwich Mean Time).
• Summer time begins at: 1:00 AM on the final Sunday of March.
• Standard time begins at: 2:00 AM on the final Sunday of October
To cancel the Automatic DST/ Summer Time adjustment and
to set DST display manually
The Automatic DST/Summer Time adjustment can be cancelled.
Press and hold DST for more than 3 seconds while the clock is displayed.
A beep sounds, and "Aut t OFF" appears in the display to show that the Automatic DST/Summer Time adjustment is cancelled. The display returns to the clock.
Notes
• The change timing of Automatic DST/Summer Time adjustment employed by the unit (see above) is subjected to variation by circumstances and the law in each country/region. In such a case, cancel the Automatic DST/Summer Time adjustment and
set DST display manually as necessary. The customer who lives in the country/region that has not introduced the daylight saving time (summer time) must cancel Automatic DST/Summer Time adjustment before using the set.
• To activate the Automatic DST/Summer Time adjustment again, press and hold DST for more than 3 seconds. A beep sounds, and "Aut t On" appears in the display to show that the Automatic DST/
Summer Time adjustment is activated. The display returns to the clock.
• To change the display to the daylight saving time (summer time) manually, see "To change the display to the daylight saving time (summer time) indication."
Sony ICF ICF C318 Operating Instructions Operating The Radio Setting The...
Apr 21, 2016 | Sony ICF-C318 Dream Machine Alarm Clock...
Text messages going to outbox.
Some reason why a mobile failed to send message and proceed outbox due to this instances.
1. Account is not sufficient
2, network signal problem
3. too many messages store on phone and may lead to full memory and unable to perform any operation.
try this method :
* try to change another simcard and test if can send message.
* erase unused data/files for phone memory free space.
* go to settings > initial set-up > master reset and reset your mobile,if ask for the code,default unlock code is 1234 or default security code is 000000.be sure to back up all data of yours before proceeding cause al data will be erase and it will go back to its orifinal settings.
good luck.
Jun 18, 2011 | Motorola Mobility TracFone® V170 Cellular...
Resendly purshased a casio 4772 watch. diplay time and city. trying to get it set for dst. read manual and cant get button (A) to flash. can u help
Hi ...
your watch supports Time Zones , Automatic time Updates, Automatic adjustments of DST.
First Verify Correct Home City Is Selected
1. In Time Keeping Mode (That is The Digital Display shows time and Day of week)
2. Press Button (A) long enough to country code start to flash on digital display.nightflare_4.png
3. Press Button (B) or Button (D) to change Country code to current one.
4. After Selecting Desired Country, Press button (A) TWICE.
Now Country Code will be saved on watch.
Supported Country codes are:-
To Activate DST (Daylight Saving Time).
2. Press Button (A) long enough to Digital Display start to flash.
3. Press Button (C) TWICE to Display DST Settings.
4. Press Button (D) repeatly to cycle through three DST Options:-
A --> DST is set on Automatic Mode. If Your country uses DST, the watch will Adjust DST Accordingly.
OFF --> DST is set to disabled. No DST is applied to Main Time Settings
ON --> DST is Set to On. DST is applied even if your country doesnot follow DST.
5. Press Button (A) TWICE to save Selected Option.
Default values (Factory Settings) when you bought this watch is
This way you can set DST
Mar 13, 2011 | Watches
I am unable to set the time because the function button (top left over the 10 O'clock position. I had a local watchmaker tell me the button moves, but it has no effect on the electronics. Casio has an...
I have a different model of Casio but I suspect that the operation is the same.
To change DST you should press the button (8 O'clock) to give world time. This should be showing your city.
You should then use the button you mention to toggle between DST & ST. (ST is no DST display!).
If this does not work and you wish to read through instructions for your particular model, then go to casio.com, select "support", and under "technical support" select "manuals", then "watches", agree terms, and the select "watch manuals archive", insert the required number off the back of your watch and download the instructions.
Jan 28, 2010 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Unable to set time and date on Sumsung t301g Tracfone
I had the same problem. I had the phone on when I called to set up initial service. After activation I left it on (it was charging) and tried to set time and date but couldn't get anywhere. Finally, I turned it off (hold "pwr / end" button till it turns off). When I turned it back on I got a message that time and date were now automatically set. This was about an hour and a half after intial phone call. Don't know if that wait time had anything to do with it.
Jan 02, 2010 | Cell Phones
How do you change time from DST to standard Time
you can go into the settings for your device and turn DST to "On" so it shows the correct time if your gps is not doing it automatically for you. You can check to see if it has the latest firmware loaded in it. Since the weekends for the DST were changed a couple of years ago some gps's may not change the time at the correct weekend.
Nov 03, 2009 | GPS
How to set the daily time on Ssano model number
You might try turning the power off for a few minutes, and then turning it back on. This worked for my sons LG 600G from Tracfone. It didn't have a place to set the date and time in the menu area that the manual said it would. Of course tracfone is a little different with their phones, but when you turn it off, the correct time and date is automatically downloaded from their satellite.
Hope this helps ya.
Nov 01, 2009 | Sanyo SCP-7050 Cellular Phone
How to upload wallpaper?
send the wallpaper to your phone by email.
Apr 13, 2009 | Motorola Mobility TracFone w175 PayAsYouGo...
Changing the time on my Motorola Razr V3 phone
Go to settings
--> Initial Setup
--> Time and date
--> Auto update off
Then you will find the time and date.
go to date use right soft key and change the date and similarly for the time.
Jul 28, 2008 | Motorola Mobility RAZR V3
Turning daylight saving time OFF
If DST is *already* set to "on" when you reset the time zone to Z-07 (Hawaii), my very recent experience is that the time *still gets adjusted back* by one hour.  Now that daylight savings time is over (at least according to the clock's pre-programmed and outdated schedule) I'm hoping that setting the time zone to Z-07 (Hawaii) will completely cancel the automatic time changes from now on.  Otherwise, I need to purchase another clock, and it won't be a Timex.
Apr 02, 2007 | Timex T311T Clock Radio
Motorola Mobility TracFone w175 PayAsYouGo Cell Phone Logo
262 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
