Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
I don't want to fix the ice maker. I just want it to stop leaking. Can you tell me how to turn the water off that is coming into the fridge.
  • 370 Answers
If you pull the fridge out there should be a valve behind the fridge. If not check under the sink. A lot of times they will plum the water from the sink. There will be a valve to turn the frigde water off.
Posted on Mar 09, 2009
Water leaking and no water to ice maker?
pull fridge out
unplug
turn off supply faucet to ice maker
check line and fridge connection for the leak usually at the frige.
repair as necessary
turn on water
check for leaks
Mike
May 11, 2016 | Refrigerators
My Maytag ice maker stopped working; ice on doors & draw; What do you think might be causing this?
As odd as this sounds, my Maytag MFX2570AEM stopped making ice. I could feel ice in the tray but it suddenly stopped ejecting or making more even when the bar was in the correct position.
I read many articles telling me the motor was dead, the gears for removing the ice from the tray needed to be replaced, etc. THEN, I read one person who responded that his issue was resolved with a HAIR DRYER. It turns out something about the unit had frozen due to water getting on it, etc.
Sure enough, after blowing a hair dryer into the ice maker for 5-7 minutes I replaced the ice maker drawer and in about a minute it ejected the ice and filled the trays with water again. It has been making ice ever since.
Jan 31, 2015 | Maytag Refrigerators
Water leaking under a fridge freezer
There can be 2 reasons for this ... the first is that the machine is causing condensation and is dripping on to the floor. Automatic defrosting fridge freezers do this but usually the quantity of water evaporates before any is on the floor.
If the Fridge / Freezer has an automatic Ice maker, or has a cold water supply, then I would suggest that there is a water leak to the system. In this case, find the water supply feed and turn it off to eliminate this as the source.
If this stops the leak, then either the supply is leaking or the problem is inside the fridge / freezer and you will need either a plumber or a repair man to fix the problem.
Aug 21, 2014 | Refrigerators
I don know how to turn on the ice maker of a french four door refrigerator
water line hooked up,open door to ice maker check to see ice maker metal arm where cubes fall down from is in the down position,,when its in the up position it stops making ice,no water coming inalso u can change water filter in fridge this way too,it will not let water in until arm is back down
Aug 07, 2013 | Whirlpool Whirpool 26 cu. ft. French Door...
Water leaking from Icemaker fill tube near the back wall
It probably is not the water valve. More likely it is the ice maker itself. Nothing else in the machine controls the flow of water to the ice maker except the ice maker itself. It is recommended that both the ice maker and the water valve needs to be replaced when trouble such as this.
Dec 12, 2012 | Refrigerators
I have an admiral American fridge freezer. The ice maker is continuously leaking water if the power is switched on as though a switched on. How can I stop the water ?
To verify if its the valve or the ice maker the easiest way would be to unplug the machine and then turn the water on. If the water stops, then the ice maker is bad and is continuously applying power to the valve causing the flood problem and should be changed. If the water keeps on coming out then the valve is bad and stuck open and should be changed.
Jun 04, 2012 | Admiral 26 cu. ft. Side-By-Side...
I have a Samsung bottom freezer top fridge RB215LASH. Water leaks from the inside back panel down under the crisper. The drain is not clogged. Their is no problem with the evaporator coils freezing...
OK, first there is only two ways water can be entering the fridge under any circumstances, one is through the Ice Maker feed line coming from your wall to the back of the fridge and into the ice maker. The other is from the ice trays themselves leaking or overflowing or the filter itself is leaking. Look at the side walls of your refrigerator, are there water streaks running down the side? Have you reset the ice maker since you did your repairs? Have you replaced the filter lately?
Usual Causes
If the water pressure is too high, the ice tray can over fill or water can splash out. You can turn the supply shutoff valve to reduce the water flow. See the diagram below. If the ice cube tray has residual pieces of ice in the bottom, remove the pieces by pressing the reset button. You may have to do this several times to clear all the ice out of the tray.
Get back to me and I know you provided a lot of information, but this is a inline water issue relating to the ice maker and not really thinking it could be anything else. So if you can give me more information about the form in which this happens, such as you find the water after the trays are filled or if this is a constant but minimal flow, large flow, we can concentrate our plan towards this are of the repairs and diagnosis. Look forward to hearing from you soon.
Aug 04, 2011 | Refrigerators
Ice maker has stopped making ice
Check the ice maker to see if there are ice cubes in the ice maker. If so, there is a problem with the ice maker heater and / or motor. You may be able to rebuild the ice maker by replacing defective parts, but it might be easier to replace it as a whole unit instead. If there is no ice present, it is likely a problem with the ice maker water lines / solenoid.
There are usually two solenoid valves and tubing systems for these types of fridges. One actuates on demand for water whenever requested, and the other operates automatically to make ice cubes until the ice cube reservoir is full.
Carefully push/pull the fridge away from the wall.
Unplug the fridge from the outlet.
Shut off the water supply to the fridge.
Remove access cover (usually the on the bottom) from the back of the fridge. Follow the tube that comes from the top of the fridge (for the ice maker) down to the bottom of the fridge.
Inspect visually for sources of the leak on tubing and related parts. Carefully check by hand for leaks in areas not readily visible - including the back sides of all the tubing, too. There may be sharp edges that can cut if not paying attention. If a leak is found where the tubing connects to other parts, you may be able to simply remove the tube and cut it back an inch or so if there is enough slack.
It may require that some special fittings and parts be obtained to reconnect and some compression type parts are designed for single use. If this is the case, gather the parts and bring them to a local hardware store for assistance obtaining replacements.
If a solenoid valve is found to be the culprit, due to a crack, etc. a trip to an appliance parts store will be required - unless able to purchase online. Part prices can vary widely , depending on the source.
Once replacement parts have been secured, reconnect after disconnecting power & water supply lines. When satisfied with the installation, reconnect power and water lines and test.
Carefully slide the fridge back into position - taking care to not crush the power or water lines.
Dec 31, 2009 | Freezers
Ice maker works but not water dispenser
Here are the steps I took to fix thi:. First, if you tapped into a copper line near your sink, turn off the off the tap completely and turn it back on again. Why? Occasionally, calcium deposits will build there and cut down your water pressure. You may have enough pressure to run your ice maker, but not enough to push the ice out of the line (I'll talk about this later). Turning the tap on and off breaks up the calcium. This will also fix an ice maker that's slow to make ice or makes hollow cubes.
Next, I just kept running my water pump (about sixty seconds or more at a time) until the water finally started to come through. When it did, a few inch-long pieces of of ice came through -- telling me that the problem was a frozen water line. If running the water pump several times doesn't work (I think it took me six tries), consider turning off your fridge for a while (be sure to remove food and pack in dry ice).
May 05, 2009 | Kenmore Refrigerators
Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
Nov 17, 2007 | KitchenAid KSCS25IN Side by Side...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
61 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
