This behavior may occur if Windows stops responding during a typical
operation or during the shutdown process. By default, the computer is
configured to automatically restart when Windows stops responding. To
view this setting, follow these steps:
- Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Start up and Recovery.
- Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
If your computer constantly restarts while you are using it, or if you
are trying to shut down the computer after it has stopped unexpectedly,
click to clear the Automatically restart check
box. If you clear this check box, you receive an error message when the
computer stops responding. This error message may describe the cause of
the problem. You can also review the system log in Event Viewer to view
the critical stop error that occurs when the computer restarts.
For additional information, click the following article number to view
the article in the Microsoft Knowledge Base:
308427
(http://support.microsoft.com/kb/308427/
HOW TO: View and manage event logs in Event Viewer in Windows XP
To configure the way that Windows responds when the computer stops unexpectedly, follow these steps.
Note:
You must be logged on as an administrator or a member of the
Administrators group to complete this procedure. If your computer is
connected to a network, network policy settings may prevent you from
completing this procedure.
- Log on to the host computer as either an administrator or the owner.
- Click Start, and then click Control Panel.
- Under Pick a category, click Performance and Maintenance.
- Under the or pick a Control Panel icon section, click System.
- Click the Advanced tab, and then click Settings under Startup and Recovery.
- Click to select any one of the following check boxes under System Failure:
- Write an event to the system log
- Send an administrative alert
- Automatically restart
At last if nothing works then clear the "Star up"
- C:\Documents and Settings\All Users\Start Menu\Programs\Start up
If you are not satisfied then If you are using XP then repair it.
thanks
I updated my BIOS to the latest from HP.com site. I did the restore BIOS to default. It still restarts on its own after I "shut it down". I even reformated the drive and reinstalled the WIN XP SP3 fresh, I still have the same problems. If you have other suggestion, I will try it. Thanks
Changing the motherboard would be too costly. I probably try your suggestion about resetting the CMOS. Thanks
Great work, Shakeelm. I removed the backup battery..I tried to lift off the battery, but I managed to lift off the battery holder (ughhh). I had to re-solder the battery holder to the motherboard. To get to the backup battery on the ZD8000, I had to remove the keyboard, the top cover, etc..Quite a bit of work.. I wish HP had installed a jumper where it is easily accessable.
Thanks.
