Question about Whirlpool Dryers
Whirlpool electric dryer, Model LEC6646ANO. On
Whirlpool electric dryer, Model LEC6646ANO. On all 3 temperatures (high, medium & low), it gets very hot; as if the heating element won't cut off and on. But when it gets to the ''cool down'' part of the cycle, the heating element does properly cut off. Help please!
  • 1 more comment
  • jwfondaw Mar 10, 2009
    The vents are not blocked with lint and, yes, it will complete a 45 minute time dry and dry the laundry. It just gets way too hot!
    I removed the vent from the rear of the dryer and with no laundry in the dryer, I ran it on high heat. I checked the air exhausting at the rear vent with 3 different thermometers and all 3 registered at least 190 plus degrees. The dryer did not cycle off. It reached that temperature within 5 minutes. I opened the door to shut it off and the inside of the door was too hot to touch. You could quickly touch, but you couldn't leave your hand on it.
    Thanks for your help! Working like new!
  • Whirlpool Master
  • 3,361 Answers
Make sure the internal and external exhaust vents are not blocked with lint.
Will it complete a 45 minute time dry and dry the laundry?
Posted on Mar 09, 2009
  • 1 more comment
  • steve
    steve Mar 10, 2009
    Remove the connecting vent from the rear of the dryer.
    With NO luandry in the dryer run it on HIGH heat.
    With a accurate thermometer check the exhaust temp for 135-160 degrees.
    If it cycles at that temp...you have NO problems.
    If you do not cycle, or cycle at different temps...please report back.
  • steve
    steve Mar 10, 2009
    Unplug the dryer.
    Remove the rear panel.
    Replace the high limit thermostat attached to the heat canister near the heating element hook up.
    Replace the cycling thermostat on the lint/heat exhaust canister just to the left of your exhaust vent.
  • steve
    steve Mar 10, 2009
    Good for you.
    Thank you for the rating.
I have an LG Electric Dryer Model No. DLEO332W. It runs fine on ultra low or low heat, but if in the middle of the cycle I turn it to medium, medium high or high heat it cuts off.
There is a hi-temperature limit switch in the heating area that may be the issue. It can be manually reset but hard to get to. Top off, control panel off, front off.
Dec 03, 2017 | LG Dryers
Starts and runs for a few minutes and then just quits?
Hello Larry;
My name is Peter. I am a retired field service appliance technician.
You have not provided a model number so I do not know if you have an electric or gas dryer. Your model number may be on a label when you open the door.
In general:
1.) Air Flow Problem - Over time lint accumulates in both your hot air distribution manifold as well as you wall air duct. This will shut you down.
2.) Week Ignitor (Gas Dryers) - The ignitor in a gas dryer will glow red. The ignitor can glow red yet not have enough power to open your gas valve.
3.) High Temperature Thermal Switch or Fuse - In both electric and gas dryers you have a high temperature thermal fuse or switch. In either case, when this component is bad and reads any temperature, high or low, it will shut you down.
That is all I can tell you without knowing your dryer model number.
Jan 23, 2015 | Dryers
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
May 04, 2014 | LG DLEX7177 Dryer
I have inherited a west bend slow cooker model 84624 and dont have a manuel for it. I am concerned with the 300 watt is this normal? Or is that very low? I dont know how long to cook in this or amounts...
  • 1 Use setting 1 (warm #1) only to warm rolls and muffins. At 140 degrees Fahrenheit, this setting should not be used for cooking.
  • 2 Use setting 2 (warm #2) to keep cooked foods warm until they're ready to be served.
  • 3 Use settings 3, 4 and 5 (low, medium high) for cooking. The setting you choose determines the length of time the food will cook. A typical meal with meat and vegetables needs 7 to 10 hours to cook at the low or #3 setting, 4 to 6 hours at the medium or #4 setting, and 2 to 3 hours at the high or #5 setting.
  • All West Bend slow cooker models eventually simmer at the boiling point, or 212 degrees. The setting simply determines how quickly the cooker will reach that temperature.
    300 watt is not a huge consumption of electricity, depending of course on, how often, how long and how high temperature.
    Regards
    Sep 28, 2011 | West Bend 84624
    I have a Kenmore electric (front load) dryer, model number 84092500 that would spin but does not produce any heat. I tried cleaning/vacuumin the tubing that vents to the outside and resetting the circuit...
    The first step of the fix has been done by cleaning the lint filter and the vent system.The next step is replacing the thermal cut-off and the high-limit thermostat both located on the blower housing. It is common that the dryer stops heating when the thermal cut-off blows open due to the failure of the high-limit thermostat to cycle off and regulate the heater temperature. The thermal cut-off cuts power to the heating element should the high-limit thermostat fails and the dryer temperature goes extremely high as a safety feature. Click on the links below for the troubleshooting and repair details.
    Whirlpool and Whirlpool-made Electric Dryers (With Removable Back Panel) Not Heating
    Whirlpool and Whirlpool-made Electric Dryers (Without Removable Back Panel) Not Heating
    Jun 19, 2011 | Kenmore Dryers
    What is the highest temperature a household dryer should be?
    On a low setting the exhaust temperature should average in the 120-125°F range. On medium the temperature should average 130-140°F and on high 140-155°F, depending on the dryers design. Those temperatures should be basically the same with or without clothing.
    Nov 03, 2010 | Hotpoint NVL333EY Electric Dryer
    Whirlpool commercial gas dryer - heating problem
    Check the voltage to the switch when turned to high and the power button pushed on. If you are not getting any power there then the setting switch is bad replace it at repairclinic.com
    Feb 14, 2009 | Whirlpool CSP2761 Gas Commercial Dryer
    Duet Dryer
    burning smell would be coming on the coil of an electric dryer. the coils could have catch some lint that produces that distict burning smell..
    i hope i was able to solve you problem..
    pls rate me.
    tnx
    drcool
    Jul 15, 2008 | Whirlpool GEW9250 Electric Dryer
    Dryer exhaust temperature
    on high turns off at 155 medium high 150 medium 140 low 125 extra low 105 all theese are plus or minus 10 degrees
    Feb 15, 2008 | Whirlpool GEW9250 Electric Dryer
    Dryers Logo
    236 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
