Question about Lakewood 798240 Utility Heater
Will not operate properly, possible thermostat?
"798240 will only run for 30 seconds then shuts off will not turn back on without turning thermostat off then back on.Is thre a way I can correct this? Is there parts available for this unit?
  • 34 Answers
Please visit this page for parts and service center info:
http://www.lakewoodeng.com/html/parts.html
Posted on Apr 18, 2009
My furnace runs to operating temp on thermostat shuts down then within 30 seconds try's to cycle back on three to four times. What would cause this.
Some thermostats have a swing setting that can be adjusted. A swing is the setting when you want the furnace to stop or start from the desired set point. For example, you set your thermostat at 70 and the swing is set at 10 degrees. Then the furnace will turn on 5 degrees below 70 and shut off 5 degrees above 70. Check you thermostats manual if it has this option.
Mar 15, 2016 | Heating & Cooling
Amana 90 furnace won't ignite. Inducer fan runs for 30 seconds then shuts off and nothing happens. Try to turn fan on at thermostat and nothing happens. Ac works fine.
Most likely one of two issues is occurring. Either the inducer fan is not providing enough draft because it is either spinning too slowly or the impeller is damaged, or the pressure switch that the inducer motor air flow is supposed to activate is not operating properly. If the pressure switch fails to activate, the furnace will not open the gas valve and fire the ignition believing that there is not sufficient draft the vent the combustion gases.
Oct 17, 2015 | Amana Heating & Cooling
We have a Coleman Electric Furnace Serial # AOL6042086, Model # AHP36C3XH21A and the fan runs constantly, will not shut off. We have replaced the thermostat and just replaced the control board. We h
I wish I was a furnace expert but I will give a push in the right direction. When a gas/electric fan runs it has two speeds. When you turn on the FAN ON switch it should run at the slower speed. If it doesn't turn on or turn off again when you turn it back you have a wiring problem or a thermostat problem. Make sure the thermostat is compatible with your unit and wired properly (on both ends). The other time the fan runs is "in session" when heat or cooling is applied to the system. It should run until the system finishes the cycle then a bit more (30 seconds or 1 minute) to blow the treated air completely through the ducts. If it doesn't stop then you may have a bad fan time delay or relay. Check parts for your model and various appliance repair site online.
Nov 25, 2014 | Coleman Mobile Modular Home Electric...
Duo therm rv air conditioner repair
Sounds like thermostat is failing. There is a factory set resistor that helps the thermostat keep a 2 degree accuracy. Second possibility is that you have a fan or direct airflow from the cooling system, being devirted, that is allowing the cool air hit the thermostat on the wall.
Aug 17, 2013 | Heating & Cooling
My Honeywell Water Heater Thermostat will turn on for 30 seconds. Then it shuts down- wait 5 seconds turn it off EITHER with the ON/OFF switch OR by turning thermostat to off & back on immediately! If...
Time to call qualified service technician. And watch what that person does to learn about your water heater.
I assume you have Honeywell Icon gas valve. Honeywell makes different several model numbers.
Here is 'typical' Honeywell Icon gas valve service manual for Bradford White, that may or may not apply to your water heater. It shows testing for Icon and disassembly instructions, and error codes.
http://waterheatertimer.org/pdf/Bradford-white-service-manual-44943-D.pdf
Gas water heaters today require yearly service that includes cleaning burner parts and combustion chamber, checking vent and air intake, electrical connections, testing gas valve, checking gas pressure, bleeding air out of gas line, etc. These are things you can learn to do by reading service manual, and making sure you have a spare water heater around to connect real quick if experiment goes wrong.
If Icon gas valve is problem, that control is modular and can be replaced without draining tank.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 07, 2011 | Honeywell Water Heaters
Ac problem
Turn the thermostat off to see if the unit turns off. If it
does than you must have had a call for heating or cooling.
Put into heating mode let unit turn on, lower the setpoint and unit should turn off. If unit is not heating
than you have a problem with the outdoor unit.
Putinto cooling mode, turn thermostat all the way down, let unit start turn thermostat all the way up
if unit shuts off, unit is operating properly
Feb 06, 2010 | Heating & Cooling
Gas dryer does not get very hot.
the dryer dries after two or three tries
Dec 29, 2009 | Kenmore Dryers
Dryer flame shuts off after about 30 seconds
this sounds like a clogged vent more than a thermostat. go outside with the dryer running and see if hot air is blowing out the vent. if not check outside vent for birds nest etc, inside make sure the vent is straight any dips in vent could cause water to build up clogging the vent. try this first if it doesn't work write back
Jan 23, 2009 | Maytag Dryers
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Lakewood 798240 Utility Heater Logo
97 people viewed this question
Top Lakewood Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Paul Carew
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
