Question about IBM Infoprint 1552 Laser Printer
Service fuser error 920.06 - IBM Infoprint 1552 Laser Printer
  • Anonymous Apr 06, 2009
    Same problem on my InfoPrint.
Call for service C 430
All error code soloution of fuser unit Fuser Unit Error Status Counter
Purpose
When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
counter varies, depending on type of error.
Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
"10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
after the fuser unit related error is resolved.
C41: Thermistor or heater abnormality at power-ON
C43: Thermistor abnormality after abnormality judgment
C44: Heater abnormality after abnormality judgment
C45: Thermistor abnormality during printing
C46 to C49: Reserved
Description
When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
error is resolved.
For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
[Fuser unit related service call] in the Service Handbook.
0: No error 10: C47 (Reserved)
1: C41 (Once) 11: C47 (Reserved)
2: C41 (Consecutively occurs) 12: C48 (Reserved)
3: C46 (Reserved) 13: C49 (Reserved)
4: C43 14: C47 (Reserved)
5: C44 15: C48 (Reserved)
6: C45 16: C49 (Reserved)
7: C44 17: C47 (Reserved)
8: C45 18: C48 (Reserved)
9: C44 19: C49 (Reserved)
* Default: 0
Setting Timing
Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
Caution
Remember to resolve the fuser unit related error, and then reset to "0."
Dec 31, 2013 | Toshiba estudio 255 Copier
MON IMPRIMANTE LEXMARK T640N AFFICHE UN CODE D
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T640n, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
May 26, 2010 | Lexmark T640n Laser Printer
920.06 SERVICE FUSER ERROR
A 920 fuser error indicates that the fuser unit in the printer is below the proper temperature for printing. Turn off the printer for 30 seconds. Bypass any surge device or power strips, plug the printer straight to the power outlet in the wall. Make sure the printer is an operating environment where the temperature is above 16°C (60°F). If none of the steps above correct the issue, the fuser unit or possibly the power supply unit on the printer will need to be replaced. This will require a service action on the printer. I hope I can assist you more on this.
May 26, 2010 | Lexmark T640N Networkable Mono Laser...
921 service Fuser error
921 Fuser Error indicates that the fuser unit failed to reach the standby temperature. Leave the printer off for at least 10-15 seconds before turning it back on. This gives the printer's engine board a chance to reset. Make sure printer is plugged in straight to the wall, bypass any surge device or power strips as this can cause a low amperage problem in your printer which can trigger a false fuser error. If this does not help, you'll probably need service on the machine since it deals with the LVPS, the fuser and the system board.
May 19, 2010 | Lexmark Optra M410 Laser Printer
Error 58.04
This is from the service manual and should help you determine if you need to call in for service. If is in warranty I would anyways since the fuser would be covered if at fault.
58.04 ERROR To continue turn off then on. The low-voltage power supply has experienced an error.
1. Reinstall the fuser. Check the connector
(J1901) between the fuser and product.
Replace the cable or fixing unit if the
connector is damaged.
2. Reconnect the connectors of the fuser
control PCA (J303, J305) and the DC
controller PCA (J107).
3. Replace the fuser. See Fuser
on page 191.
May 03, 2009 | HP LaserJet 5200tn Printer
980-fatal-error
Service call 980:Error
Cause: Error by media clinging to the fuser
Error description: Media has clung to the fuser.
Solution: Power OFF. Replace the fuser unit.
Nov 19, 2008 | OKI C5800Ldn Led Printer
980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
*Media has clung to the fuser.
*Power OFF
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Apr 07, 2008 | OKI C5800Ldn Led Printer
Hello
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Mar 20, 2008 | HP LaserJet 4 plus Printer
ERROR
921 Fuser Error Indicates that the fuser is below standby temperature when the printer is idle.
Error codes 920, 921, and 922 may display for a cold fuser failure. A 920 error caused by low line voltage can sometimes be cleared by turning the machine off and then on again.
Service Tip: Set the Fuser Temperature to NORMAL before starting this service check.
Manually spin the fan and check that
it rotates freely. Check the cable
connection to the engine board, J13
for correct installation.
Jan 23, 2008 | Lexmark Optra M410 Laser Printer
IBM Infoprint 1552 Laser Printer Logo
945 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
