Question about HP Color LaserJet 2600n Printer
Print out looks 'dirty'. When toner cartridge
Print out looks 'dirty'. When toner cartridge gets low, the print out look like black toner has gotten on the paper. How do I clean this?
This is a HP 2605dn
  • horloge Mar 12, 2009
    replacing the cartridges does not help. We have a shadowy grey film on every one of our color prints. I think this is why Info Mgmt was willing to trade us our hpcolorlaser 2550n for this one.
  • 3 Answers
I solved this by doing the following:
- ran the Clean ETB function from the engineering menu - press the [tick] button, then press the [left arrow] and [stop] buttons at the same time
- did this again!
- printed a cleaning page
- replaced the black cartridge (refurbished)
Seems to be OK
Posted on Mar 12, 2009
  • namspam Mar 12, 2009
    And I vacuumed the inside of the printer....
If toner is low, replace it
Posted on Mar 11, 2009
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
WHENEVER I PRINT I GET A GREY BACKGROUND IT LOOKS LIKE DUSTY PAPER BUT IT ISNT? WHY IS THIS?
If the black toner cartridge (Q6000A) is not original, problem with the doctor blade, bad calibrated.
Use Original cartridges?
See This:
The amount of background toner shading becomes unacceptable.
1.The media might not meet HP specifications.
  • Use a different paper with a lighter basis weight.
2. Use a different paper with a lighter basis weight.
  • Check the MFP environment.
3.One or more print cartridges might below. If non-HP print cartridges are used, no messages appear on the control panel or in the HP ToolboxFX.
  • Replace any low print cartridges.
Aug 03, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
Hi when printing black or grey outside edges
sounds like your black toner cartridge is getting low or not filled evenly. To fix this until it get a bit lower on toner just take the cartridge out and holding it up right give it a few shakes side to side. The will spread the toner power out inside and you should be printing normally again.
This can also happen if you moved or bumped the printer. Usually you only see this when the toner is low or after you print a lot of pages. Most text is in the mid of the paper so thats where the toner get s used the most.
Oct 23, 2009 | Samsung CLP-350N Laser Printer
It says toner life end and it prints just fine
The toner life end message means the toner is getting low. It will continue to print without any problem. Eventually you will see the print starting to get light in spots. If it is a new cartridge, the toner level sensors are probably dirty.
Oct 08, 2009 | Brother MFC 7420 All-In-One Laser Printer
Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
Sep 23, 2009 | HP LaserJet 2840 Printer
Faded black print.
may have gotten a bad cartridge ! try another one !!
Jul 21, 2009 | Samsung CLP 300 Laser Printer
Konika Minolta 2430 DL won't let me print
Look through the menus on the printer for a setting for "Low Toner" -- the choices of what to do are usually either "continue" or "stop" or something similar (my 2430DL has this option setting) -- set this option to "Continue".
My 15 year old HPs also have a similar setting. However, this will keep it printing when the black runs out, so you will need to check your print production run visually as you go along to make sure the quality is what you need
Jun 22, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Brother HL2040 - Shading of toner all over my page when I print
The drum is a very sensitive part. Should not touch with bare hand, expose to light for long, etc. With what did you clean,it.
May 19, 2009 | Brother HL-2040 Laser Printer
Is there a override function to keep printing when toner alerts are on?Wondering since black still shows 30%.
These printers will still print when any or all of the toners are LOW, but if any one of them is EMPTY (according to the chip on the toner cartridge) printing stops.
Standard capacity toners ere 2000 page for the colours, and 3000 page for the black, so they can soon be used up.
Much cheaper per page printed, if you use the high capacity cartridges (6000 page for the colours, and 8000 page black).
There are high quality remanufactured cartridges available now, as good as OEM, and typically you'll get a Hi Capacity Remanufactured cartridge for the same sort of price as a Std Capacity OEM cartridge.
As a short term solution at a lower cost than replacement cartridges, you could just replace the cartridge CHIP. The printer would then think the toner was full (there'll likely to still be some toner in it), so you'll be able to print. Don't run the printer like this for ever though, as the toner has some lubricant properties, and with a TRULY EMPTY cartridge, you'll eventually do some damage to the cartridge, and then possibly the transfer belt (and you don't want to be changing that until it's rated 100,000 page life is up.
May 01, 2009 | Xerox Phaserâ„¢ 6180DN Laser Printer
Printed pages look dirty
That black dust that fell out is the toner. When you shake a toner cartridge that shouldn't happen. It looks like you have a faulty toner cartidge and that need to be replaced! Now to make your printer prints cleanly and clearly after you replace the cartridge, you'll need to get someone to service the printer(the faulty toner cartridge more than likely spilled toner on your internal printer parts, cause the smudges). Sevicing would mainly entail, taking down the printer and removing any spilt toner! If you feel you are up to this, be cautious, because toner can be hazardous to your health if you accidentally breathe it in! hope this was helpful! regards babb
May 10, 2007 | Brother MFC-7820N Laser Printer
HP Color LaserJet 2600n Printer Logo
901 people viewed this question
Ben Johnson
