Question about Kenmore 24032\24036 Top Load Washer
Kenmore 70 series washer
My kenmore 70 series washer will not finish rinsing or spinning. I took it apart and checked the water pump and it seems to be working fine. I took apart the motor and check the couplings and they seem fine also. I am guessing it has to be something electrical which I am not quit experience with can you help??
  • chrish7 Mar 09, 2009
    Isn't there a way of check it with the lid switch taken off and disconnected and something with the wiring??
    thanks a whole bunch it was the lids switch!
  • 163 Answers
Your lid switch is bad.you can take a pen and push it up and down to hear if it clicks.you may want to take it off and see if it has split.very easy to do.if you need help i can walk you thru it.
Posted on Mar 09, 2009
  • mike cooksey Mar 09, 2009
    you can take a jumper wire and try putting it in both ends of the plug coming down off the machine.you can strip both ends of a wire and that will be your jumper.all that is doing is by passing the lid switch.do not put either end in center of plug.plug machine in and make sure the wire is not going to hit against frame and turn machine to spin and on.
    Glad I was able to help.have a great day.
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Doesn't drain water and spin
It sounds like your drain pump is either clogged or bad. Bail out as much water as you can with a cup and then check the pump. There will probably be something in the pump stopping the impellor blades. There will also be alot of water so make sure you have towels and/or a bucket when you take the pump off.
Jul 06, 2010 | Kenmore Washing Machines
Washer doesn't rinse well. Doesn't spin water out properly.
Ok.you need tro make sure that its pumping out okay...if not check the filter..then pump..
Feb 21, 2010 | Washing Machines
I have a top loading kenmore 70 series washer. It
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Sep 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore 70 series Washer will not drain and spin
You have a bad lid switch . Try inserting something into the hole on the top and see if that starts the machine in drain/spin . If not , still bad lid switch . If so , tells you still bad lid switch .
Jul 26, 2009 | Washing Machines
Kenmore 20722990 series 70 will not drain
I have the same problem right now. I found a dime in the discharge but it still does it. I am going at it from the front side of the pump now. I need disassembly instructions for the upper sections to get to it. It was really nasty dirty and stinks.
Mar 18, 2009 | Kenmore 20722
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
130 people viewed this question
Sal De
fordexpert
Robert Rankin
