Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
No power to my dishwasher
There is no power to my dishwasher. I have checked the breaker and it was fine. We pulled it out and couldnt find a problem. I cant find a reset button anywhere, but everyone keeps telling me it should have one. Could you please give me some advise & let me know about that reset button.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
A diswasher is normally plugged into a non-switched outlet under the sink. Make certain the power cord hasn't been knocked out ot the outlet.
Most homes today come pre-wired for a garbage disposal, as well. Normally there will be one duplex jack under the sink, one jack "always on", the other controlled by a wall switch above the counter. If you don't have a garbage disposal, make certain the dishwasher is plugged into the "always on" jack.
Posted on Mar 09, 2009
Had a power failure from bad weather now the dishwasher is dead? checked the fuse box the breaker is fine, there are no lights on the display panel. what is the reset procedure for this dishwasher?
Try turning the breaker for the dishwasher off for 30 seconds and turn it back on. This should reset the dishwasher control board. If it still doesn't work then most likely the power failure burned up the main control board. The control boards in the newer dishwashers are sensitive to any type of power surges or failures.
Hope this gets it running for ya.
Dec 15, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Miele G 2630 stopped working. It started and then just stopped now no power
Hi
The power issue with the Miele G2630 dishwasher is due to a blown fuse inside the dishwasher or due to faulty main board of the dishwasher. However, before checking internal components we can first reset the circuit breaker, make sure it is a 15 A breaker. If the breaker is fine then you'll need to disassemble the dishwasher. Try and dis-mantle the dishwasher from its place, before this remember to turn off power and water supply. And also check for the drain hose. After the dishwasher is dismantled, you can remove the back panel of the dishwasher and check for the blown fuse and also check for any loose connections on the power supply board. Inspect for burnt components on the main board.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Jul 30, 2010 | Miele G2630SCiSS Dishwasher
Was working fine but acts like it has no power. No lights on, fuse breaker is fine, plug is fine
when you say the plug is 'fine' does that mean you've checked the line for 120 or 208 volts with a voltmeter? if so then the only thing to do is pull it apart and find out where your problem is. It has to be somewhere before any lights or motors. I'm assuming this dishwasher is on a GFCI breaker (the test/reset outlets that trip when wet), if so that would be to check if you haven't confirmed voltage on the outlet. Keep in mind it doesn't have to be on the outlet you're plugging the dishwasher into, it may be a few feet away, I suggest you just make sure all the outlets are working properly
Mar 06, 2010 | Dishwashers
Cant reset
Turn power off at circuit breaker and wait 5 minutes for board to clear then reconnect power. Should be fine.
Feb 28, 2010 | GE GLD4450NCS Dishwasher
Not getting anypower checked the breaker and that's working fine
you need to check that you have power going through the breaker. you do that with a voltmeter.once you know you have power through the breaker you have to check you have power at the Dishwasher with the voltmeter.if you have power there you could have reset on the motor. or the clock has gone bad.I have seen some feed out of a GFI outlet to the dishwasher.
Feb 26, 2010 | Dishwashers
Washer stopped mid-cycle, water in the bottom of the tub. Circuit breaker popped due to over-load. Reset breaker and it immediately popped again. Could this be cause by a jam in the grinder assembly?
My dishwasher just quit mid cycle. (still has water in it) It is a whirlpool partner 1. I checked the breaker and it wasn't tripped... but i reset it anyways. When I tried the dishwasher again it worked for a second and turned off. I have done reading about the thermo fuse but can't find it. Not sure how big of a problem this is.
Dishwasher is 5 years old.
Thanks,
Dale
Jul 02, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Dishwasher model gu980scgq3
Hi vicyoung0921,
I'm Harvey the Master Plumber.
Your question is: Will not start, seems to have no power at all. You checked the breaker and it's fine. Is there a reset button somewhere on this dishwasher ?
No reset, if breaker is good then check the connection at the d/w. It's under the d/w behind the kick plate on right or center under a cover box. 9 times out of 10 you'll find a loose, broken or burnt connection there. That done, it's time to call in warranty repair. If beyond warranty you might consider utilizing the Repair Directory to find a repairman. If the d/w has a few years on it perhaps it is time to compare the cost of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Dishwashers
No power
perhaps you should check the fuse in the plug and in the breaker,if there is still no power maybe a circuit has blown in which case you should call yhe manufacturers for qualified technicians.
May 05, 2008 | Frigidaire GLD2445RFC Stainless Steel...
JDB3610AWX - Controls (pushpad) does not respond to input (doesn't turn on, led doesn't light)
in the manual there is a sequence to unlock the control check the manual for the unlock sequence
Apr 25, 2008 | Jenn-Air JDB3610 Built-in Dishwasher
Kitchenaid 24" SS dishwasher
the first thing to check is power. check your breakers to see if any are tripped. if so turn it off than on some breakers do not reset if you just switch them to the on position. also check if it has a plug or shut off switch in a cabinet nearby .
Dec 31, 2007 | KitchenAid 24 in. KUDG25SH Built-in...
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
971 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
