Question about GE JTP45 Electric Double Oven
I have a F0 on the display of my double oven JTP45 model
I have pressed the clear button as suggested per manual and have disconnected the power source per manual and it has not helped. I only use my oven about 20x per year (holidays & special occasions) as it is only myself and husband, so even though it is almost 8 years old it is not used daily or even weekly. The last time it was used was Valentine's Day 09. I am not pleased to have to repair a frequently used oven. I would like to know what my options are for repairing this unit and if there are any recalls as well. Thank you in advance. Cheryl
Giggles01: I wish I had an answer other than calling GE. We are about to install a used oven of the same model/same vintage. I've been unable to locate a manual and need some information from it. Would you be willing to tell me the cut-out size the manual calls for regarding the installation of the oven? Most 30" ovens require a 28.5" cut-out, and I need to confirm that for the JTP45. Thank you!
Posted on Mar 23, 2009
Jtp45 lower oven hot heating on any cycle
Possibly a tripped thermal fuse. Should be located behind the panel in between the upper and lower ovens. Might have a red reset button on it you can push down. If it clicks and then works again, look for possible cooling fan problems.
May 12, 2014 | GE JTP45 Electric Double Oven
Ge jtp45 display is very dim
Cover over display has a film that darkens with age. you can cut the film off.
Dec 26, 2013 | GE JTP45 Electric Double Oven
Double wall oven F0 error code
The F0 error code means that the control board has detected a defect within the control board itself, the F0 code can be cleared by pushing the CANCEL/OFF button and if it goes away and returns all is well,however if a short time later the F0 returns the control board would need to be replaced.
GENE
Oct 04, 2011 | GE Profile 30" Built-In Double Electric...
The teamperature on the digital display can say 350 degrees and the oven thermatore that is located in the oven reads 310. Does this oven need to be calibrated? The oven is 6 years old.
The thermometer that hang on rack are Whooly inaccurate. A good one is the TAYLOR brand. As long as things bake within recipe time no adjustment needed but to do it;
  1. Press BAKE
  2. Select the maximum temp. depending on model it either 500 or 550
  3. Quickly (within 5-seconds of setting 550) press and hold the BAKE button approximately 5-15 seconds until "00" or the previously entered temperature adjustment is displayed.
    Pressing longer could cause an F0, F1 or F7 error to be displayed.
  4. Press the UP/DOWN arrow button to change the oven temperature in 5° increments to a maximum of +/- 35°
  5. Press the CLEAR or OFF button to return to normal operation.
But before doing that i suggest a new high quality thermometer that you hang on oven rack
Aug 12, 2011 | Ovens
How do you recalibrate the oven temperature of a Whirlpool Accubake oven system
To do that;
  1. Press BAKE
  2. Select a temperature of 550 or highest temp on some models its 500
  4. Press the UP/DOWN arrow button or turn the set knob to change the oven temperature in 5° increments to a maximum of +/- 35°
Gene
Aug 12, 2011 | Whirlpool Ovens
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Apr 21, 2017 | Whirlpool GBD307PD Electric Double Oven
I have a Kenmore 30" double wall oven model no. 911-41185. It will not let me do anything and keeps displaying FO and beeping. Can you tell me what is wrong?
F0 means no error. press cancel to clear display.
If you cannot then that key might be stuck, just a guess. I have your tech repair manual with failure codes and troubleshooting on page 43. This NOT a user guide. It is meant for qualified peeps. So be careful. Late model double oven tech repair manual HERE
Feb 06, 2010 | Ovens
I have a 326B1230P001 GE Double oven that displays ?F7? and beeps?..have cut power to it to try to reset it but it comes back beeping and the display goes through different changes by itself?.what is wrong...
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jul 30, 2009 | GE JTP45 Electric Double Oven
GE Profile double Built-In Oven error Code
According to the GE User manual... any F# error code means you have a function error and they suggest you press the CLEAR/OFF pad and allow the oven to cool for one hour. Then put the oven back into operation. If the function code repeats, disconnect all power from th eoven for at least 30 seconds and then reconnect it.. If it still comes back.. call for service.. however it has been my observation that F0 is usually a shorted off key on the keypad. Hope this helps..
Sep 21, 2008 | GE Profile JTP56 Electric Double Oven
Display 11
your control must be fried...dacor fault codes are f0 to F8 the display must be faulty..
Aug 25, 2007 | Dacor ECD230 Epicure Electric Double Oven
GE JTP45 Electric Double Oven Logo
196 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
