2006 Buick Lucerne Logo
Posted on Apr 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I replaced my water pump for my 2006 buick lucerne and now theres no heat
I replaced the water pump on my buick burped it for about 20 minuets and now there is no heat to the car
Anonymous
Level 3:
President:
  • Master 949 Answers
  • Posted on Apr 14, 2013
Anonymous
Master
Level 3:
President:
Answers
949
Questions
0
Helped
420912
Points
3655
Hope you didn't break a nail.
There is a air pocket in the heater core, you just didn't burp it right.
Try this
  1. Open the hood of your car. Secure the hood with the safety handle. If you have a newer car, you should have a bleeder valve on the front of your radiator. Check in your owner's manual for the location of this valve. If you do start your car, open the valve with wrench and let your car heat up. The excess air will bleed out of your cooling system. Keep your car on long enough to give the (trapped air) time to bleed out of your system.
  2. Let your car cool down. Once the car is cool, take off the radiator cap. Did the level of the radiator fluid go down? If it did, it means you bled the air out of your cooling system. Replace the radiator fluid, turn on the car, and let it run. Replace radiator fluid as needed.
  3. Step 3 (above) is the way you will remove air from your cooling system if you do not have a bleeder valve on your radiator. You will leave the cap off the radiator. You will run your car until it heats up. As the air dissipates, the radiator fluid level will go down. You will fill up your radiator fluid to the correct level. Be careful because the heated radiator fluid will be hot. Always wear leather gloves and safety goggles when working on your radiator.
  4. Once the air dissipates and you fill the fluid, shut off the car. Let the car cool down. Once the car is cool, put the radiator cap back on the radiator. You may have to put more radiator fluid in the radiator. The level may fall as the car cools down. Now it is safe to drive your car. You have removed the trapped air from your cooling system.
Tips:
Always wear gloves and safety goggles when working on your radiator.
Radiator fluid gets very hot when heated.
Check radiator fluid periodically.
5 Related Answers
Anonymous
  • 106 Answers
  • Posted on Mar 19, 2009
SOURCE: 2000 buick lesabre - water pump replacement
first disconnect the battery then check how the serpentine belt is lined up so u can take it off and put back on. Then the pump should be on the side of the motor with 9or12 bolts there could be more! after taking out take razorblad and skrap the old gasket clean wipe of then put new gasket and pump back on dont over tighten the screws cuase the pump my be aluminum.
GM Elec
Bruce Bracey
  • 1000 Answers
  • Posted on Apr 21, 2009
SOURCE: 2006 Buick Lecerne airbag light stays on
The Air Bag light is indicating it see's something wrong with the system.
Go to you local Auto Zone or Advance Auto and have them scan for codes. They will do the scan at no cost to you.
Let me know what the codes are and we can go from there.
Regards,
honeymokey
honeymokey
  • 3113 Answers
  • Posted on Jun 16, 2009
SOURCE: 2007 buick lucerne has water leaking into the
Remove trunk trim and covers , close trunk and wet car now look for leak source.
Anonymous
  • 521 Answers
  • Posted on Aug 04, 2009
SOURCE: WHERE IS THE BATTERY LOCATED ON A 2006 BUICK
Battery is locate dunder the rear seat bottom cushion.
Anonymous
  • 7 Answers
  • Posted on Jan 12, 2010
SOURCE: how do you access the windshield washer pump on
The washer pump is located on the bottom of the wash fluid bootle. you can access it by removing the front passanger fender liner..
I have a 2008 Buick Lucerne and my lighter ports don't work?
'"Lighter Ports"? You mean accessory power outlets and cigarette lighters?
Fuses 26 and 31.
Buick Lucerne (2006-2011) fuses and relays
Fuse Box Diagrams https://fuse-box.info > buick > buick-lucerne-2006-20...
Cigar lighter (power outlet) fuses in the Buick Lucerne are the fuses ? F14 and F23 in the Rear Under seat Fuse Box (2006-2007) or fuses ? F26 and F31 in the Rear ...
2008 Buick Lucerne fuse box diagram
StartMyCar https://www.startmycar.com > Lucerne > Fuse box
The 2008 Buick Lucerne has 2 different fuse boxes: Underhood Fuse Block diagram. Rear Underseat Fuse Block diagram. Buick Lucerne fuse box diagrams change ...
2006 Buick Lucerne. Looking for a Manual for it?
Question edited for clarity and add maker.
Question moved to model category.
2006 Buick Lucerne Owner Manual M - Dealer E Process
dealereprocess.org https://cdn.dealereprocess.org > servicemanuals
2006 Buick Lucerne Owner Manual M ... Keep this manual in the vehicle, so it will be there if ... A French language copy of this manual can be obtained.
416 pages
2006 Buick Lucerne - Owner's Manual - 416 Pages - PDF
OwnersManuals2.com https://ownersmanuals2.com > buick > lucerne-2006-o...
2006 Buick Lucerne - Owner's Manual. Posted on 10 Apr, 2020. Model: 2006 Buick Lucerne Pages: 416. File size: 3 MB. Download from Buick.com. Online Viewer.
What is the diagram for a 2006 Buick Lucerne brake lines
Question edited for clarity. Wrong type of Brake - Break. Easy way to remember 'brAke' = Automobile.
They leak because they exposed to water and salt and they rust.
2006-08 Buick Lucerne 3.9L V6 4.6L V8 Complete Brake ...
https://www.inlinetube.com > products > sblb0601
This preformed complete brake line kit will replace all the metal brake lines on your vehicle and includes the master cylinder lines, left front line and right ...
US$251.00 · ‎In stock
https://www.google.com/search?q=2006+Buick+Lucerne+brake+lines
2answers
How do I replace the water pump on a 2006 buick lucerne cx 3.8 v6
first take hose off, or drain from drain plug. antifreeze is what you are draining. Then get a 15 mm rachett and socket and pry tension pully back so you can remove belt. unbolt water pump and take off. Once off clean engine block with razor blade,or something to get old gasket off. put a thin layer of rtv blue permatex on new water pump. Now put new gasket on new water pump on top of the permatex . let dry and set up, this will keep the gasket from moving around when putting back on. follow the process backwards and should b 30 min job . GOOD LUCK YOU CAN DO THIS FOR SURE. ONE OF THE EASIER ONES.........................
How to remove water pump from buick lucerne of 2006?
This should help,
https://www.youtube.com/results?search_query=How+to+remove+water+pump+from+buick+lucerne+of+2006%3F
How to remove engine cover on 2006 buick lucerne
What about the the cxs lucerne which is a 4.6 l motor on the rear water pump the pulley comes to the valve cover you have to pull that pulley out with a puller or what to get the valve cover off because this removing the cap ain't going to do it is that pulley goes all goes right through the valve cover and it don't just slide off very easily so how do you get it off. This is the picture of the front cylinder Bank the rear of it where the water pump belt holds up bolts on to you that's cool you there is what turns the water pump now how do you get that off yet we got to pull it off of the pool right
How to replace water pump on 2006 buick lucerne with 4.7l northstar engine
Remove air box & air tube loosen throttle body 2 clamps disconnect Hoses on pump area remove rear cover 4 10mm bolts from rear of pump disconnect two bolts on housing bottom then 4 bolts on center housing two more are on lower rear between eng & tranny the other two are front lower 8 total remove nut fuel line clamp disconnect Wiring move housing out pump area 2-3 inch disconnect tensioner & remove water pump 5 x 10 mm bolts install new pump & reassemble good look 2-3 hours
1helpful
2answers
Top Buick Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
