Question about Magic Audio Players & Recorders
Need local repair help in Central NJ
Our mic fell and the face came off. In the process of trying to carefully put the face back on a pin broke. I don't want to keep trying and break more pins. What can I do?
we have the Magicsing II
    Problem Solver:
  • 7 Answers
Where is the broken pin located? My suggestion is to buy another Mic. In my experience no matter how you fix it you'll end up getting another problem. Like a Buzz or the mic will start cutting out. Sometimes it'll effect the frequency.
Posted on Mar 10, 2009
I need a wiring digram for a rk 56 inside the mike my wires are broke need to know were to put them back connex 3300hp
  • With the switch sitting as it is in the picture below (actual switch recessed tho the right. Soldier the wires in this order.
  1. Black
  2. Red
  3. Lite Blue.
  4. Dark Yellow (This yellow wire comes from the mic cord itself)
  5. Shield.
  6. Lite Yellow. (This yellow wire runs off to the side of the mike to the electrical components inside the mic)
  • Standard 4 pin Cobra mic tip to run it to that Connex.
  • Pin 1 - Shield.
  • Pin 2 - White.
  • Pin 3 - Red.
  • Pin 4 - Black.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 05, 2011 | Connex 3300 240-Channels Base CB Radio
Tip
DS Lite microphone repair tips.
If your built in microphone on your DS lite is not working then there are
5 things I can suggest for you before you go ahead and buy a new one for replacement.
1) Make sure your volume is up, you may not be hearing it picking up (sounds obvious but worth a try).
2) Use a wooden coctail stick or similar and CAREFULLY remove any lint/fluff that may have collected in the mic slot (be careful not to dig too deep as this will damage the mic).
3) Use a hairdryer on a low setting to dry out any spittle that may have collected in the mic (please be careful not to let the ds get too hot as this will cause serious damage).
4) Test your external mic port by either connecting a mic if you have one and if not get a slither of metal (such as a sewing needle or small/precision flat-head screwdriver) and give it a wiggle in the mic port. (the mic port is the rectangled hole with two metal pins in it net to the 3.5mm headphone jack), if you get a reaction thats a good sign and shows that, if it comes down to it you can use an external mic until you get the problem sorted.
and finally...
5) I must stress that this last tip requires you to have a steady and gentle hand... plus a bit of congidence :).
Use a sewing needle or pin to gently pry the two metal pins in the mic jack upwards, the front of the pins are fixed but further back the pins float, you need to raise these enough to sever the connection these pins are making as when these pins are making a connection they over-ride the internal mic.
If all these five tips fail to work for you then your only option is to replace the microphone, it can easily be done with basic/moderate D.I.Y skills. A replacement DS lite microphone is readily avaliable and cheap on ebay. If you need help with a microphone replacement please feel free to contact me and I will do my best to help you out.
I hope this helps and would like to say I accept no responsability for any damage that may occur to your ds lite when following my tips.
Regards,
SOD69
on Feb 06, 2010 | Nintendo DS Lite Console
I cant insert a ps3 disc to my ps3 after it fell help!
Your blu ray drive is broken. You will need to replace it. You will need to find a local repair shop, the process should only take an hour or less. Don't worry, once the drive is repaired or replaced, you will be back to gaming in no time. If you are handy, purchase a drive (be sure to have the correct model number, located on the back of the unit) and install the new drive. Be sure to remove your blu ray drive's controller board and put it on the new drive once you receive it. There are many things that can go wrong so please do be careful.
Jan 18, 2011 | Sony Playstation 3 (PS3) Console
My ESP AX260 fell face down off the stand and the impact though not very acute broke the headstock and its completely off the body. The fretboard is intact but the Tune O Matic bridge fell off. I really...
I have reattached three headstocks myself as an amateur... I would take your pieces to a Luthier and see what he says about it. The ones I repaired, an acoustic bass required putting in a steel pin to stabilize the joint and some epoxy for the pin as well as the wood glue... an acoustic 6 string required only careful gluing, as did a 5 string banjo...
In all cases Titebond III glue was used for the wood and perfect mateup of the parts was required. Nitrocellulose laquer restored the finish using very fine emery sanding (4000 grit) wet sanding.
The perfect fitup and clamping is mandatory, and the gluing, if done right, will be stronger than the original wood. A key is to have clean LARGE areas of glue contact.
Please do take the unit to a professional Luthier... you should find them in your phone book...
Nov 13, 2010 | ESP Ax260 Electric Guitar
I have a DELL Studio 1737 running Windows 7, with integrated web cam. i am trying to make videos with web cam and video is perfect but no sound on playback. Dell webcam central is what i am using to make...
Sounds like a software issue, possibly with webam central. There's a free player that has good codecs, and it may help you. Here it is:
http://www.finalmediaplayer.com/
This will be an easy fix if it works.
Jul 31, 2010 | Computers & Internet
148 gtl 5pin
Looking from inside the radio at the mic jack, with the nub down. Starting from the left is pin 1, pin 2, pin 3, pin 4, and pin 5.
here is the colors that should be attached to each.
1 is white.
2 is sheild.
3 is black.
4 is red.
5 is blue.
Hope this helps. Take care in soldering. It is easier to reach the pins if you remove the 4 screws that hold the face plate on. Be careful not to pull another wire from somewhere.
Apr 20, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
A Problem Wiht My DS Lite System
Try resetting the Ds lite by taking the battery out for a few minutes then try the mic again.
If this fails the mic has blown and needs to be replaced. This involves taking the unit apart and installing the new mic and cable from it's location in the top screen to the port in the motherboard in the bottom screen.
If you are not handy at repairs i would suggest bringing it to a local repair shop as it is a relatively cheap repair to fix (€20 approx).
Jan 05, 2009 | Nintendo DS Lite Console
No power in the cell phone .
IF your earphone dead plz conform it
r
try to roster your cell phone and then try agin
Dec 05, 2008 | Sony Ericsson K790i Cellular Phone
Parts fell out
WE FIXED IT!!!!! Ok my fabulous husband fixed my automatic thread foot last night and now I am sewing away. Here is what he did best I can describe. when you engage the thread shuttle, a piece comes down from the right of the sewing machine. I has a spring on the back and a very thin piece of wire with a white plastic moving part. the foot has to snap under the white plastic thing... so you have to very carefully take the white thing out of the track and then put the foot in. the bar side with the larger metal pin goes here and the foot should be facing towards the needle. Hope this helps and if I didn;t explain it well please leave me a note and I will try again :)
Apr 18, 2008 | Brother SE-270D Computerized Sewing...
Need to repair gamecube ASAP
  • You don't take care of it.
  • Family member/friend did something to it when it fell down.
  • You use it too much and it overheated and fell down.
Nov 25, 2007 | Nintendo GameCube Console
149 people viewed this question
Top Magic Audio Players & Recorders Experts
Michial Gueffroy
conquer111
Level 1 Expert
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
