Apparently it's not "frost free" any longer. had problem with refrigerator repeatedly trying to go "on" all the time, it fixed itself. now freezer is acting up.
Give it a full defrost like an old fashioned freezer. Take the inside back panel out and look for ice buildup in the cooling fins. Check for any openings where the pipes come in, through the back. There should be NO HOLES.
This freezer is not frost free. Being an upright limiting the amount and frequency of opening the door will reduce the build up of ice. Ice is expected and depending on humidity and quality of seal around door affects the amount of ice.
Using a thin ribbon check the seal integrity around the door. Confirm nothing is prohibiting the full closure of the door.
Adjust door if necessary. Replace seal if defective. Freeze open unsealed items in a frost free freezer before locating frozen food in this unit.
These units are likely located in the garage where the humidity is high. If used only as needed planning transfer between this and the kitchen unit frost can be minimized.
Being a conventional freezer not frost free freezer burn is less likely and frozen food will not dry out as quickly. Confirm that the freezer maintains about 0 degree F.
This unit is likely more efficient and will maintain the food frozen longer in the event of power outage.
Depending how long the power was off you may have an ice blockage in the freezer. Normal cooling causes the freezer coils to build up frost and snow coating all over the coils. A normal defrost cycle melts that frost/snow off and keeps the coils clear so the fans can move air through the coils.During the power outage the frost may have started to melt wetting the snow. If the refrigerator then came on and re-froze the wet frost/snow into a solid block of ice, the normal defrost cycle would not be able to clear that solid ice out. So it may be blocking the air flow. Remove freezer back panel and see if there is ice back there. If yes--use something like a hair dryer to melt everything out until it is completely clear. Make sure the fans are running also.
If this is a frost free unit they actually have an internal heater. If you block the outlet for the cooling air in the freezer the heater cannot sense the dew point temp so it will not activate. Ice accumulates at the dew point temperature. Make sure the outlet isn't blocked. My wife blocks it all the time despite my many warnings not to. It's easier for me to rearrange things than keep repeating myself.
Check freezer and refrigerator door seals, ice dispenser ice door and floor of freezer for ice buildup caused by a defrost drain blockage. If ice door is stuck open it will allow for warm moist air to be drawn inside freezer and collect as frost over everything. Is GTS16BCS the correct model number listed above your post? I will be here should you have questions, Thanks Sea Breeze
Sounds like a defective defrost timer If its a frost free upright freezer and the evaporator is frosting up with a snow like frost you have a defrost problem.. defrost themostate, heaters, or timmmer Also note that Dirty condenser coils are not the problem. It's most likely the defrost timer or defrost heater. The heater should come on about 3 times per day to melt the ice on the evaporator coils. If the defrost timer is not turning on the heater or the heater is burnt out, the coils will freeze up......
You have not defrasted your refrigerator for a longer duration and it has resulted in ice formation and frost formation on th ecoils and even in the back of the freezer.
Please make it a point to defrost the unit atleast once in a week.
Keep the area around the fridge free from humidity and moisture.
If you have sun light around please keep the windows opened for a brief time to allow fresh air to come in and circulate.
Please do not fill the freezer to the full capacity
Please set the theromstate nob to the minimum point during winter.
Defrost circuit problem, the snow means that your freezer coil is not being automatically defrosted. This could be a problem with the defrost heaters or defrost timer. Also in the newer models a module controls this operation. Call for service. Removing ice or snow from the back wall is not the solution. The coil behind the back wall is also frozen and no air is circulating.
Can you give me the make and model # ?
