Question about GNR 19M1 19" LCD Monitor
Monitor goes dead after after switch on after 3seconds
Gnr model f173 flat screen monitor
this monitor will give no display after intiall burst after 3seconds.turn monitor off then back on again the same thing happens allthough the green p[ower led is still on the display The screen not showing any raster even though the monitor is on. Please can you help. Thankyou
GNRItem model numberF173 -PScreen Size17 inches
i need power supply for this lcd monitor
+923003431239
Posted on Jan 28, 2013
Hi
i have a GNR F173 flat screen monitor when first turning it on the green light just flashes on and off with a picture for around 1min then turns on fully and stays on and works fine until it is turned off again
does any one no what componant whats replacing
Regards Annette
Posted on Dec 21, 2009
  • 109 Answers
CCFL backlight may be busted.. also ccfl inverter may need repair or replacement too..
Posted on Mar 09, 2009
GNR TS902W monitor start up problems
GNR TS902 19 inch flat screen computer monitor with 3x4 aspect ratio
Difficult starting or completely dead:- (This is a 'Stock Fault' with these otherwise excellent monitors)
Check or replace the electrolytic capacitor C829 - type 1000MFD 16 Volt DC Wkg It sits on the PSU board next to an empty "C817" mounting point (which is for a device wired in parellel) so you can fit two smaller ones (of ~ 500MFD each) . . I suggest replacing it (C829) with a 1000MFD 25 VoltDC Wkg type.
Also (very much less frequently) capacitors C802 - 470MFD 50V VoltDC Wkg and C819 680 MFD 16 VoltDC Wkg are faulty.
Jul 08, 2014 | GNR 19M1 19" LCD Monitor
I have a number of gnr ts902 monitors which don,t come back on when I reboot the computer until I remove the power from the monitor and reapply it. then the monitor works ok
Check or replace the electrolytic capacitor C829 - type 1000MFD 16 Volt DC Wkg It sits on the PSU board next to an empty "C817" mounting point (which is for a device wired in parellel) so you can fit two smaller ones (of ~ 500MFD each) . . I suggest replacing it (C829) with a 1000MFD 25 Volt DC Wkg type.
Also (very much less frequently) capacitors C802 - 470MFD 50V Volt DC Wkg and C819 680 MFD 16 Volt DC Wkg are faulty.
Good luck
Jul 06, 2011 | Computers & Internet
How can i change the preset resolution of my gnr ts900 monitor.the resolution is set to640x480. this is insufficient for my new radeon hd5450 graphics card.
The video resolution setting is done AT THE MONITOR DISPLAY PROPERTIE SETUP, not at the monitor. The video card driver is up to date?
What OS are you running?
If you are running Windows 7, you need to find driver for this model.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Jun 30, 2011 | GNR 19M1 19" LCD Monitor
My GNR F173 makes a squeky noise when switched on and the screen goes black. After switching on again (several times) it works fine. Can this be fixed? Will it be worth the cost if it can?
gwyn1william, Monitor printed circuit components are all "working" !!!! That's good!! You need to see video clips at YOUTUBE!!! Learn how to do soldering. Then use very large magnifying glass or use inspection grade microscope (4x to 20x) to find the 1 maybe 2 "hairline fractured,thermally intermittant" solder connection of the leads of the devices (active or passive) which are causing this condition and will need to be resoldered. ($20 or less DIY) ($40 to $80 contracting out the work) Then and only then return to fixya and rate this as to it's usefulness to you in solving monitor problem. 12fixlouie
Sep 13, 2010 | Gateway FPD2275W LCD Monitor
Screen just flashes then blank screen
laptops.promo.web.id/toshiba-laptop-screen-goes-black-randomly
Aug 02, 2010 | GNR F153A (Black/Silver) 15" LCD Monitor
Black screen
You have bad El-condensator on secondary side of power supply.
Oct 06, 2009 | Dell UltraSharp 2000FP 20.1" Flat Panel...
Monitor gnr ts 700 driver
GNR Corp Ltd. (UK) Support Q, How do I install/reinstall my GNR monitor drivers? A, Check the link on the GNR website: wwwgnrintl.com. Q, Where can I find the latest drives for my GNR ...
www.amtiva.com/client/gnruk/support/faq.html
Oct 06, 2008 | Computers & Internet
Vison 19 inch monitor
when you tried it on the laptops did you make sure that you went into the dispaly properties and checkd the extend my desktop on this monitor if nto it wont do anything anyways
May 18, 2008 | TDV Vison F173 17" Flat Panel LCD Monitor
GNR F173 172 monitor faulty
I think this is the problem of blanking section change the horizantal and vertical blanking transistors.placed near eht.normaly 700 in series and connected with vertical output ic.if they are ok then change vertical output ic.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 17, 2008 | Gateway FPD2275W LCD Monitor
GNR 19M1 19" LCD Monitor Logo
803 people viewed this question
Top GNR Computers & Internet Experts
David Payne
David Payne
Are you a GNR Computer and Internet Expert? Answer questions, earn points and help others
