Question about Olympus FE-170 Digital Camera
The screen comes on in scene and guide mode but when i switch to any photo mode i can't get a view. the little light at the top stays orange. will not take pic
When i turn camera on it will not illuminate the back screen. if i change it knob to scene or guide mode it works fine and i can scroll through the options with ease. when i hit ok to change it over to taking a photo, all goes dark and the little orange/green light stays on orange. if i press the other button at the top for review, it goes right into review mode and the screen comes on again. please help. i bought it used and am wondering if i just got ripped. also, does it have any kind of internal memory? i've found that my regular memory card does not fit into this camera. whats up with that? what size card does it need?
4 Suggested Answers
SOURCE:
Jeap
  • 114 Answers
SOURCE: write protect
just open the card cover and press quick view and ok at the same time, and reset the camera. if that donĀ“t solve it may need to replace the mainboard
Posted on Feb 28, 2007
SOURCE: olympus mji 700
sameeee problemmmm!
Posted on Oct 19, 2008
gwcoan
  • 49 Answers
SOURCE: Hi, My Olympus SP570u. camera was working fine
Sounds to me like a circuitry issue if the camera has not been dropped or been in prolonged contact with moisture. An authorized Olympus camera repair shop is the only option I can offer. You might try resetting it by removing the battery for thirty minutes. Then reinsert the battery and try again. If there is no change, head for the shop or contact Olympus directly through www.olympus.com/contact
Posted on Oct 30, 2010
Focus circle clear but surrounding area appears hazy
This is often the result of little available light on the focus screen. The more ambient light (and more open the aperture is) the brighter and sharper the image is in the viewfinder. Less light effects the image in the view finder and makes it harder to see and focus.
If your lens only opens to f3.5 or 4.0 and you\'re trying to shoot indoors with available light - your lens may not let enough light into the camera to see the scene as well as you can with the naked eye. An f1.4 aperture lets eight (8!) times as much light as an f4.0 does and is why they\'re so expensive.
Try the same setup in a brightly lit (sunny day) scene to see if it goes away.
Apr 06, 2014 | Nikon FG 35mm SLR Camera
My polaroid iS2132 won't change settings when I turn the mode dial/Can't set the intelligent scene mode.
When you put the Mode dail to the SCN mode, It will enter the last used Scene mode. THEN press the MENU button to select other scene mode.
Don't turn any dail. Use the navigation controls left and right from the OK button, to move through the section. Press OK button to save and activate the selected scene mode.
Success
Nov 17, 2013 | Polaroid IS2132-BLACK 16MP 21X Zoom...
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
I can't find how to Cascade on Elements using "Expert Mode" Where is Expert Mode?
Modes are listed on the main screen of Adobe Photoshop Elements. Simply click on EXPERT to get into the expert mode.
The Expert mode has tools to correct color problems, create special effects, and enhance photos. The Quick mode contains simple tools for correcting color and lighting, and commands to quickly fix common problems, such as red eye. The Guided mode contains tools for basic photo edits, guided activities, and photographic effects. If you are new to digital imaging, Quick or Guided modes are a good place to start fixing photos.
If you've worked with image-editing applications before, you'll find that the Expert mode provides a flexible and powerful image-correction environment. It has lighting and color-correction commands, along with tools for fixing image defects, making selections, adding text, and painting on your images. You can rearrange the Expert workspace to best suit your needs. You can move, hide, and show panels, and arrange panels in the Panel Bin. You can also zoom in or out of the photo, scroll to a different area of the document window, and create multiple windows and views.
Oct 25, 2012 | Adobe Photoshop Elements 9
There is a delay between pressing button and photo being taken with my samsung s7000. The delay means that the subject (child) is out of view by the time the photo is taken.
Hi Susan, and welcome to FixYa-
I have had the exact problem that you are describing, albeit a different make and model of camera. Here's how I solved my issue:
I grabbed the nearest heavy object and smashed the camera....
No, but seriously, try this:
The S700 has the standard "Scene Selector" knob on the top. Make sure that this is NOT pointed toward (set to) the "Self Timer" option. The icon for this, on the camera's body, looks similar to the "Auto" setting icon.
The S700 has 3 timer modes: a 10 second delay, 2 second delay and a "Double" mode wherein the camera waits 10 seconds, takes one picture then, after an additional 2 second delay, will take a second picture. The delay must be selected by the user and will appear in your LCD viewing screen. Prior to taking a test picture, look in the display screen to see if any numbers appear. If you see any, you know that the camera is in the Self Timer mode. Simply rotate the button on top of the camera to the "Auto" icon and you'll be all set.
Good luck, and let us know how you go!
Aug 10, 2011 | Samsung Digimax S700 Digital Camera
Manual that came with camera does not explain symbols for setting the mode. Amazing! What do M, A,S,P, N and SP 1 and SP2 stand for? the only things I understand are Auto and Panorama.
M stands for 'Manual mode'. This is the mode wherein you set your shutter speed and aperture setting. A stands for 'Aperture Priority'. This is the mode where you set the aperture or opening of the lens and the camera sets the shutter speed. The lower the aperture number setting, the more light penetrates the lens, a faster shutter speed is needed. This setting is usually used for portrait scenarios. S stands for 'Shutter priority'. This is the mode where you set the shutter speed and the camera sets the aperture. The higher shutter speed number, the lower aperture number is set by the camera to accommodate more light into the lens. This setting is usually used for capturing moving objects like cars. P stands for 'Program Mode'. The camera takes care of different settings except for the aperture and the shutter speed. You get to choose combinations of aperture and shutter speed settings that will not change the exposure of your scene. This is like a combined 'A' and 'S' mode with different combinations. N stands for 'Natural Light'. The camera tries to make use of available light. This is ideal for indoor use when flash is prohibited or when you just want to capture the ambiance of the scene. The camera sets a high sensitivity setting to handle low light conditions. The drawback of this would be grainier pictures. SP1 and SP2 stand for Scene Position 1 and 2. This is like a memory setting for most commonly used scene settings. For example, you can assign SP1 for landscape mode scene and SP2 for night mode scene. You have 13 scenes to choose from in your camera, 2 of which you can assign in SP1 or SP2. The default setting for SP1 is Portrait mode and for SP2, it is Landscape mode.
Hope this helps.
Apr 15, 2011 | Fuji FinePix S1000FD Digital Camera
When put power cable in orange light comes on power button and wont boot up
Sir,
Orange light usually comes only if your system stays in low power mode or sleeps, So u get orange light immediately when u switch on the system, try pressing the ESC Key on the top left corner of the Keyboard, and if not try pressing the power button again...
If not working,tell me Whether do u get any sounds in system?
Your system Operationg System?
And What u get on the screen, when u switch on?
Thanks, Regards
Vinod
Jun 29, 2009 | Dell GX270 P4-2.8 512/40/24X/XPP/NONE...
My sony
I can fix your camera, it is not an easy thing to post because the post would be forever long....
$20 and it would be good as new.
Jul 12, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Whitebalanc; red cast over pictures
Greetings...
The red or orange cast comes from a warm light source since you have the auto white blance off...
Got to your menu and turn the auto white blance back on and then try taking the same picture under the same lighting and see if that corrects your problem...
Ed
Apr 08, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Wont take photos outside
The symptoms you're describing could be caused by either the "Fireworks" special scene selection mode, or manual mode with too much exposure compensation. Look at your mode selector (back of the camera, upper left hand corner). Is the mode set to the still image setting (pointing at the liittle red camera)? Or is it set to special scene selection (SCN)?
If you are unintentionally in SCN mode, to get it out of "Fireworks", just turn the mode selector dial to select "still image" (pointing at the little red camera). Or you can also select an SCN mode more appropriate for outdoors. Just turn the dial to SCN, press the FUNC button, then press the left/right arrow buttons to select Portrait, Beach, Snow etc...
But if your mode selector is already in still image selection, then check to make sure that you're not in "Manual" picture mode. Turn the mode selector dial to "still picture mode" (pointing at the little red camera), then press the "FUNC" button. Now look at the bottom of the screen. If it says "Manual", press the "left" button controller once to select and put the camera in "Auto" still picture mode.
Feb 29, 2008 | Canon PowerShot A400 Digital Camera
Olympus FE-170 Digital Camera Logo
157 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
