Question about Roper RAS8445KQ Top Load Washer
The load will stop at after it fills with the rinse water, I have to restart the load. it sounds the the dail/ timers not working.
  • 163 Answers
You have a bad lid switch or your drive coupler is broken.drive coupler is located between motor and transmission.you can take a pen and push your lid switch down and up and see if you hear it clicking(like on and off) if you dont hear it or feel it clicking on and off then your lid switch is bad.both are easy repairs and not too costly.
Posted on Mar 09, 2009
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Periodically our KitchenAid washer will fill for the Rinse cycle but then will not begin to agitate. Sits there with tub full of water. We have tried different water levels and it will fill to the next...
it sounds like the timer needs to be replaced. if it is a top load washer with the control panel upright and in the rear. you can get to the timer and remove it, take it into a repair shop for testing. possibly a replacedment. if you mark all of the wires to what location they are connected, then it will be fine. a pro can tell you whether the timer is faulty or not, which in this case it sounds like that's what the problem is. thanks
Jul 07, 2011 | KitchenAid Washing Machines
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    Stuck in spin
    Hi!
    If the Washer is stuck in spin then either the timer or a cold-water supply problem is causing this :
    It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance, then you need to replace the timer.
    Do rate the solution as FixYa and revert for further clarification.
    Thanks
    Rylee
    Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Kenmore front-load washer stops at rinse cycle
    When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
    Mar 03, 2009 | Kenmore 43142 Front Load Washer
    Washing machine fills with water & that's all it does
    sounds like the timer has bit the dust,time to replace it.this is fairly simple to do.if you decide to do this yourself,make sure the unit is unplugged,& swap the wires to the new timer one at a time(noting their location)if your not comfortable with this,then call a service tech.hope this helps.thanx for using fix-ya!!!
    Nov 26, 2008 | Kenmore 22422 Top Load Washer
    Will only work on cycle, will not agitate in the other cycles
    Thanks for your question You say it works on one cycle but not the other lets sat you start a regular wash ,the washer should fill ,wash for the minutes you have set, pump out the water #spin , Stop fills & rinse stop pump out water &spin If you try a delicate cycle and it does not do what it did on regular cycle . You have a timer problem . Thanks for your question hope i helped you solve it . THE APPLIANCE DOC
    Sep 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Roper RAS8445KQ Top Load Washer Logo
    44 people viewed this question
    Top Roper Washing Machines Experts
    Dan Webster
    Dan Webster
    Mike
    Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
