Question about Brother HL 1440 Laser Printer
My page is printing with a blank line down the right hand side.
    Guru:
  • 829 Answers
Most likely cause is a driver setting NOT a printer setting, especially if it's 1 used on a networked printer.
You list the paper size in tray as lettre (so I assume you are in USA)
make sure the printer driver is set to match this size, and that the document size in word is set to this also.
I can't recall if it's letter or A4 is slightly longer, but if either way 1 is slightly longer and narrower than the other. So if printer and driver are not set to match it could be throwing line feeds in odd places.
Try a print from a different application, for example, does a windows test page throw a spare page afterwards ? If you print 2 pages worth of raw text from Notepad does it throw extra pages. If yes, then remove printer driver and reload it CHECKING all the settings, if they previously looked OK, if you found a setting in driver looked wrong, try that first.
If it still does it, try installing driver on a different PC (laptop?) and test from there, if it still does it contact local HP support team, if it doesn't then look into software setup on the "problem" machine.
having spent 5 yrs fixing printers I can assure you most problems of this nature are simply a driver setting, or a printer option setting, or can even be the paper tray guides not set right, so middetecting paper sizes.
Posted on Mar 09, 2009
SOURCE: Print fading down right hand side
I was able to fix it by taking off the top of the printer. This involved taking off 4 screws on the top of the printer. I then had to disconnect the wires going to the control panel by unhooking them from the right side. I then located a thin rectangular box which I'm assuming houses the laser. I removed this with 4 more screws and turned it over. There was a little metal flap that I moved back and below was the mirror the lasers shoot on before going onto the toner.
In the same spot where I was having fading, I noticed a lot of toner on the mirror, so I cleaned it of, put it back together, and the fading was gone.
This was after I tried a new toner and maintenance kit.
Hope this helps
Posted on May 01, 2008
Bubbabear64
  • 2794 Answers
SOURCE: RICOH AFICIO 1022 ADF scanning with a black line down right-hand side
There is a tiny spec on the scanner glass. Cleaning it will make the line go away.
Posted on Jul 11, 2008
  • 14 Answers
SOURCE: Striped line down right hand side of printout
all parts are ok just clean the printer it will work
Posted on Dec 02, 2008
rioglen
  • 95 Answers
SOURCE: black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Posted on Sep 23, 2009
  • 43 Answers
SOURCE: Kyocera Mita Ecosys PS 1010 all prints have thick and thin line
Try cleaning the charge wire. Move the lime green plastic handle from one side of the image unit to the other in the groove. If this doesn't work you'll need a new image unit.$$$$$. note: Make sure green handle is moved completely to the right when finished or black line will occur.
Posted on Feb 12, 2010
My HL2040 printer is printing black vertical lines along the right-hand side of the page, about 3" or so. A month ago I took it apart and cleaned the roller. Still doing it.
If the lines go all the way down the page, check the position of the corona wire cleaner tab (blue or green) at the top front of the drum unit. if not parked fully to one side it will create a solid black lines where it blocks the laser. Otherwise look for some other foreign object (or torn paper piece) that may be blocking the laser from the drum. If the lines are thin and shark, check for scratches on the drum (not repairable without replacing drum). If the lines are uneven thickness but in a pattern that repeats down the page every few inches, then the film on the drum is probably worn or wearing away and the drum needs to be replaced.
Mar 04, 2015 | Brother HL-2040 Laser Printer
My printer is printing black horizontal lines down the right side of the paper - what is wrong?
Needs Drum If you pull the drum unit out you will see on the drum different shades of color lighter is wear the lines come from. Buy a rebuilt drum much cheaper and they work, may have to reset the drum count if the change drum lite on...
May 02, 2014 | Brother MFC-8460N All-In-One Printer
Canon pixma mx516
"I did get pages stuck and had to pull them" That probably is what caused the misalignment. Maybe some part got bent. PIXMAs can be rather delicate.
Jul 14, 2017 | Canon PIXMA Office Equipment & Supplies
Konica Minolta 2430 DL has Smudges or dots on page
Not an expert on this brand of printers but it looks like dirty feeder rollers to me. Try cleaning them and Print a Blank document and see if the marks show up
Jan 24, 2014 | Konica Minolta magicolor 2430 DL Laser...
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
I have a problem with my printer hp 1018 only print white pages please help me
I seems like you have snaped the pin is broke. if you open the printer on the right hand side there is a little hole with leaver in shove some folded paper in it and close top. the leaver has to be pushed down for the printer to work. if the leaver is not down it will print blank pages.
Sep 24, 2010 | Office Equipment & Supplies
Toner is printing on right hand side of each page printed
Most likely it is the drum cartridge. The other causes such as toner on the laser optics would not produce an on again off again print area. It would be blank the entire way down the page. Since the toner prints in patches down the right side it means it is coming from something that is "rotating" and that narrows it down to the drum.
Good Luck and Thank You for using Fixya.
Mar 31, 2010 | Dell 1700 Laser Printer
Kyocera Mita Ecosys PS 1010 all prints have thick and thin line down left hand side A little while back the printer started printing completely black sheets. Fixed by turning off and then on again. Since...
Feb 09, 2010 | Office Equipment & Supplies
Intermittent blank stripe down Right Side of page
Open the top cover, lift up the PCU lever & remove the PCU. Rotate the carousel (Toner holder) by hand and check that all of the toner levers are locked down fully. Check if any of the toner levers are loose and possibly moving as the drum is rotated. There is a small clear plastic flap below each cartridge, it is possible that one is fitted incorrectly or even missing allowing toner to leak past and fall on to the laser lens thereby blocking the laser and causing these symptoms. Hope this helps.
Feb 02, 2009 | Epson ACULASER CX11NF All-In-One Printer
Brother HL 1440 Laser Printer Logo
784 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
