Question about HP OfficeJet J4580 All-In-One Laser Printer
I am having an issue with getting the first ink cartridge in
I am having an issue with getting the first cartridges of ink into a HP J4580 printer. This machine is making me feel incompetent. I cannot get them to insert at all. Are there any tricks to this?
  • 127 Answers
Take a look at this site it should be able to help with replacing the ink in your printer
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01429130&cc=uk&lc=en&dlc=en&product=3645100
Posted on Mar 11, 2009
How to change cartridge of HP J4580
There must be a way... Usually HP printers have schematic how it is to be done. Those are in a litlle book that came with printer.
Apr 22, 2014 | HP OfficeJet J4580 All-In-One Laser...
How do i find ink levels in Windows 8 for HP Office Jet J4580
It depends on what type of ink cartridge you have installed.....with HP genuine ink cartridges and HP Solution center installed, everything should be there. However, if you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels will not be displayed nor can they be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena.
NOTE: These types of 'SEVERE' cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
HP Officejet J4500 J4600 4500 Printer Error Messages -HP 901 & 901XL Cartridges
http://www.youtube.com/watch?v=RivHgvWCkJ8
HP 901 & 901XL Ink Cartridge Alerts - Low Ink Warnings:
http://www.youtube.com/watch?v=hzLM5mlkTt4
HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
HP Officejet J4500 J4600 4500 Cartridge Error Bypass - HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
HP 901 Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
Apr 12, 2013 | HP OfficeJet J4580 All-In-One InkJet...
HPoffice jet #J4580 printer wont recognize Costco refilled Cartridge
This model HP printer may only let you use genuine Canon/Epson printer cartridges. If you try to refill these ink cartridges it will not work because the HP cartridges have an embedded chip in the cartridge that detects the empty cartridge even though it has been refilled.
Mar 28, 2013 | HP OfficeJet J4580 All-In-One Laser...
The exclamation mark is on and the screen is flickering hp j4580 officejet all in one
A flashing exclamation mark is typically associated with a sever cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. Have you tried replacing the ink cartridge with a new HP genuine cartridge to confirm?
NOTE: The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
Jan 10, 2013 | HP OfficeJet J4580 All-In-One Laser...
How to reset ink levels from HP J4580 printer refilled 901 wont show ink level comes up as empty
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jan 10, 2010 | HP OfficeJet J4580 All-In-One Laser...
I am receiving the ?Print cartridge problem-[Tri-Color] refer to device doc. to troubleshoot.? Error message on my Hp j4580. There is no help in doc and nothing I?ve tried (cleaning etc.)works. Should I...
I had the same problem. I called hp and spent an hour running through the troubleshooting things that I'd already done. They ended up sending me a new ink cartridge, and surprisingly, it worked. For some reason, the printer refused to recognize a nearly full ink cartridge. Go figure. It seems to be working for now, but it's a huge waste of ink and money. If you have the patience for it, call hp and see if they will replace your cartridges.
Sep 23, 2009 | HP OfficeJet J4580 All-In-One Laser...
When I print documents, approximately every fifth line is missing in the document. The printer is an hp J4580 with new ink cartridges. I have reloaded the driver many times from the CD and even from the...
check the scanning plate. sounds like something is blocking imaging. Other than that, i could have you take your ink cartridges and shake them up before placing them in the printer. As ink cartridges sit on the store shelf, they actually can develop 'dry spots' and they never tell you to shake them, but it helps. but in your case, sounds like something is in the image copy area of the machine and needs to be cleared.
Aug 12, 2009 | HP OfficeJet J4580 All-In-One Laser...
Print cartridge problem: tri-color
lestave my j4580 trouble lt says ck blk cartrige
Jun 09, 2009 | HP OfficeJet J4580 All-In-One Laser...
My hp officejet j4580 says incompatible black ink cartridge
I've been in print cartridge hell since I bought a J4580.
I spent an hour on chat with HP customer service and was able to resolve the problem by partially resetting the printer. Here's how:
  • Make sure your print cartridges are installed.
  • Unplug the machine, wait 20 seconds
  • Press and hold the # and 3 keys
  • Plug the machine back in
  • You'll see a reset message on the machine, release the # and 3 keys
  • Follow the prompts to set the language and location
Cross your fingers, hopefully your printer will print now!
Apr 11, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Refilling of canon ink fine cartridge pg 41
you must buy a brand new cartridge do not refill your old cartridge and use it again it may cause malfunction of your printer..one thing you have encounter is " the cartridge is not recognized"
Feb 15, 2009 | HP Office Equipment & Supplies
HP OfficeJet J4580 All-In-One Laser Printer Logo
121 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
