Question about Toshiba 2060 Copier
Have toshiba 2060 copies are coming out with gray and blk stripe
I have taken it apart myself and cleaned off the mirrors and glass as well as cleaning the drum, it got a little better for a while, but this is a physicians office and the copies are aweful. I need help. I also tried contacting a place to see if they could come help but the closest is 2 hours away... Is there anywhere else i could contact that could set me up with someone who could possibly help.
    President:
  • Toshiba Master
  • 990 Answers
Hello sir; Everything you can clean but drum, that's most sensity part, UNTOUCHABLE , I believed you damaged the drum already, go change one meanwhile change cleaning blade too.
Posted on Mar 09, 2009
2007 Chevrolet Silverado z71 1500 passenger mirror wiring: Mirror has Gray; Orange; White; Yellow; Gray wires; Truck has Gray w/blk stripe; Orange w/blk stripe; White; Black; Black. How to pair?
standard mirror wiring diagram shows light green, tan, white, black, dark blue/white, orange, black so somthing is off with your description. There are 3 possible mirrors on that year and the other two have even more wires.
May 09, 2018 | Chevrolet Cars & Trucks
Copies come out with gray streaks all the way through the entire page
if you are copying through the feeder check the small glass under the lid has not got any typex or ink stuck to it you check by placing a copy on the glass under the lid and do a copy here.. if no streaks apear then check the glass area.. also if you are printing to it and no streaks appear this area is the cause.. if it happens on teh print side too then you have a drum /dev wear issue and it may need replacing.
Jul 12, 2010 | Toshiba 2060 Copier
Savin 2545 document feeder gives a gray band on the copies
Yes - surprisingly - we had the same problem, the gray stripe along the side of the page only showed up when the original was fed through the document feeder on top. Cleaned the small area of glass under the feeder repeatedly with no change to the resulting stripe, but then while cleaning the upper roller, above the area of glass where the scan lamp illuminates during the copying from the ADF, we found a small piece of paper adhering to the top roller in the paper path, cleaned it off, and no more band. We didn't see the bit of paper on the upper roller until we rolled it while cleaning. Still can't figure how that made a stripe....but hope this helps you.
Feb 22, 2010 | Savin 2545DP Black and White Copier
GRAY STRIPES ON COPIES
clean the glass. it must have streaks
May 28, 2009 | Canon imageRUNNER 210S Copier
Leaving a black line at the top of the page
make sure paper guides are secure other then that could b dirty optics (mirrors under the glass) or drum / fusing unit
Feb 26, 2009 | Toshiba 2060 Copier
Wireing dia for cdx l400x
if your wires are white\w blk stripe gray\w blk stripe green\w blk stripe purple\w blk stripe the white and gray is front's green and purple are rear's white is right gray is left green is left purple's right
Dec 14, 2008 | Car Audio & Video
How to change developer on Toshiba 2060 copier?
Changing the developer is a procedure for service technicians to do.  You might want to ask that question on copytechnet.com.  There are Toshiba service technicians on that can help you with that.
Sep 13, 2008 | Toshiba 2060 Copier
Copies have gray background.
Have you had the optics cleaned resently? If not Iwould start with that and make sure you have the copier unpluged and don't forget to clean the two mirrors under the Black Box/cover. It could also,mean that you need a new OPC drum and blade.. It depends on how maiy copies are on the copier and drum...
Sep 04, 2008 | Toshiba 2060 Copier
147 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
