Question about Dewalt D26441 Heavy Duty 2.4 Amp 1/4 Sheet Palm Grip Sander With Cloth Dust Bag
I have a d26441 sander. No instructions. Are the
I have a d26441 sander. No instructions. Are the plastic tabs supposed to be broken off for the vacumn to work?
Hummer
  • 1 more comment
  • theosbornes Mar 09, 2009
    Dear Rowdy 45176
    The clerk at the store said that the plastic tabs under the sandpaper holes should be punched out. Store going out of business and the sander was last one in store. No box no instructions. Do not believe clerk, but not sure.
    Thanks
    the osbornes
  • David Ford
    David Ford May 11, 2010
    what plastic tabs are you talking about. You should not have to break anything for the vacuum to work. Make sure that you use the right paper
  • Anonymous Mar 14, 2014
    Dewalt d26441 sander does not spin freely even when motor is removed from sander it still toils and snags it also smokes a little
  • 2,176 Answers
Do not break anything. Go to Dewaltservicenet.com and type in your model number in the middle of the page at the bottom and download a user manual for the tool. It should have come with what is called a punch plate to perforate the sandpaper for dust pickup (such as it is) Go there first and you will find everything that you need to use the tool
Posted on Mar 10, 2009
My D26441 sander stopped vibrating during normal use. Motor still on & getting hot.
motor /armature problem
could be worn out brushes
take it in for an inspection and quote
May 20, 2017 | Sander Tools & Hardware - Others
Palm sander not vibrating
Only real way to find out what is wrong is to open it up on this one. They are mostly plastic parts and you will probably find the broken part or where a gear is worn out.
Jul 04, 2016 | Ryobi Tools & Hardware - Others
I keep getting shocks from skil pp gf30 palm sander
The case should be plastic and the sander is supposed to be double insulated. About the only way to get a shock is from a damaged power cord. Check for splits or exposed wire where the cord enters the sander.
Feb 19, 2014 | Drills
Where to apply grease
There are no parts in your sander to grease. The only place there is grease is in the three sealed bearings on the armature and in the platen. Everything should be clean and dry inside the sander to make it less likely for sawdust to stick inside the tool. Blow everything out and replace the bearings if they are not turning freely and smoothly.
Dec 01, 2012 | Dewalt D26441 - Palm Sander, 1/4 Sheet
Bosh B7350 Belt Sander not working
Did you pull the plastic cover on the left side to see if the drive belt has broken? I think the cover is held on with only one screw.
Jul 15, 2012 | Tools & Hardware - Others
I have a power devil belt sander, but every time i turn it on for use the belt works its way off... i bought this sander second hand at a boot sale so im thinking is there supposed to be an outside guide...
no there is not anything missing, you need to adjust the belt by turning the black plastic adjuster knob which guides the belt to the left. I have found that whilst using the sander you sometime need to adjust it further. If you adjust it too much the belt will hit and grind the plastic casing of the sander.
Also make sure you are using the correct size belt as it should be size 75X533 which you can buy from Toolstation for £2.78 a pack of 5.
Sep 03, 2011 | Electric Power Belt Sander, 3" X 21" 700...
Heater and Air conditioner work bur air flows from window vents only. Can't change direction of air flow to different vents.
There may be a couple of items to look at here.... but the most common problem is a source of vacumn to the pneumatic operation of the heat/a/c vent doors....if vacumn is not distributed properly to the vents you command it is assumed that there is either no vacumn to the selector swith panel(broken vac. line,kinked vac. line, defective in dash a/c control panel) or under the hood a defective vac./heater control valve that is stuck,frozen, not allowing the vacumn to pass through it to supply the indash pneumatic controls and/or panel.
Most vacumn systems that i have ever came in contact with incorporate a vacumn supply tank(nothing more then a round plastic vac. resevoir) which is used in sequence with the a/c heater controls, its purpose is to keep an even vacumn supply to all command points continously while the vehicle is being driven, without this supply one will experience the a/c coming from various different non selected dash vents upon acceleration, this is a direct relation to the tank either being defective(leaking vacumn) or its supply hose(usually vey tiny rubber/plastic tubes) being pinched or broken not allowing the vacumn to the supply tank.
listen for vacumn leaks(hissing sound), look for the obvious...broken vacumn lines or hoses, also check for a defective one way vacumn valve on some pneumatic controlled door vent systems(these valves are inserted in a vacumn line one side being the ""in" port and the other side of it being the "out" flow port,typically if these dont work the vents will also devert your a/c or heat all different ways through your dash.
to check these valves, simply remove from the vacumn hose, and apply vacumn to one side,if vacumn flows through the valve, apply the same vacumn to the opposite side of the plastic valve, if vacumn flows through on the opposite side the valve is bad, it should only allow flow from one side not the other. These valves are small and are usually white or black plastic and look like the old vacumn dash pots used on the old carbureated engines only smaller with one small hose in and one small hose out.
May 16, 2010 | 2004 Buick Rainier
The motor buzzes slowly, it seems to be labouring and the plate rotates very slowly. Its as if the motor is blocked up inside. I've taken it apart and removed as much fine dust as possible but this hasn't...
sounds to me like the bearings are locking up, you can go to Dewaltservicenet.com and type in your model number and download a parts explosion for this tool so you can see the replacement part numbers. when you had it apart did you see any indication that the field was rubbing on the armature?? I would take a close look at the bearings though.
Jan 23, 2010 | Dewalt D26441 Heavy Duty 2.4 Amp 1/4 Sheet...
Replacing broken cable on Porter Cable 7800 sander
just have to take off the plastic flexible casing it is screwed to the head. then you can pull the old wire out, if it it broken take out the plastic bellow and the 2 screws that are underneath that. then u can pull the remain of the old[broke shatf wire. To unscrew the casing use a plier and hold the metal piece not the plastic or u will broke it. \ REMENBER THE CASING IS NOT THE VACUUM HOSE IS UNDER IT.
Jul 27, 2009 | Porter Cable 7800 Drywall Sander With Dust...
No sanding action and motor just buzzes
It will probably be the shaft from the motor to the orbital cam which is on the flat plate that you connect the sandpaper to , either the shaft or the bottom cam is broken [probably the shaft has snapped ] you can do a cheap repair with a good glue to reconnect the shaft [but you wont be able to push too hard again] or if you can get the parts just replace the shaft into the motor . they are really simple things to work on
Mar 30, 2009 | Dewalt D26441 Heavy Duty 2.4 Amp 1/4 Sheet...
Dewalt D26441 Heavy Duty 2.4 Amp 1/4 Sheet Palm Grip Sander With Cloth Dust Bag Logo
147 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
