Question about Saeco Vienna Espresso Machine
Grinds beans, won't dispense water sometimes
I have a Saeco Vienna Deluxe that grinds the beans, but on occasiona no water comes out to make the coffee. The steam wand works just fine, and we have run the cleaning solution through it recently. A few days later, it will make coffee perfectly and for a week it will be fine. Then one day, it suddenly won't dispense the water to make the coffee again. We let it "rest" for a few days and then it works again. What is wrong and how do we fix it? I need detailed instructions, as the instruction manual and Saeco customer service personnel haven't provided me instructions about how to fix this particular problem.
  • 3 Answers
I just had this problem. I took apart the brew chamber and cleaned under the screens and everything else I could get to along the path of the water. These areas were completely filled with gum residue and solids. I'm guessing that when they dry out, the water can pass through for a little bit. After a cup or two, they go back to blocking off the water flow.
Posted on Apr 10, 2009
No coffee coming out. i hear it grinds but no water coming out. i primed but to no avail. i do get ground dry beans in the resovoir
Hi
Turn your small knob down in the bean hopper. You are putting to much coffee in the brw unit. The + / - knob has to be turned down 1 mark or click.
Nov 26, 2010 | Saeco Vienna De Luxe Espresso Machine
I just received a used Saeco Vienna SuperAutomatica and I can not get coffee to brew. Drive grounds are shot into discard bin
HI
You must have 2 knobs in the bean hopper, or the grinds are more like French Press (very large grinds) If yoou just have 2 knobs turn the small one towards the minus (-) a little, and see idf that helps. If you hqve very large grinds you grinder has seperated and needs to be replaced.
Oct 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna. Wet cofffee grinds in the dump box.
It could be the grind on the coffee or the red group o-ring and the 2 o-rings on the white plastic valve need to be replaced.
Nov 05, 2009 | Saeco Vienna De Luxe Espresso Machine
Grinder settings for Vienna Deluxe
Hi
To start off with, you should not change the big knob unless the grinder is operating at the time.
Set the small knob to the middle position. You can move this any time. Move towards the + mark to strengthen the coffee, but never all the way to the full +.
Set the big knob to the #8 to start off with. Move it 1 # smaller to make the coffee stronger but be careful not to get it to fine as you will clog the grinder and you will have to take it apart to clean. If you ever get an out of beans light, but there are beans in the hopper, open the knob to #16 for 1 cycle, then turn it back down to a # 1 larger than you had before and leave it unless you get the message again. Shiny beans call for a coarser grind than a dull bean because of the oils in the coffee bean. Oils will cause the grinds to stick together and cause clogs faster than beans that have less oil.
Jul 16, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna grinds too much coffee.
Hi
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
Jul 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Hot water
Grinds are too fine and or the coffee chute is clogged.
Feb 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
The water is not adding to the ground beans , is it plugged?
I haven't seen a Vienna in a long time so I cannot remember if there is a door for preground coffee, if that option is there, open door and press button to make a coffee if you get water, then adjust the grind and dosage on the grinder and try the auto function.
Jan 17, 2009 | Saeco Vienna Digital Coffee Maker,...
Saeco Easy dispenses first, then grinds
I think you have pre-brewing on your machine, if you have a Sirius then you have these settings in the menu under coffee settings.
I don´t think this is on Saeco Easy, only if you will make two cup of coffee, then the machine will pre-grind the beans for the second cup.
/Mirran
Aug 23, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Vienna superautomatica Machine
if you open the steamer, does it work correctly? and if u request hot water does it come out?
if not, then its the pump..
Nov 02, 2007 | Saeco Vienna Espresso Machine
Saeco Vienna Espresso Machine Logo
292 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
