Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
The pitcher turns dark purple and blue
Just got it back from shop last week. thay had it in 2 times it was working great, now the pitcher gets dark. if i move it or hit it . it goes back to normal. it seems like it is missing the white.
  • ask4ajd Mar 09, 2009
    it was a bad wire on the green crt board
  • 1,066 Answers
Take it back to the shop
Posted on Mar 09, 2009
Need Wireing diagram to hook up a Wire Harness to a Kenwood BT645U to a 2000 Jeep Grand Cherokee
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
Dec 21, 2010 | Car Audio & Video
Re: turning on s700
How are your pictures coming out? If the photos you take after seeing these lines come out good, then it could be the LCD only. However, if you are unable to shoot, or the photo files are damaged, there may be a problem internally. You should contact Fuji to see if they have heard of this problem, and if not, contact local camera shops to see if they can take a look at it. Also, digital cameras and card will only last so long - they will wear out much sooner than their film counterparts did.
Jul 24, 2009 | Fuji FinePix S700 Digital Camera
Installing my stereo
Constant 12V+ Red Switched 12V+ Red/White Ground n/a Illumination n/a Dimmer Orange/White Antenna Trigger Yellow Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Dark Blue/Red Rear Speakers 5 1/4" Side Panels Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Dark Blue/White Right Rear (-) Dark Blue/Orange
Apr 18, 2009 | 1999 Dodge Ram
Putting in a alpine deck into my cirrus
Constant 12V+ Pink/Yellow Switched 12V+ Red/White Ground Ground/Back Strap Illumination Orange/Brown Dimmer Black/Light Blue Antenna Trigger Orange/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Light Green/Green Left Front (-) Light Green/Purple Right Front (+) Light Blue/Green Right Front (-) Light Blue/Purple Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown/Yellow Left Rear (-) Blue/Light Blue Right Rear (+) Dark Blue/White Right Rear (-)
Dark Blue/Orange
Mar 28, 2009 | Alpine CDA-9847 CD Player
Solid Purple Light on Plantronics 220
Explorer 230 went into solid blue light the second time I used it. Fixed mine by letting the headset go completely dead and re-charged and it appears to work fine now.
Oct 09, 2008 | Plantronics Explorer 220 Bluetooth Headset...
04 1200 Sportster - backfires - cuts out - fouls plugs
Turns out the crank sensor needed to be replaced again (second time in 8 weeks or so!). In the last week Harley has sent out a "improved" crank sensor that does not have the issues of the original. Therefore if you replace it once you shouldn't have to do it again and again. Bike runs great now. We will see - though - my local service manager promises it will stay that way.
Jul 21, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Truly MP3 13X only showing blue backlight
same here, you just have to keep messin' with (pluging it into computer, etc.). I know it sounds strange but that's how I deal w/mine. It eventually comes back to life.
Feb 21, 2008 | Truly MP313X 1 GB MP3 Player
Start by going to a good college and studying electronics 101 followed by electronics 102, math, algbra, etc, until you get an engineering degree. Now as for the dark purple and blue. It sounds as though you have a picture tube getting weak in the red gun and unless you can turn the red gun up you may need a new set. Anyway, good luck and have a great week
NC Electronic
MIlls Wyoming
Jan 06, 2008 | St. Moritz Bellagio Flyback Chronograph...
Purple lcd display
Hello tonyj111, If your old pictures look fine on the display, then the problem is related to the ccd sensor itself. The purple color is displayed because of a problem in the signal transmision from the ccd sensor to the camera's main processor. This is done using 3 channels one for each primary color (RGB red green blue). If the connector to the sensor is broken, or got out of place (loose) because some mechanic shock or symilar, the data processing woun't come out right. It is purple because your camera's processor mess up blue and red signals therefore resulting same purple instead of blue or red colours. In order to fix this you will need to either send the camera to a service center to have those connections checked (if your camera is still in warranty you will want to do this) or ask me for further instructions if you wish to try to dissasemble the camera yourself. In either way the problem is fixable and in most probabilities a cheap fix will work. Good luck
Jun 01, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
