Question about HP 48gx Calculator
WHERE CAN I SELL SOME USED BEAT-UP HP48GX CALCULATORS?
I HAVE 3 USED HP49GX CALCULATORS I NEED TO SELL. ONE IS BEAT-UP TO THE POINT IT WOULD BE BEST USED FOR PARTS. WHO WOULD BUY THESE?
I will buy one that isn't to beat up
Posted on Sep 14, 2009
    Genius:
  • 1,066 Answers
Ebay.com
Posted on Mar 09, 2009
How to disable beeping sound on HP48gx?
Press right-shift MODES to bring up the mode screen, then uncheck the "BEEP" option.
Apr 13, 2012 | HP 48gx Calculator
Need a Manual for my TDS GX card used with HP48GX
http://www.tdsway.com/binaries/tdscogoforhp48gx/documents/manuals/COGOManual&Reference.pdf
Mar 09, 2011 | HP 48gx Calculator
HP48GX does not turn on
no sry get a new one
May 23, 2010 | HP 48gx Calculator
Hp48gx was dropped, now difficult to turn on if at
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the beginning of the post and skip to the last part For Repairs )
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the diagnostic tests.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Release the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterward you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a high pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
You can also try this site. They do repairs on most models, except the newer ones.
May 10, 2010 | HP 48gx Calculator
Hp48gx is autistic
The following procedure valid for the 48G should work for the HP48GX.
Self test.
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
System Halt
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
Hope it helps.
Jul 16, 2009 | HP 48gx Calculator
The #3 key sticks and won't show on the display
Try the following procedure (valid for the HP 48G should work for the HP48GX.) If any of the tests fails the calculator requires service
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Jun 30, 2009 | HP 48gx Calculator
Hp48gx got wet and wont communicate wit sokkia surveying equip?
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
For repairs
There is an HP customer self repair (CSR) which you can contact. On the site it is sais that the service is available for products under warranty or on contract. but you have nothing to lose by contacting them. Here is the link to the web site
Feb 23, 2009 | HP 48gx Calculator
I HAVE A HP-48GX THAT WANT TURN ON.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Feb 05, 2009 | HP 48gx Calculator
My HP 48GX with COGO Card is running slow.
You should perform the dagnostic tests.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Nov 12, 2008 | HP 48gx Calculator
ON switch
.The selft tests will show you what is wrong, and if the calculator requires repairs.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Jul 01, 2008 | HP 48gx Calculator
HP 48gx Calculator Logo
186 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
