Question about Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Quiet Guard 3 leaves soap film. This happened before and we realized it wasn't standing straight. Bringing back to balance seemed to fix it. Now it's happening again but doesn't appear to be a balance issue. We use Jet Dry and tried changing detergent but that doesn't help.
  • 3 Answers
We have had the same problem with clear glasswear with both Kenmore and Maytag diswashers, in fact any diswasher I have used. It seems to be a problem with diswasher soaps. Either try a different soap (continue using Jet Dry), or do what I do and periodically go over your glasswear with an SOS pad.
Posted on Mar 09, 2009
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Its not soap but actually the problem is hard water. www.dishwasherfilter.com has a new product out that solves this problem once and for all. it filters the water going into the dishwasher removing the hard minerals that leave those spots. it is very affordable and guaranteed to work or your money back. you will love the way your dishes look.
Posted on Aug 22, 2009
Could you please help diagnose problem...dishwasher consistently stops washing in the middle of wash/sensing cycle. 2005 Kenmore Ultra Wash Quiet Guard 3
most likely the water is not hot enough,,it trying to heat the water,,when it starts to sense open the door and just test the water,,careful may be hot ,,but i doubt it...another easy way to tell is what is your hot water heater set on,,if you have a lot of soap residue is a good sign..
Sep 02, 2011 | Kenmore Dishwashers
I have a Kenmore Quiet Guard 2 (model 16994400) and the soap door doesnt open during the washing cycle.
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Jan 05, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
My Kenmore is leaving white film on all my dishes. It like it is not rinsing. I will add it is 11 years old.
It might be a bad dishwashing soap. I know the cascade complete works best and all others seem to take a 2nd or worse place. Try a diff. liquid and see what happens.
Aug 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Elite dishwasher will not dissolve soap or wash well.
Temperature should be 140F. and the units heater should energize during fill to achieve this.
May 19, 2010 | Kenmore 24 in. 15173 Stainless Steel...
Soap dispenser will not open during was cycle.
Probably a faulty solenoid on the dispenser. Not replacable new dispenser needed
Jan 20, 2010 | Dishwashers
Model 665.13732k600 seriel FT4610713 dishes are not getting clean, they look like they have a film on them. Kenmore Ultrawash Quiet Guard Deluxe
The film is the stuff and the old soap backing up in the dishwasher. There is no cure for this. You can have them come out and it won't get fixed because it will happen again. They did not put a large enough drain/disposal on the models. Essentially you are eating old soap - goodness only knows what is in it.
Jan 01, 2010 | Kenmore Dishwashers
Kenmore quiet guard standard ocassionally does not use/mix all soap supply and does not get dishes clean. Any ideas?
MIne did the same thing a couple of times. I found that I had put a casserole dish on its side in front of the soap dispenser...so it opened, but the sprayed water could not get to it.
Hope this helps.
Aug 03, 2009 | Kenmore Dishwashers
Kenmore 665.17539. fills but does not wash. makes
Kenmore 665
My dishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them.
Jul 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Dec 09, 2008 | Dishwashers
Kenmore 24 in. 15932 Built-in Dishwasher Logo
321 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
