Question about RCA E13309 13-Inch Diagonal XL-100¿ Color Television Television
How do I get it to channel 3 to use my converter box
Remote for x13101gs does not have any numbers and will only reset to channels in the area whose signals are strong. I bleive my new analog to digital converter requires that the TV be on cahnnel 3. Is there na override that can get me there?
    Problem Solver:
  • 16 Answers
Turn on the converter box and then scan for channels on the tv. Channel 3 should be picked up by the tv as having a signal.
Posted on Jun 09, 2009
I do not know my converterpin numbers ! I would like to reset to facory condition. I am
Your converter is not connected correctly to your TV. Start with the antenna connected to the antenna input on the rear of the box and the R-W-Y outputs of the box connected to the R-W-Y inputs on the rear of the TV. Use the box remote to turn it on and select "setup". With the box menu displayed on the TV, select channel search to find active digital channels in your area.
May 29, 2017 | Televison & Video
Connecting a sansui 13 inch to a converter box
1) Connect the converter box to a good digital TV antenna and position the antenna as high and as close to a window as possible.
2) Set the converter box 'output switch' to an unused channel for your area. (Usually 2, 3 or 4.)
3) Connect the output of the converter box to the 'antenna input' on the TV.
4) Turn on both units and set the TV channel to the same output channel selected above.
5) Now select TV channels using the converter box remote only. The TV should receive all converted channels on the preselected channel.
6) Adjust the TV antenna for the best reception for all channels.
May 04, 2014 | Sansui Televison & Video
I have an older Sanyo (approximately 8 years old) and my remote control is damaged (only the buttons/controls on the right side are working, volume turns up but not down, most of the left keys do nothing)....
If you are feeding the signal from your digital converter into the TV antenna input, I would input the converters signal to the TVs video input instead. I am assuming your converter has a video output signal and left & right audio so you will need cables for your audio also. If your converter has only rf output for the TV tuner input it is generally on either channel 3 or 4 and there may be a switch to set this. It is possible that when the TV scanned for channels the converter was off and it did not find a signal on 3 or 4. If you can get the TV to re-scan, be sure the converter is turned on and on an active channel. All your channel selection should be via the converter after that and the TV simply stays on 3 or 4. I would suggest looking in to getting the original remote. Try partstore.com and see if they have one for your model.
Nov 18, 2009 | Sanyo DS27930 27" TV
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
Can't get CH. 3 or 4 on older Magnavox TV to hook in convert. box
HAVE YOU TRIED GOING BACK TO YOUR MENU AND SELECTING AUTO CHANNEL SEARCH LIKE YOU DO WHEN YOU PROGRAM YOUR TV FOR THE FIRST TIME TO GET THE CHANNELS IN YOUR SERVICE AREA? IT SHOULD PULL IN CHANNELS 3 & 4 (PARDON THE CAPS)
May 05, 2009 | Philips Magnavox DVD/VCR Dual Player
I was able to program my Comcast remote to control the volume of my tv, but was unable to get it to change channels. Is there something else that I should do?
Controlling the TV power and volume is probably all you'll be able to do with that control. The Comcast remotes are meant to be used with their converter boxes, and normally people want to change channels on the box while the TV stays on the box output channel (usually 3, sometimes 4). The remote's channel up and down buttons and number keypad only send out the codes recognized by the converter box. You'll need to fall back to the TV remote if you want to control more than power and volume.
May 04, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Problems with insignia remote control on converter box
Well, try it two different ways, as follows: But be sure that the tv-channel that's selected for tuning will be identical to the "output-channel" which you'll then select for the Insignia converter-box. So, if you first select Channel 3 for tuning the tv set, then you must later select Channel 3 on the "Output Channel" choice for the Insignia "set-up" menu. Similarly, if you first select Channel 4 for tuning the tv set, then you must later select Channel 4 on the "Output Channel" choice for the Insignia "set-up" menu. Be consistent! If you find that the Insignia menu-screen does not subsequently appear after tuning the tv to Channel 3, then start-over with Channel 4 as your proper tv-tuned station to initiate the pop-up screen for the Insignia menu. Now, here's an example that assumes Channel 3 is the proper tuning-station for your tv-set within your particular region: You will first tune your tv-set itself (by means of its handheld tv-remote) to Channel 3. Be sure, however that your Insignia converter-box is turned-on and properly connected to your tv-set and antenna. On your tv's hand-held remote-controller, you should find a button that serves as its "input selector" -- with a typical descriptor such as "Input" or "Line" or "Video/Antenna." Press that button, and enter successive channel numbers until you get to Channel 3. You may need to press the digits 03 to signify Channel 3. The tv-screen may be colored bright blue at that point. Then, as you switch to holding your Insignia remote-controller, press the "Menu" button. (Please note that you will need to press hard and firm upon the buttons of the Insignia hand-held in order to get proper responsiveness; a quick touch of the button will not be effective.) After pressing the "Menu" button, the Insignia menu should now appear on the tv-screen. Now, you need to use your Insignia hand-held remote-controller (not the tv hand-held remote-controller again) to travel through the menu-screen to the "Setup" feature. Then, select "Output Channel." Proceed to select Channel 3 -- which will then be printed for you next to the Output Channel feature. Finally, under the same Setup menu, go to "Auto Tuning" -- which will commence a complete scan of all available channels. Remember, if tuning by Channel 3 is inappropriate for tv-tuning within your particular geographic region, then repeat the above process by substituting Channel 4. When you are done, you will rely almost exclusively upon the Insignia hand-held remote controller. You do not especially need to use your tv hand-held remote-controller again. However, be sure to avoid standing in front of your tv-set to change channels by buttons or knobs upon the tv-set itself. Tuning again upon the tv-set itself will negate your prior tv-setting for either Channel 3 or Channel 4 -- and thereby sabotage your working set-up! I myself incurred chronic anxiety yesterday (June 13), as I was stunned that the Insignia menu-screen did not appear immediately when I pushed "menu" on the Insignia hand-held. The only buttons that worked on the Insignia handheld remote-controller were the Power-on for the converter-box and the Power-on for the tv-set. (continued next page) Because my expectation had been this process would take just a few minutes, I was deeply frustrated and impatient. However, I recognized that my apprehension of impending loss was absolutely appropriate as emotional "signal-processing" for me personally -- in contrast to my formerly high expectation of immediate fulfillment, completion, and gratification. Instead of my intention for quick success, I faced the stunning dread that the Insignia box had become defective or that I'd fail to ever figure-out the problem. I would not have been so impatient if I hadn't expected immediate success for the set-up. I rejected the slogan that "I just want to get this over with!" I rejected the option of stomping upon the Insignia box! Amidst my hour-long anxiety, I summoned "Courage" -- a mode of patience to accompany my internal "quivering." I did a Google search. From this Fix-Ya web-site and other troubleshooting sites, I had strong clues that improperly setting Channel 3 or Channel 4 was a primary culprit for the failure of the Insignia's menu-screen to appear. When I finally succeeded, my anxiety dissipated quickly with a temporary relief. But then came the anger that the Insignia "User Guide" had not been clear to explain the process. From that aftermath of outrage, I decided to promptly compose this protocol to assist others who have been similarly tormented -- perhaps to the extent of incorrectly believing that the Insignia converter-box was a defective product requiring prompt replacement.
Feb 22, 2009 | Insignia Digital-to-Analog Converter for...
Cannot get tv to synchronzie with hd converter box
YOU NEED TO GET INTO THE MENU AND EITHER AUTOPROGRAM THE SET WITH THE CONVERTER BOX ON OR BUY A REMOTE AND DIRECT ACCESS CHANNEL 3.
Jan 22, 2009 | RCA Televison & Video
When on the digaital converter says no signal
Depending on type of antenna you have on the box the signal maybe too weak. But first try to lock channel 03 into your set. go to menu and add 03 where it has add/delete channels. If this still does not work select channel 04 and set your converter box switch to channel 4. This should do it.
Jan 18, 2009 | Sony RMT-V202 Remote Control
I installed the converter box on channel 3 instead of channel 4
No reason to delete converter box from channel 3. Most converter boxes have a selection switch on the back for channel 3 or channel 4. Slide switch to 4 and set tv to 4.
Jan 13, 2009 | Televison & Video
Televison & Video Logo
182 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
