Question about Dell Dimension 2400 PC Desktop
Ram upgrade problem
My computer was installed with 256m at 333. I have two new ones, 512 at 400. They are the correct pin#. When installed my computer woudn't even come on. Is there a way to make these cards work? My father purchased these for me and he was told that these would work with my system. I have my doubts. The card is Samsung 3200-512m S111
pc3200 512mb
DDR400 184 pin
Dimm OEM
  • 1 more comment
  • jeremy_stubb Mar 09, 2009
    No I removed the 256 all together. I thought there was a problem with the slot so I tried every combination possible with the same results. The computer was on but the monitor was blank. I reinstalled the original card and everything is back to normal. Is there a way to have the cards operate at 333 even though it's designed for 400?
    I tried using just one stick and this wouldn't work. I tried both slots and nothing. I guess I will just have to get the right ones.
    Thanks anyway for your help. I appreciate it.
  • 3 Answers
Hi
i thought that it was the miss match the bus speed
first check the bus speed of ram
bus speed wrote on the top of the ram
Posted on Mar 09, 2009
    Sergeant:
    Champion:
  • 224 Answers
Are ou adding them along with the 256MB memory? That could be the problem
  • Shakeel Muradali
    Shakeel Muradali Mar 09, 2009
    No, unfortunately it is not possible to force it to 333. How about if you jjust add one RAM instead of two?
  • Shakeel Muradali
    Yes i believe so, Sorry i was not much help
What ram do I upgrade with,,cant seem to find the right pin number etc,..there are 4 slots..can i use them all
The specs for the RAM on this motherboard are:
DDR400/333/266 SD RAM with ECC. Maximum you can use is 4Gb in total (so 1Gb stick in each slot would be fine - just make sure you match them in pairs).
Maximum of 4GMaximum of 4GB of DDR400/333/266 SDRAM with ECCB of DDR400/333/266 SDRAM with ECC
Jul 26, 2011 | Chaintech 9CJS ZENITH Motherboard
I can not upgrade the memory of my laptop, i have buy a new 256M SDR ram and put in the opposite socket and restart, but its BIOS still 256M at the same(it should be 512M). I try more than ten times but...
try to remove all memory and place only the new memory, if things goes right, there is a problem on the compatibility on your new memory, it should have the same speed as your old memory
May 04, 2011 | IBM ThinkPad X30 2672 Notebook
Can i upgrade my intel D845pesv mother board with 1GBDDR3 RAM ?
No, that motherboard only has two DIMM sockets that support 184-pin connections, DDR3 RAM only comes in 240-pincount. Your motherboard does support up to two gigabytes of RAM, so you could buy two 1GB sticks of DDR 184(pin) SDRAM DIMMs at 333/266Mhz (the speed of the ram)and install that.
Dec 22, 2010 | Intel D845PESV Motherboard
I have a dell dimension 4600. It has original memory cards installed. 2 256 MB for a total of 512 ram. I recently tried to install 1 GB memory card. When I start up computer it beeps several times,...
hello
several beeps in a system is caused by a memory issue -- If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
the specs can be found at this link
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
the system you have is upgradable to 4G of RAM, and this RAM must be installed in equal pairs
so if you have 4 slots to insert memory in (assuming you will retain the 2 256M) , you must install the other slots by 2 512M, 2 1G or 2 2G DIMMs -- make sure you isntall exact same DIMMs, dont mix memory makers or specs, other than what Dell specifies
memory type must be
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
i hope this helps --
Dec 09, 2010 | Dell Dimension 4600 PC Desktop
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Upgrading ram on laptop, new ram not recognized.
remove the bios battery for a few seconds...and place it back on ...this will make it see the new ram memory modules...if you are sure they are compatible ..they will work .....in fact ..the ddr1 333 512 M is more that compatible with your system and it will work after you remove the battery ...\ my recommendation is to reinstall a clean operation system after you boot up ...and format the C partition too...this have to be done after memory changes to get the max out of them ..
Nov 13, 2009 | Dell Inspiron 1100 Notebook
I have an extra memory card: DM, 256M, 32x64, DDR266, S. Is it compatible with my E210882 motherboard?
# Four 184-pin DDR SDRAM DIMM sockets
# Support for DDR 400, DDR 333, and DDR 266
# Support for up to 4 GB of system memory
So the ans is yes provided all RAM's have the same FSB, i.e. 266 & satisfies the above .....sodeep
Oct 26, 2009 | Intel Motherboard
Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
Aug 26, 2009 | ASUS PSCH-L Motherboard
Asus Mobo Will Not Boot After Memory Upgrade
not right ram gotta use samusng low density sum mobo so picky
Jan 20, 2008 | ASUS P4PE-X Motherboard
Dell Dimension 2400 PC Desktop Logo
48 people viewed this question
Alun Cox
