Question about GE Dryers
Bad 220? I have been having problems with my 220 volt Dryer. There is 220 across both legs and 110 to the ground from each leg, checked at breaker, rec., and dryer. Dryer works fine at neighbors house.
  • 1 more comment
  • kellervincen Mar 09, 2009
    Not doing anything
    I just checked the dryer again and it works at the neighbors house, I believe there might be a problem with the service panel, also noticed the heat pump is not blowing the air as hard as it used to be. I am wondering if the voltage or amps are being restricted somehow. Again there is 220 at the terminal block.
  • kellervincen Mar 10, 2009
    All is tight, I have a service dis-connect and four wires from that into the service panel, my 3 wire set-up from the dryer the ground is on the ground pole not neutral, in the service disconnect box the neutral and ground come together by the green screw. also I have two different ground rods in the ground.
  • GE Master
  • 3,361 Answers
What is your problem? Not drying? Not heating? Not running?
Posted on Mar 09, 2009
  • 1 more comment
  • steve
    steve Mar 09, 2009
    Check the internal wiring just past the terminal block where the cord is.
    Are they OK?
    Check the door switch for continuity.
    Check the thermal switch/fuse located on the dryer heating element canister behind the drum.
    Check the belt. If broken replace the belt. These dryers have a motor switch activated by a properly routed belt.
  • steve
    steve Mar 10, 2009
    Your neutral wire at the circuit panel and or each outlet is loose.
    Repair the neutral wire and you will fix your problem.
    Double check the ground wire at each outlet also.
  • steve
    steve Mar 10, 2009
    If your heat pump and dryer both are not working correctly call the utility company.
    Thje problem is on their side.
My Bosch Nexxt 500 dryer stopped heating. All other functions work fine except heat. I've checked continuity on heating element & overtemp breaker- both OK. What else could be the problem? Fuse?
CONSIDER THIS
BOTH LEGS OF AC MUST WORK TO GET HEAT FOR DRYER
Maybe you don''t have power to both legs of your receptacle. Both legs of the 220 volt AC have to work go get heat. Only one leg is used to run the motor etc.. Your motor runs so this can fool you into believing that the electrical connection is ok when it really is not. Your dryer is on a double circuit with two breakers. If one fails you lose one 110 volt leg which can be the one giving the full 220 Volt needed for the heater. This happens quite frequently and people mistakenly replace heating coils. You could have a bad breaker, one of the two. You must check this first before assuming anything else. Get help if you are uncomfortable with potentially deadly voltages
Dec 14, 2015 | Bosch Nexxt 500 Dryer
My beko dcrs76w condensing tumble dryer was blowing out cold air so we repaced element & thermostat buts still not fixed. We have cleaned out filters aswell. Any clues as to what the problem could be?
In most dryer, there is a thermal fuse and open from overheating. Generally, it installed on the dryer's exhaust duct. Typically, you must remove the back panel of a dryer to access the fuse.
Dec 11, 2015 | Dryers
Why wont dryer heat up after changing out coil ?
most dryers are 220. its possible your breaker is half tripped. try cycling the breaker.. you should get 220 across it while its running. (Be careful).
Sep 09, 2015 | Haier Dryers
Oven is slow to heat up and will not heat above 250
You may have a bad heater coil in the oven or have lost a leg in the 220 line. Check and reset the breaker 1st then check the voltage in the receptacle. It should be 110 from each leg to ground and 220 across the hot legs.
Jan 03, 2015 | Maytag MEW6530DDS Stainless Steel Electric...
I need to make a 110 volt leg from my existing 220 volt dryer outlet.
Dear Sir:
See the diagram attached, you must USE VOM carefully for to measure the 110VCA. Disconnect the power C.BREAKER from your house. Before to make any job.
God bless you
May 23, 2012 | Dryers
220 appliances in house all out.lights up but either dont heat or wont bake .lightning could be culprit but never lost tv reception.dryer runs ,no heat.water heater out.stove lights up wont get hot.shut...
Sounds like you have lost one leg of your power
Think of it like this
You an upside down "Y" at the top of your breaker panel
220 - 240 volts come in the Y and break in half 120 volts to each leg of the "Y"
A 220 Volt breaker straddles both legs a 110 volt breaker only contacts one leg
I suspect that you have lost one leg
Possibly at the main breaker ( top most)( main disconnect) in your panel
If you have a tester with the capacity to test 240 you can test the two top lugs where the main wire comes in Test them together That is one probe of your tester on each wire you should show 240+/- volts
Then you can move down through the panel 120 +/- on each leg
Hope this helps if you need more just let me know
Scott
Mar 16, 2010 | Bryant 50 Amp 2 Pole Br250 Type Br Ni...
Dryer has 110V only.Light burns when door is opened.Controle panel does not switch on at all.Each leg where power cord is attached has 110V.I have replaced Thermal Cut-off & High Limit...
Your problem is not in the dryer. 220V circuits can be confusing in that the 110 leg can feed back and in reality you are getting the same 110V reading on both legs. Check across the two legs and see if you get 220V if not then you have confirmed what I suspect. Your problem is probably with you circuit breaker in the electric panel. Try switching the breaker off and forcefully turning it back on, You also can take off the panel cover and check to see if you have 220V across the two poles of the circuit breaker. You may have to replace the circuit breaker, it is not uncommon for one leg of a breaker ot go out especially when used on a dryer that pulls high amp. resistance loads.
Heatman101
Dec 26, 2009 | Whirlpool GEW9868K Electric Dryer
I have bard central unit model# a/c ph11361 blower not running
220 is just putting two 110 volt circuits together. You should read only 110 volts from each leg to ground. But you should read 220 between both legs. Measuring between two legs that are supposed to be 220 and you read nothing than you are not measuring the differences. This means you are only getting 110 volts. Check your units data plate and make sure you need 220. Usually the condenser fan on a split system is 110 volts and the condenser fan is 220 volts. Which motor are you checking?
Apr 02, 2009 | Heating & Cooling
Dryer runs but doesnt heat
check the heating element and the limit switches there are the first things to look for when theres no heat
Jan 29, 2009 | Roper REX4634KQ Electric Dryer
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
