By Perkins - usenet poster
a computer I have is locking up after being on awhile! I'm thinking CPU
overheating but I thought they ussually reset! I also suspect the PS since
it is underpowered at 90watt! Ideas?? (win98)
Solution #1
posted on Aug 02, 2007
Green1 - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Actually I was wrong, its a 70 watt power supply! This info I found on this
Gateway said 90 but the label on the PS says 70. Gateway are junk!
Glenn
Glenn
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Mini Me - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
MM's guideline: Start with 200W and add 50W for every 2 drives. [All-in-1,
p. 332]. Later in the book he states you should go with 230W-250W to start
with. I haven't seen a 90W PS in a long time. I'm surprised it doesn't
lock up immediately. I've run into low-wattage PS problems that manifest in
different and unpredictable ways; i.e. - resets, lockups, and even complete
shutdowns. Also, don't forget that the PS fan assists in providing cooling
and air flow within the case.
My guess would be Dell circa '92, or Gateway circa '9x? ;-)
Zac
Zac
Solution #4
Charlie - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
90 Watts!?! Is that a Dell? Gateway? Packard Bell?!?!?!?!?
The new phone books are here!
Solution #6
herself - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
your suspicion of the power supply would be my first guess also, especially
if you are dealing with a higher end CPU.
Techie
A+, Network+, MCP
Techie
A+, Network+, MCP
Suggest a new solution for this problem
Post a New problem for Gateway /ton 90W Power Supply Power
Email this problem
Email this problem
Can you Help with these System Power Supplies problems?
Power Adaptor for 500GB LaCie...
Hi, My LaCie 500GB Porsche USB... Answer This...
Lanier VoiceWrite EX won't come...
The on/off button will not work... Answer This...
Repair Service
Find System Power Sup. Repairman Near You:
