Question about Dell Inspiron 2650 Notebook
Dell inspirion 2650 does not for mat hard drive it
Dell inspirion 2650 does not format hard drive it starts, but it stops about 2%
  • Anonymous Mar 16, 2014
    changed hard drive after getting this message and still getting this message
  • 224 Answers
Before formatting, try removing all partitions by using fdisk. What means are you using to format the disk?
Posted on Mar 09, 2009
    Problem Solver:
  • 10 Answers
You might have to Debug and then format the hard drive heres the link for debuging the harddrive and then try to format..hope this helps.
Dell inspirion 3520 no internal hard drive detected
Do you hear the hard drive spinning? If so, reboot unit and press F10 or F12 for Boot menu. In the boot menu you should see Hard drive or C/: as a selection, if not, the drive has stop working. I hope that helps.
Mar 16, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
Cannot boot from usb. dell serverPoweredge 2650
Try entering the BIOS (usually by hitting F2 or Delete during the boot up sequence) and looking under the boot menu for the USB drive. Some older systems cannot boot from USB. You might have improperly formatted the USB drive. What are you trying to boot into?
Feb 28, 2011 | Dell PowerEdge 2650 Server
Windows 98 on dell inspirion d600 install problem
Installing Windows 98, is you need a start-up disk (floppy disk) first before you can use the Windows 98 cd. The start-up disk will perform the partitioning and formatting of the HD...doing this, you have to boot from floppy drive first---after partitioning and formatting, you have change again the boot sequence to boot from cd then you can start the installation of Windows 98.
Jun 07, 2010 | Dell (6T980-A01) CD-ROM Drive
How do I replace the hard drive in my Dell
Did you format the drive before installing it on your laptop. Some laptop will not detect unformated hard disk. Try to format the hard disk somewhere else and check to see if the laptop detect it after.
Apr 11, 2010 | Dell Inspiron 2650 Notebook
How to install hyper v on dell 2650. Can Windows 2008 with hyper v be installed on a Dell 2650?
Yes, Server 2008 will install on the 2650 as long as you make sure you have enough RAM and hard drive space. Once you have Server 08 installed, you will have a to-do list to help with setting up hyper-v.
Good Luck
Feb 26, 2010 | Dell PowerEdge 2650 Server
My Dell inspirion 2650 won't charge.
Try using a different power adapter. They sell for around $25 and up on the internet. Dell adapters burn out quite often.
Jul 30, 2009 | Dell Inspiron 2650 Notebook
How to transfer OS and data to newer Poweredge server
The new RAID controller should read the data from the drives and work without difficulty. You will need to transfer all drives at the same time. Be sure to put the drives in the same spot in the new server.
Here are the bad news parts:
1. Your data is at risk. Make sure you do a good backup before trying this.
2. It is far more likely that your performance problems come from disk access or memory than the actual processor. If this is the case, then you probably won't be helping yourself with the migration. If you haven't already done so, analyze what is causing your performance bottleneck to make sure you are going in the right direction.
Jun 11, 2009 | Dell PowerEdge 2600 Server
I have a working Dell Poweredge 2650 with 2 x Xeon 1.8Gig processors, 5 x 36GB hard disks, running Windows 2003 Server. I have recently purchased a newer Poweredge 2650 with the same configuration except...
You should be able to do this by moving the drives all at once ALL DRIVES MUST BE PLACED IN THE SAME SLOTS 0,1,2,3,4, do not mismatch else it will be a nightmare ............HOWEVER BACKUP your data up if you are going this route,on paper it might sound like a winner,however not all that glitters is gold.controllers though they might be the same have different firmware which allow them to do different things,so if you are going to this the os drive raid 0 or 1 must be two seperate is drives.once this done,how is your raid set up for the other drives once you have a good back up to restore if there is any complication,move the over in the same order,remember POWER DOWN BEFORE YOU ATTEMPT THIS .PS REBUILDING TAKES FOREVER.
Jun 08, 2009 | Dell Refurbished PowerEdge 2650 Server
Does not reconize hard drive
turn off the laptop and then take out the hard drive from the laptop. Go ahead and reseat it back into its slot and then turn on the laptop and press F2 to go into the BIOS. It should see it in there. If it doesn't then you know the hard drive is bad and will need to be replaced.
May 18, 2009 | Dell Inspiron 2650 Notebook
Dell Inspiron 2650 Notebook Logo
136 people viewed this question
Alun Cox
