Question about Hotpoint FFM90 Bottom Freezer Refrigerator
Hotpiont ffm90 fridge not chilling
Hotoint ffm90 fridge not chilling was making a lot of noise but stpped when door was open now not cold at all
  • 75 Answers
Hi if the freezer appears to work and the fridge if warm,the problem is that the freezer is over frozen and blocking the vents which send cold air into the fridge when required,and the noise is the fan hitting the the ice build up,defrost (switch off)your applinace for at least 36 hours then switch back on,you will then find after the freezer reaches -12 the fridge will then start to go cold.
Posted on Aug 02, 2009
SOURCE:
  • 24 Answers
SOURCE: My 10 year old Roper fridge stpped keeping the
Sure it's worth fixing, in fact you can probably do this yourself. This is usually caused by either a broken defrost heater, defrost thermostat, or defrost timer/control. Take all the food out of your freezer and remove any shelving that might be in the freezer. Remove the rear panel in the freezer and you'll see ice blocking the air ducts going into the refrigerator compartment. Use a hair dryer to carefully thaw ALL of the ice. Also check the defrost drain while you have it apart. The defrost drain is located in the freezer, in the middle. It's a small hole going out of the bottom middle of the freezer. Pour a coffee cup of hot water down the tube. If it drains, you're okay. If it puddles up, you have an ice blockage and you need to pour more hot water in the hole until it drains freely. Reassemble your freezer and if the problem comes back in a couple weeks or months, you know you have a bad part. Usually the defrost thermostat. It's a small round part that is about the size of a golf ball. It has 2 wires going to it. See if it's bulging.
Posted on May 26, 2010
SOURCE: chilled water stopped .chiller frozen in bottom of fridge
SR-32 EMB MODEL, FREEZER OK, BOTTOM NOT COOLING PROPERLY. ADVICE SETTINGS
Posted on May 28, 2008
  • 74 Answers
SOURCE: ge profile side by side 'fridge
Evaporator fan motor and main Pcb , the fan motor goes faulty and then burns out a resistor on the main pcb at the back.
Posted on Aug 28, 2008
  • 112 Answers
SOURCE: Kenmore 59652673200 fridge is not chilling well ,
its dropped its gas or auto defrost not working.
Posted on Jul 20, 2010
  • 117 Answers
SOURCE: Hi my Samsung fridge freezer
some good stuff on youtube re
samsung fridge freezer help
also samsung diy video help
Posted on Oct 19, 2010
Made a loud noise from fridge(fan) now will not get cold
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Feb 13, 2011 | Hotpoint FFM90 Bottom Freezer Refrigerator
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Refrigerator compartment doesn't chill
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Feb 04, 2010 | Amana Refrigerators
My fridge freezer motor was making a whole lot of noise
There is a fan that blows air over the condenser coils under the fridge in the back. You will have to pull the fridge out away from the wall, remove the screws that hold the access plate or panel that covers it. There is probably something catching the fan. This would be a good time to clean as much of the evaporation coils with the light brush or vacuum. It could be the fan is shot but these things operate on a low speed and last a long time. Check this first before doing anything else, The screws are generally removed with w fillips screwdriver of you may have to find a set of small sockets to remove them. It is possible that the compressor is broken in which case you will need a new or used fridge which you can find all over.
Oct 21, 2017 | Hotpoint FFM90 Bottom Freezer Refrigerator
I have a samsung side by side fridge, and the fridge side is not staying cool, but the chill drawers are keeping the right temp??? The Model# is RS267LABP
The chill drawers are probably staying cold because there is a vent to the freezer in the wall for the cold air to seep through.
Nov 03, 2009 | Coffee Makers & Espresso Machines
Haier HRF10 Fridge weird motor sounds
hi. thanks for the question. leaving the door open ,would let a lot of moisture to enter the freezer, and cause it to frost up. to clear frost. cut power to fridge, open the doors .,let thaw over nite clean up the water mess. dry the inside of fridge & freezer turn power on good to go. to stop the door from being left open .lift the legs under the front so the fridge has more weight, and it will close by self . no more doors left open. thanks the appliance doc
Sep 28, 2008 | Refrigerators
The fridge door was left open and the fridge-freezer is no longer chilling, how can i reset the appliance
thanks for the question you probably have a lot of ice build up in the freezer try shutting it down with doors open for 24 hrs and start up again thanks the appliance doc
Sep 16, 2008 | Samsung Refrigerators
Chilled water stopped .chiller frozen in bottom of fridge
May 28, 2008 | Refrigerators
Fridge motor is very very noisy
It sounds like it could be ice around the fan motor. Unplug it and let it defrost for about 12 hrs with the doors open. Plug it back in and see if it has quit making the noise. If it did it probably needs the defrost timer replaced. Good luck. kstfas
Sep 29, 2006 | Hotpoint FFM90 Bottom Freezer Refrigerator
My fridge makes loud popping noises and is over cold (freezing the things in the fridge & frosting up the freezer, when it is a frost free freezer)
Check in your owners manual for a "noise" section to see if you can identify the source. Refers make lots of unusual noises so it helps to understand if they are normal or not. Over cold in the fridge may be due to the air damper system being stuck open or food placed too close to the air duct outlet. Frost in the freezer can be due to moisture getting inside from a bad door seal, etc.
Sep 11, 2006 | LG LRTN19320 Top Freezer Refrigerator
Open Questions:
See all Hotpoint FFM90 Bottom Freezer Refrigerator Questions
Hotpoint FFM90 Bottom Freezer Refrigerator Logo
266 people viewed this question
Top Hotpoint Refrigerators Experts
Steve Allison
Steve Allison
Carmen Mikulic
Jose Pino
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
