Question about Zanussi ZWF1430W Front Load Washer
A sock has escaped and siezed up the drum
Model no zanussi zwf1217 w
  • 44 Answers
Hi
to get it out you need to remove sump hose and hopefully you should be able to get at it if not remove heater and try that way . if that fails then its drum out job.
regards
Posted on Mar 21, 2009
My zanussi aquacycle 1000. Programme knob is just cycling through the was cycle really quckly without the machine washing, the drum is moving slightly back and forth and sounds like its trying to engage...
Could be that the drive pulley behind the drum has loosened on the shaft. You do not say that you can hear the motor, but the drum moves slightly. Some machines have a shear pin which fails to prevent damage to the drum and motor. If you machine has one of these, it will be obvious when you get the back off. The lack of load on the motor could do strange things to the programmer. Good luck.
Jan 31, 2018 | Zanussi F1045W Front Load Washer
I have azanussi zwf1437w washing machine. The drum has become stuck and won't turn and can't be turned by hand. There are no socks etc stuck between the inner and outer drum that I can see.
Well, I hate to tell you, but the drum will have to be looked at and that means opening the machine up. It probably dislodged from its mounts from excess vibration caused by unbalanced loads in the drum.
Jan 15, 2013 | Zanussi Washing Machines
My pulley won't move
Does the inner drum move? If not the drum bearings have probably siezed and will need replacing.
Dec 29, 2012 | Zanussi ZWF12070 Front Load Washer
I have a Zanussi ZWX1506W washing machine and have a problem used it yesterday and after about 10mins i could smell a burning smell so turned it off and unloaded it/ drained it etc left it go an hour or so...
There is a tiny possibility that the motor has seized. To test this possibility, remove the top of the machine and take the drive belt off. If the drum now spins easily but you can't turn the motor spindle by hand then the motor has siezed, if the drum is still stiff but you can turn the spindle of the motor by hand then the drum is siezed. A replacenemt motor will probably set you back around £100 ($170) this may make the machine a write off. Worst still, and I'm sorry to say, far more likely is that the main bearings in the drum have broken down and siezed. The smell is from the motor buring out as it tries, and fails to turn the siezed drum (or siezed motor bearings).
Under normal circumstances, to test your bearings, open the door of the machine and by putting a little lifting pressure on the top of the inner drum, attempt to rock the stainless steel inner drum up and down.
The outer drum is mounted on springs and shock absorbers, so it will rock about (and it should do this) but the inner drum should not move up and down in relation to the outer drum. There should be ABSOLUTELY NO PLAY between the 2 drums, even the tiniest amount will mean the bearings have failed. Having said this, if your bearings have siezed, there may be no play in the drum because they are jammed solid.
If the bearings have siezed, then other symptoms that have been leading up to the failure will typically include:
A clonking noise as you lift and release the inner drum (this is the inner drum rattling on its bearings and/or hitting the outer drum), but as I say, with siezed bearings, this may not be the case.
You will have become aware of the spin cycle becoming far noisier recently and possibly even a grinding crunching noise when the machine spins.
When you turn the stiff drum by hand, it may not only be stiff, but you may be aware of a grinding crunching noise that you can also feel transmitting through the drum as you turn it at the same time (the broken bearing catching up on smashed bits as you turn the drum)
A leak from under the machine, which you will probably be able to trace to the back of the machine, coming from the centre of the drum. This is a result of the failing bearing allowing water to escape through the seal at the rear.
If it is the main bearing (and I can't imagine any other cause other than the motor its self seizing) then this is NOT a job for the uninitiated DIY enthusiast as it will mean stripping the machine and removing the drum from the chassis, splitting it, removing pressed in bearings and then sourcing and re-fitting new bearings.
To be frank, the cost of a bearing set (if they are replaceable, and most are) will be about £20 ($30) or so. But it's a long and horrible job if you haven't done it before. I know professionals who claim they can do a bearing change in under an hour, I've done a few and it takes me about 2 hours by the time I
Aug 30, 2011 | Zanussi Washing Machines
My washer model fjs1397w wont move through a wash cycle or spin drum wont go around on any cycle , tried moving it around by hand will not do anything
if you are unable to turn the drum by hand it may have ceased due to a sock or item of clothing jammed in it behind the drum this in turn may have snapped the belt
regards
Ian
Apr 20, 2011 | Zanussi FJS1225W Front Load Washer
I think there is a sock of something stuck in between the drum how can i access it
The only chance you have got is to remove the large sump hose from the pump to the bottom of the drum, this will allow you to get your fingers into the bottom of the drum, and hopsfully retrieve the sock.
Jan 30, 2011 | Zanussi Washing Machines
The drum will not spin because something is stuck between it and the outside
Sometimes the water heater guard plate can come adrift and cause this or some article of clothing has jammed behind the back of the drum and forced between the tub and the front door gasket.
It could also be a siezed tub back bearing..
Sorry
Mar 17, 2010 | Zanussi FS1055W Front Load Washer
I have a Zanussi ZWF1241W and something is stuck in the drum. The drum does not spin freely and prior but does not have any play. What is the best way of checking this and getting the obstruction out....
It was a sock wedged between the lip of the spinning drum and the outer (stationary) drum casing. I managed to ease it out with some pliers - rotating the drum and pulling. Be careful though not to nick the door seal (as I did). It may be a better strategy to get the door seal off and then remove the obstruction. I'm about to find out how easy/hard/fiddly it is to get a new door seal onto this machine!
Oct 07, 2009 | Zanussi Washing Machines
Kenmore 44092/spin cycle
It turns out that there was a sock stuck within the pump in the washing machine. I removed the back cover and removed all the excess water, because once the sock was removed, the water was free to escape. I just removed the hose that connects to the pump and felt the sock, and was able to remove it. Once I hooked everything back up, the washing machine ran great.
Apr 17, 2008 | Kenmore Energy Star 44092 Front Load...
Zanussi washing machine drum will not go round at all
Tracy
The bearing may have siezed or you have something jammed between the drum and outercasing
Mar 23, 2008 | Washing Machines
Zanussi ZWF1430W Front Load Washer Logo
78 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
