Question about Xerox DocuColor 3535 Copier
Printing horizotal lines on the paper
It was printing fine and then it starting printing with these horizontal lines. If I copy in black and white its fine. When I print a test page ther are those lines. Any ideas Thanks!
  • kharley Mar 09, 2009
    How do you printhead cleaning on the xerox 3535 printer
  • kharley Mar 20, 2009
    I have been out of town, but my problem still exists
  • 527 Answers
Sir,
Click this link for pdf and go through it. read throughly
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on Mar 20, 2009
    President:
  • 2,004 Answers
Do alignment on your printer troubleshooting menu. If problem persist, change the ink cartridges for a new set. This should do it.
Please rate this.....
    Sergeant:
    Champion:
  • 224 Answers
Have you tried re-alligning your cartridges? It seems like a calibration also needed. The options should be available from your software, printer settings
Posted on Mar 09, 2009
    Sergeant:
  • 219 Answers
Have you attempted to uninstall the printer's drivers then re-install them? Search the, "Control Panel" for, "Add/Remove Programs." Inside this region you might find the drivers to your printer. Remove them.
Afterward use the CD that came with our printer to re-install the printer's drivers. If the problem persists, check the manufacturer's website for updated drivers. Then you would once again uninstall the old drivers before installing the new ones.
Let us know how it turns out.
    Genius:
  • 1,550 Answers
Do print head cleaning .
  • SAM ANDERSON Mar 09, 2009
    Open the printer driver setup window and click Print Head Alignment on the Maintenance tab.
    The Start Print Head Alignment dialog box opens.
    Load a sheet of A4 or Letter size plain paper into the auto sheet feeder.
    Get a record of the current settings before you adjust the print head position by clicking Check Setting.
    Next, click Print Head Alignment
When making a copy, be it A4R or A4 Lines cross horizotally from left to rigth
Good Day Lucamoses!
Maybe it is time for you to clean the scanner glass and or the ADF platen glass.
Remember a small dirt, usually a dried ink in the scanner glass or platen glass will leave a horizontal black lines in your copied paper.
I hope the problem you have Lucamoses is just as simple as cleaning the glass to solve it.
Good Luck!
Jun 10, 2011 | Computers & Internet
I have a Canon Pixma MP270 and I can only print in colour both the black and colour lights are lit up on the printer
f print quality does not improve by the standard cleaning of the Print Head, clean the Print Head deeply. Cleaning the Print Head deeply consumes more ink than the standard cleaning of the Print Head, so clean the Print Head deeply only when necessary.
1. Make sure that the power is turned on.
2. Clean the Print Head deeply. (1) Press the g0022565.png (Maintenance) button repeatedly until y appears. g0054776.png
(2) Press the Black or Color button.
The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 2 minutes.
3. Check the print head condition.
When the deep cleaning is completed, the LED returns to the copy standby mode. To check the print head condition, print the nozzle check pattern.
See " Printing the Nozzle Check Pattern".
If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours.
If the problem is still not resolved, replace the FINE Cartridge with a new one.
See " Replacing FINE Cartridges".
If the problem is still not resolved after replacing the FINE Cartridge, contact the service center.
Print the nozzle check pattern to determine whether the ink ejects properly from the print head nozzles.
NOTE If the remaining ink level is low, the nozzle check pattern will not be printed correctly. Replace the FINE Cartridge whose ink is low.
You need to prepare: a sheet of A4 or Letter-sized plain paper
2. Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
3. Open the Paper Output Tray gently, and open the Output Tray Extension.
4. Print the nozzle check pattern.
(1) Press the g0020617.png (Maintenance) button repeatedly until A appears. g0054754.png
The nozzle check pattern will be printed.
5. Examine the nozzle check pattern.
See Examining the Nozzle Check Pattern.
Examine the nozzle check pattern, and clean the Print Head if necessary.
1. Check if there are missing lines in the pattern (1) or horizontal white streaks in the pattern (2). g0054755.png (1) Check if lines are missing in this pattern. If yes, the cleaning is required.
See " Cleaning the Print Head".
(A) Good
(B) Bad (lines are missing)
(2) Check if horizontal white streaks are present in this pattern. If yes, the cleaning is required.
(A) Good
(B) Bad (horizontal white streaks are present)
Post back!
Oct 26, 2010 | Canon Office Equipment & Supplies
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Hello - my Brother DCP 330C printer is printing horizontal faded lines on both color and Black and white copies. I have changed the toner in all areas but still no change. Could the problem be with the...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 28, 2010 | Brother DCP-330C All-In-One InkJet Printer
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
Poor printing from my printer
Hi D
First off review my previous post about under head cleaning and follow the process through. Make sure you have no build up of fluff or a small piece of paper stuck below the head.
Once you have completed the under head cleaning cycle, let me know what difference is made via this post. Further wirk may be needed
Sep 20, 2007 | Epson Stylus RX500 All-In-One InkJet...
Printing mostly blue with lines across page
I have the same problem that you are haveing, I changed the ink ,both black and color, and it hasen't helped any, I wanted to get a new copy and printer machine but I don't want to get one and have the same problem. I have runined a lot of print paper trying something else new. I am open to all suggestons. thanks Ken.
Dec 03, 2006 | Lexmark X73 All-In-One InkJet Printer
64 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
