Televison & Video Logo
sara hardy Posted on Apr 13, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My pictur on my tv looks like it is snowing how can I fix it
Anonymous
Level 2:
New Friend:
  • Expert 57 Answers
  • Posted on Apr 13, 2013
Anonymous
Expert
Level 2:
New Friend:
Answers
57
Questions
Helped
9621
Points
110
Try to watch a movie that doesnt contain snowing...
If you mean white pixels for no reason on the screen while whatching the tv it can be caused by unstable power, or tv signal.
try to remove tv cable, then replug it so the picture will clear
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Model LNT4061FX/XAA Intermittent snow then picture. Is there a cure?
Intermitant snow means your tv is not getting signal continuously. Please check the input signal connection and source to your tv.
Poor picture AVR1600
This is not the malfunction to remote as you thinks. It with the set itself.
How can i fix static on my maxent lcd tv
26 inch maxent mx-26x3 and 32 inch, l2614xw02 some same parts
When i hear the word static, i think snow,
If while your watching tv and it looks like color snow pixels popping in and out all over the picture i did this to fix it.
look at main board you see a green heat sink,
left of that heat sink you see a 220 uf 16 volt capacitor that half surround by 22 uf capacitors,
change the 220 uf capacitor and snow is gone.
to get it off i just wiggle slowly back in forth until the old capacitor falls off,
then put some fresh solder on and new capacitor on and done.
use a radial electrolytic capacitor not the little metal one they had on
tc
bagabillion
2helpful
2answers
A brief history: fixya helped me change my bulb (been receiving a "replace bulb" message for awhile until my picture went black). The picture now is snow, not black which seems to me to indicate the bulb...
Since you do have sound but snow for picture is your TV 54J or 54U chassis the PT50DL54J chassis shows 4 tuners also Have you look for Leaky or Bad capacitors if they are puffed up on top they are Bad 2200uf 25v 1000uf 25v Look for bad capacitors on tuner Boards, and I have seen where they are on Power supply board that will affect Picture.
1helpful
What can I do to fix the flipping of the screen from snow to prog
the tuner is getting a weak signal and that is why the vertical sync signal is weak and the picture is rolling .check the cable on the back
The picture on my old slyvania consoul set has become a bunch of snow but.
Good Day;
1984 > 1994 > 2004 > 2008 = ?; YOU are wondering WHAT? With the new tech of today and HD coming in spring of 2009, I think it is time you look for a new TV. Please give it a good resting place.
Good Luck, big IRISH.
Green and red snow
I had the same problem with Red/Green snow after 11mos of owning my Plasma. It was coevered under warranty thank goodness. The repair person had to replace all the inside circuit boards to fix.
3answers
52" SHARP LCD getting a snowy picture after 5 to 10 minutes
these sets are notorious for bad inverter boards and bad video processor boards.Sharp is well aware of the problem,and will fix the units if you push the issue.They have fixed these ynits out of warranty with a smile.This is a issue with defective parts not connections
Poor digital picture Toshiba ZP38 TV
Hi. Sounds like DRY JOINTS WITHIN DFS MODULE. This is a pcb within a rectangular metal screened box on the left hand side of set when looking from the front. Will need resoldering be carefull very fine print will need decent soldering iron with fine tip & poss magnyfying lamp to aid looking. If your not at all sure take to repair shop. This TV is nice set has one of the best crt pictures you can get.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
